I have just looked at the plugin code and it is checking specifically for a Stella-Z so it won't handle a Comet.
That's the bad news BUT the potential good news is that if it isn't too much work, I may be able to fix that for you.
I guess you don't need the heat source controller - not sure what the best way round this is as removing that from the code could be problematic.
It might work by being able to define a Virtual Device that can be used by the plugin to turn on and off - I'll take a look at that.
You'll have to give me a day or so to get round to it as I am in the middle of fixing an issue with the Alexa-Hue Bridge.
I haven't got a Comet thermostat, so if I do the change, you will have to test it and report back to me.
Assuming that is OK, what would be helpful is if you could do a dump to the Event Log and PM me the results of the Comet device as follows:
Run an Action Group script (Server Actions > Script and File Actions > Execute Script) (Embedded > Python) of the form:
indigo.server.log(u'Comet Device:\n%s' % (indigo.devices[12345678]))
