[SOLVED]: ZIPATO - Bulb LED RGBW Z-Wave
Re: [SOLVED]: ZIPATO - Bulb LED RGBW Z-Wave
It's not just you, I get the same problem. When you turn on the "Warm White" channel after turning off the bulb it turns to the brighter "daylight" white color. You have to go to the device page, pick the bulb turn everything off and then turn on the warm white slider to actually get warm white.
- matt (support)
- Site Admin
- Contact:
Krissh and Toille27: are you both seeing 2 devices (grouped together as tabs) for each Zipato bulb?
Can you define/sync them and copy/paste the Event Log results into a reply for me?
Matt, two tabs appear next to each other in the devices page. I'll send you a sync tomorrow .
Hi Matt.
I am also seeing the same behavior and UI.
To get this to work "properly" I have been tweaking this with action groups as long as I have used this device.. Always sending an off command before setting the rgb value, en brightness at the end. I spent quite some time trying to figure out how get it to work "ok". Below is my sync log.
Z-Wave Syncing - started for "Light - RGBW Garasje Master"
Z-Wave Syncing - retrieved module neighbors list: 6, 7, 8, 10, 11, 12, 14, 15, 16, 18, 19, 22, 24, 25, 31, 45, 46, 47, 48, 72, 82, 88, 100, 113
Z-Wave Syncing - assigning return route to "104 - Light - RGBW Garasje Master"
Z-Wave Syncing - retrieved manufacture and model names: Zipato - 0131, RGBW LED Bulb - 00020002
Z-Wave Syncing - retrieved protocol version 3.83, app version 1.05
Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
Z-Wave Syncing - retrieved command classes: 20v1 60v2 73v1 85v1 26v1 27v1 70v1 72v1 33v1 5Ev1 59v1 5Av1 7Av1 86v1
Z-Wave Syncing - retrieved encrypt commands: - none -
Z-Wave Syncing - retrieved capabilities: routing, beaming
Z-Wave Syncing - retrieved multi-endpoint types: 1:(11 : 01)
Z-Wave Syncing - retrieved multi-endpoint classes: 1:[26 05]
Z-Wave Syncing - retrieved group 1 associations: [1]
Z-Wave Syncing - group 1 association to interface already exists (skipping)
Z-Wave Syncing - retrieved parameter 1 "Color temperature" is 50
Z-Wave Syncing - retrieved parameter 2 "Tapping sensitivity" is 16
Z-Wave Syncing - complete
Håvard
- matt (support)
- Site Admin
- Contact:
What I think is complicating things here is that there are 2 different firmware versions with very different behaviors. There is the older version (module app version 1.05) which defines 2 different end points (personalities) for the device, and there is the newer version (module app version 1.06 and higher) that defines just a single device.
I'm not sure how the Indigo 7 changes are working with 1.06 yet. I know forum user opbzil has that one, but I think most others (haavarda, krissh, toille27) probably have the older more "eccentric" version.
For the older firmware I believe the 2nd device controls the brightness of white, and the color temperature of the white should be set via the Color Temperature edit field in the settings dialog. The first device should be used to set only the RGB components. I don't think you want to try to use the W or W2 sliders at all with the older firmware. I might try to get those hidden/disabled, but it is somewhat problematic since the device definition is shared with the newer firmware version.
For the newer firmware there will be just a single device and hopefully all the UI will work correctly.
It sounds like in the older firmware the module is getting confused if one of the devices is controlled without the other one being turned off? Also just leave those W and W2 sliders at 0, I think.
Mine is also 1.05, so you are correct, sync log:
The 2nd device, if I remember correctly, used to be for warm white in Indigo 6. Now in Indigo 7 it seems that this 2nd device is just cold white.
The W slider seems to be for warm white, but that will reset any colors set, log output:
Even with both W and W2 at 0, I can't set any color while the bulb is on.
Guess the workaround will be to make actions to turn it off before setting colors etc., like haavarda is doing.
Z-Wave Syncing - started for "Zipato lyspaere"
Z-Wave Syncing - retrieved module neighbors list: 3, 5, 6, 14, 15
Z-Wave Syncing - assigning return route to "010 - Zipato lyspaere"
Z-Wave sent "Zipato lyspaere" status request
Z-Wave received "Zipato lyspaere" status update brightness 80
Z-Wave sent "Zipato lyspaere varm" status requestThe W slider seems to be for warm white, but that will reset any colors set, log output:
Z-Wave sent "Zipato lyspaere" set color to -- -- --, 57 --Guess the workaround will be to make actions to turn it off before setting colors etc., like haavarda is doing.
Could it be programmed to be an option to select 1.5 behavior in the device settings? In that way you could separate the two firmwares...
Håvard
- matt (support)
- Site Admin
- Contact:
I might be able to change the behavior based on the firmware version, but I'm not sure exactly what changes to make at this point. I'm a bit puzzled as to how the behavior has changed for you all in Indigo 7 so much. For Indigo 7 we added the RGB and W/W2 sliders to the first device, but if you ignore those (set them to 0), I would expect the behavior to be the same as Indigo 6. It doesn't sound like it is, but I'm not sure why.
Maybe it could be smart to set up a test? If we all test under the same criteria it is easier to determine how it behaves.
Håvard
Mat, has something changed with this device? Since Indigo 7 I am struggling big time to set RGB levels...
Håvard
- matt (support)
- Site Admin
- Contact:
Indigo 7 definitely changes how it works with RGB devices (new UI, actions, etc.), but your existing actions should continue to work. Try re-Define/Syncing it Indigo (no need to exclude/re-include it, just re-sync it). Does that help? If not describe exactly what you are seeing and include some Event Log window copy/paste snippets.
I am a little uncertain on how to do fault finding on this. If I try to change colour on the device UI it is working. But if I try to do it with an action group it does not change colour.
I dont know if the info below helps. Please let me know if you need any other data. I have tried to re include the device since I at one time thought it had gotten in to a bad state.
Below is some colour changes from the device UI:
And now the colour change from Action group:
Z-Wave Debug SENT setRgbColorValues: 01 10 00 13 78 09 33 05 03 02 FF 03 80 04 00 25 0E E9
Z-Wave sent "Light - RGBW Garasje Master" set color to 100 50 0, -- --
Z-Wave Debug SENT setRgbColorValues: 01 10 00 13 78 09 33 05 03 02 80 03 00 04 80 25 0F 97
Z-Wave sent "Light - RGBW Garasje Master" set color to 50 0 50, -- --
Z-Wave Debug SENT setRgbColorValues: 01 10 00 13 78 09 33 05 03 02 00 03 00 04 FF 25 10 77
Z-Wave sent "Light - RGBW Garasje Master" set color to 0 0 100, -- --
Z-Wave Debug RCVD requestMeterLevel: 01 10 00 04 00 0A 0A 32 02 21 44 00 04 E3 59 00 00 00
Z-Wave Debug . . requestMeterLevel: node 010, endpoint None, meterType 01, raw value 4400...
Z-Wave Debug . . requestMeterLevel: 3203.45 kWh (float: 3203.450000)
Z-Wave received "Dehumidifier - Garage" energy total to 3203.45 kWh
Z-Wave Debug SENT setRgbColorValues: 01 10 00 13 78 09 33 05 03 02 FF 03 00 04 00 25 11 76
Z-Wave sent "Light - RGBW Garasje Master" set color to 100 0 0, -- --
Z-Wave Debug SENT setRgbColorValues: 01 10 00 13 78 09 33 05 03 02 00 03 FF 04 00 25 12 75
Z-Wave sent "Light - RGBW Garasje Master" set color to 0 100 0, -- --
Action Group Bulb Garasje - Multi Blue colour
Schedule _delayed_action_90
Z-Wave Debug SENT setRgbColorValues: 01 14 00 13 78 0D 33 05 05 02 00 03 00 04 FF 00 00 01 00 25 18 78
Z-Wave sent "Light - RGBW Garasje Master" set color to 0 0 100, 0 0
Action Group Bulb Garasje - Multi Green colour
Z-Wave Debug SENT setMultiLevelValue: 01 0A 00 13 78 03 26 01 63 25 19 E5
Z-Wave sent "Light - RGBW Garasje Master" set brightness to 100
Schedule _delayed_action_89
Z-Wave Debug SENT setRgbColorValues: 01 14 00 13 78 0D 33 05 05 02 00 03 FF 04 00 00 00 01 00 25 1A 7A
Z-Wave sent "Light - RGBW Garasje Master" set color to 0 100 0, 0 0
Action Group Bulb Garasje - Multi Red colour
Z-Wave Debug SENT setRgbColorValues: 01 14 00 13 78 0D 33 05 05 02 FF 03 00 04 00 00 00 01 00 25 1B 7B
Z-Wave sent "Light - RGBW Garasje Master" set color to 100 0 0, 0 0
Z-Wave Debug SENT setMultiLevelValue: 01 0A 00 13 78 03 26 01 63 25 1C E0
Z-Wave Debug SENT setRgbColorValues: 01 14 00 13 78 0D 33 05 05 02 00 03 00 04 FF 00 00 01 00 25 1D 7D
Z-Wave Debug SENT setMultiLevelValue: 01 0A 00 13 78 03 26 01 63 25 1E E2
Z-Wave Debug SENT setRgbColorValues: 01 14 00 13 78 0D 33 05 05 02 00 03 FF 04 00 00 00 01 00 25 1F 7F
Z-Wave Debug SENT setRgbColorValues: 01 14 00 13 78 0D 33 05 05 02 FF 03 00 04 00 00 00 01 00 25 20 40
Z-Wave Debug SENT setMultiLevelValue: 01 0A 00 13 78 03 26 01 63 25 21 DD
Z-Wave sent "Light - RGBW Garasje Master" set brightness to 100- Attachments
- Skjermbilde 2017-03-21 kl. 18.08.14.png (78.02 KiB) Viewed 4098 times
Håvard
I was able to sort of use it reliably with Indigo 6, but after spending many hours trying to get it to work with 7, I gave up and bought an Aeotec bulb.
- matt (support)
- Site Admin
- Contact:
