LIFX Controller 4.0.6 Problems? [RESOLVED in 4.1.0]
autolog
Post by autolog »
UPDATE: There may be a problem with the 4.0.6 release that I need to investigate further - It is possible that after the initial discovery the plugin may lose contact with the LIFX devices. :?
If you have downloaded and installed 4.0.6, It is probably best to revert to 4.0.5 else stick with 4.0.5 :)
In the meanwhile I have set the 4.0.6 as a Pre-release on Github. :|
autolog
Re: LIFX Controller 4.0.6 Problems? [RESOLVED in 4.1.0]
Post by autolog »
Looks like the problem was also present in Version 4.1.0. :cry:
Hopefully this resolved in Version 4.1.3.
This version is marked as pre-release until I have user confirmation that it fixes the issue. :)
Return to “LIFX Controller”
