Execute shell command as root (sudo)
Discuss the Indigo Plugin SDK and developing Indigo plugins here.
kwijibo007
Post by kwijibo007 »
Hi All,
I would like to write a plugin that presents an on/off device which enables/disables remote login (SSH) on the Mac running Indigo server.
The command(s) to do this in terminal are:
systemsetup -getremotelogin #Query state
systemsetup -setremotelogin off  #Enable SSH
systemsetup -f -setremotelogin off  #Disable SSH
The problem is that this needs to be ran as root (prefixing with sudo). Is there anyway to run a command as root inside a plugin or is it impossible?
Pete
P.S Congrats to me on my 100th post!! :D
jay (support)
Re: Execute shell command as root (sudo)
Post by jay (support) »
I think if you wrap it in an AppleScript thusly it will work:
do shell script "YOUR COMAND HERE" with administrator privileges
I think that'll cause the authentication dialog to open. Not positive it'll work, but I'm pretty sure this is what PyCharm does when installing packages, etc.
Note, however, that the user will have to be sitting at the Mac to authenticate. AFAIK, there is no way to automatically run a sudo process.
roussell
Post by roussell »
You can also exclude the file in sudoers to allow running it without a password. I suggest rather than editing the sudoers file, create an override like so:
sudo visudo -f /etc/sudoers.d/myOverrides
A new file called 'myOverrides' will be created and open in visudo (like the vi editor, but performs checks to make sure you don't lock yourself out of sudo with a syntax error). To allow any user to run the application without a password enter the following in to the file:
ALL ALL=(ALL) NOPASSWD: /usr/sbin/systemsetup
Save the file and exit. Then if you run
sudo /usr/sbin/systemsetup
it won't ask for a password, but note that you still have to use the sudo command.
WARNING: This has obvious security concerns. You can minimize those somewhat making a copy of the systemsetup file somewhere else with an innocuous name:
sudo cp /usr/sbin/systemsetup /Users/indigo/birthdaylist
(assuming the username you run Indigo under is "indigo")
Then of course you'd change your myOverrides file to point to the copied version of the file. You can also restrict it to the username Indigo is running as:
indigo ALL=(ALL) NOPASSWD: /Users/indigo/birthdaylist
You can also specify arguments such as:
indigo ALL=(ALL) NOPASSWD: /Users/indigo/birthdaylist -setremotelogin on
indigo ALL=(ALL) NOPASSWD: /Users/indigo/birthdaylist -f -setremotelogin off
The above will allow that command with those arguments to run without a password for the user 'indigo', but other users/commands/arguments will require a password.
Terry
RogueProeliator
Post by RogueProeliator »
Wow, great tip, Terry! I haven't needed that but was unaware that was even a thing... will put that away in the brain so that when I need it I won't remember but might feel a tickle making me search for it. :-)
jay (support)
RogueProeliator wrote:Wow, great tip, Terry! I haven't needed that but was unaware that was even a thing... will put that away in the brain so that when I need it I won't remember but might feel a tickle making me search for it. :-)
+1 - awesome tip.
roussell
Post by roussell »
Heh, thanks guys, hope it helps the OP. I suck at software development, but *nix is my jam... 8)
Terry
kwijibo007
roussell wrote:Heh, thanks guys, hope it helps the OP
Fantastic stuff. Thanks Terry, exactly what I was looking for. :D
I have no excuses now... I'd better write the plugin.
Pete
kwijibo007
I've posted the plugin here.
Thanks again Terry for your help.
Pete
roussell
Post by roussell »
kwijibo007 wrote:I've posted the plugin here.
Pete
Anytime Pete, happy to be of service! Nice plugin BTW!
Terry
Return to “Plugin SDK and Development”
