Roomba 980 Scripts
Re: Roomba 980 Scripts
The "NotReady" codes don't appear to be documented anywhere, but they have important info. I don't know if these are some binary code like the flags are, but I have found:
7 - bin missing
15 - (is possibly) low battery
16 - bin full
It's interesting that when the bin is full, Roomba just goes and parks itself without giving a warning. Seems like a design flaw (that I have now fixed by sending a message when that happens).
7 - bin missing
16 - bin full
- FlyingDiver
The plugin is pretty much done, based on the code you posted. My new Roomba will be here tomorrow so I can start testing.
Great - I look forward to seeing it.FlyingDiver wrote:The plugin is pretty much done, based on the code you posted. My new Roomba will be here tomorrow so I can start testing.
Someone might find this list of error codes helpful. They appear to be accompanied by a Phase: Stuck variable.
roombaError = str(indigo.variables['roombaError'].value)
if roombaError == '0':
indigo.variable.updateValue('roombaErrorText', value=str('0: No Error'))
elif roombaError == '1':
indigo.variable.updateValue('roombaErrorText', value=str('1: Place Roomba on a flat surface then press CLEAN to restart.'))
elif roombaError == '2':
indigo.variable.updateValue('roombaErrorText', value=str('2: Clear Roombas debris extractors, then press CLEAN to restart.'))
elif roombaError == '5':
indigo.variable.updateValue('roombaErrorText', value=str('5: Left/Right. Clear Roombas wheel, then press CLEAN to restart.”'))
elif roombaError == '6':
indigo.variable.updateValue('roombaErrorText', value=str('6: Move Roomba to a new location then press CLEAN to restart. The cliff sensors are dirty, it is hanging over a drop, or it is stuck on a dark surface.'))
elif roombaError == '8':
indigo.variable.updateValue('roombaErrorText', value=str('8: The fan is stuck or its filter is clogged.'))
elif roombaError == '9':
indigo.variable.updateValue('roombaErrorText', value=str('9: Tap Roombas bumper, then press CLEAN to restart.'))
elif roombaError == '10':
indigo.variable.updateValue('roombaErrorText', value=str('10: The left or right wheel is not moving.'))
elif roombaError == '11':
indigo.variable.updateValue('roombaErrorText', value=str('11: Roomba has an internal error.'))
elif roombaError == '14':
indigo.variable.updateValue('roombaErrorText', value=str('14: Re-install Roomba’s bin then press CLEAN to restart. The bin has a bad connection to the robot.'))
elif roombaError == '15':
indigo.variable.updateValue('roombaErrorText', value=str('15: Press CLEAN to restart. Roomba has an internal error'))
elif roombaError == '16':
indigo.variable.updateValue('roombaErrorText', value=str('16: Place Roomba on a flat surface then press CLEAN to restart. Roomba has started while moving or at an angle, or was bumped while running.'))
elif roombaError == '17':
indigo.variable.updateValue('roombaErrorText', value=str('17: The cleaning job is incomplete.'))
elif roombaError == '18':
indigo.variable.updateValue('roombaErrorText', value=str('18: Roomba cannot return to the Home Base or starting position.'))
indigo.variable.updateValue('roombaErrorText', value=str('xx: Undocumented Error.'))
- FlyingDiver
Roomba arrived a couple hours ago. I can successfully retrieve the password and blid, but that's as far as I've gotten so far. Need to make dinner soon.
Thanks for the ongoing work on this - following with interest!
Hopefully using my script!FlyingDiver wrote:I can successfully retrieve the password and blid...
- FlyingDiver
Well, a derivative of your script.
- FlyingDiver
Well, the Roomba didn't pass the wife test, so it was returned on the 30th day. We'll try again in a couple of years.
- FlyingDiver
Really? We like our 980 a lot. But then we've used an 880 for almost a year now.Bollar wrote:Well, the Roomba didn't pass the wife test, so it was returned on the 30th day. We'll try again in a couple of years.
