Thanks again for this.
With just these initial functions, I quickly created Action Groups to add users to my new locks and I added a schedule to allow a contractor access during the day.
<Action id="setUserPin" deviceFilter="indigo.relay,indigo.zwave">
FlyingDiver wrote:Working fine with my Kwikset 910, so far.
Suggestion - change the deviceFilter in your Devices.xml
howartp wrote:FlyingDiver wrote:Working fine with my Kwikset 910, so far.
Ah, thanks - didn't realise I could combine filters.
I've already asked about filter for just locks - not available yet
for dev in indigo.devices.iter("indigo.relay, props.IsLockSubType"):
print dev.name
# Or:
<Action id="setUserPin" deviceFilter="indigo.relay,props.IsLockSubType">
<Action id="setUserPin" deviceFilter="indigo.relay,indigo.zwave,props.IsLockSubType">
FlyingDiver wrote:WouldWork?
- Code: Select all
indigo.insteon, indigo.x10, indigo.relay, indigo.dimmer, props.SupportsColor, props.SupportsWhiteTemperature
(insteon OR x10) AND (relay OR dimmer) AND (props["SupportsColor"] OR props["SupportsWhiteTemperature"])
matt (support) wrote:Yes, that would and you are correct that is what we want here since the functionality is Z-Wave specific. Note that logically the search is performed by AND'ing the categories (protocol, class, and props) and OR'ing the property items within a category. For example, using a filter string of:
- Code: Select all
logically performs a search using:
- Code: Select all
matt (support) wrote:I actually got it snuck into 7.0 but forgot to tell anyone
howartp wrote:Don't suppose device.scenecontrollers exists yet...?
howartp wrote:Can you do my subforum for lock manager?
howartp wrote::-)
Doesn't help that Tapatalk doesn't show empty subforums!
