Better Email plugin discussion thread
Re: Better Email plugin discussion thread
I'm getting this error in my Indigo log when running 1.2.13
Better Email Error Error: Move Permanently
Turning on debugging....
Better Email Debug GET /repos/FlyingDiver/BetterEmail/Releases/latest
Better Email Debug HTTP 301 Moved Permanently
Also, and more important, after about 24 hours or so, the plug-in stops working.
I'm using it with IMAP and and Gmail account.
After it stops working, if I reset it with Indigo command "Plugins > Better Email > Reload" it restarts and finds several pending emails and processes them.
This has happened several days in a row.
Any suggestions?
Any suggestions?
- FlyingDiver
I changed the name of the repository on GitHub. That's causing the error.
Install this version manually: https://github.com/FlyingDiver/Indigo-B ... 1.2.14.zip
I'm using the plugin in my Indigo 5 setup. Yes, I know that Indigo 5 is "so last year" but the server hardware is paid for and still works great!FlyingDiver wrote:I'm trying to get a handle on how many people are using this plugin.
The primary reasons for liking the plugin is that it supports variable substitution in its outgoing message fields. Secondarily is its ability to properly do STARTSSL with my SMTP server. Yep, all my HA-based messages are super secret.
/Marty
Any suggestions?
I'd like to continue using this plug-in if I can resolve the reliability.
Compared to the built-in email support in Indigo I like that it supports IMAP and not simply POP and that with IMAP support, incoming email is detected faster than the built-in Indigo plug-in which polls for email at 1 minute (or longer) intervals.
- FlyingDiver
Make sure you're running the latest version (see above).spiv wrote: Also, and more important, after about 24 hours or so, the plug-in stops working.
Any suggestions?
Turn on debug logging. When it seems to stop working, force a poll (menu). Then post the log output (use CODE tags).
***** I checked for the correct/updated version
Aug 15, 2016, 9:16:49 AM
BetterEmail Debug Plugin version detected: 1.2.14
BetterEmail Debug Current version is: 1.2.14
BetterEmail Debug Getting latest release from FlyingDiver/Indigo-BetterEmail...
BetterEmail Debug GET /repos/FlyingDiver/Indigo-BetterEmail/releases/latest
BetterEmail Debug HTTP 200 OK
BetterEmail Debug Latest release is: 1.2.14
****** With nothing happening, even after I activated the device trigger, I reloaded the plug-in
Reloading plugin "BetterEmail 1.2.14"
Stopping plugin "BetterEmail 1.2.14" (pid 764)
BetterEmail Debug Removing Trigger Better Email IOTbuttonDoublePress (1841385603)
BetterEmail Debug Removing Trigger Better Email IOTbuttonLongPress (429389513)
BetterEmail Debug Removing Trigger Better Email IOTbuttonSinglePress (1152249399)
BetterEmail Debug Stopping server: [email protected]
BetterEmail Shutting down Better Email
Stopped plugin "BetterEmail 1.2.14"
Starting plugin "BetterEmail 1.2.14" (pid 18800)
BetterEmail Debug Debugging enabled
Started plugin "BetterEmail 1.2.14"
BetterEmail Starting Better Email
BetterEmail Debug [email protected]: Device Current Version = 3
BetterEmail Debug [email protected]: Device Version is up to date
BetterEmail Debug Starting server: [email protected]
BetterEmail Debug [email protected]: Doing connect using encryptionType = SSL
BetterEmail Debug [email protected]: idle() called
BetterEmail Debug Adding Trigger Better Email IOTbuttonDoublePress (1841385603)
BetterEmail Debug Adding Trigger Better Email IOTbuttonLongPress (429389513)
BetterEmail Debug Adding Trigger Better Email IOTbuttonSinglePress (1152249399)
***** I forced the plug-in to poll, nothing happened
Aug 15, 2016, 9:19:58 AM
BetterEmail Debug Polling All Email Servers
BetterEmail Debug Polling serverId: 664960021, serverTypeId: imapAccount([email protected])
BetterEmail Debug Skipping IMAP Server using IDLE: [email protected]
***** I had the plug-in clear existing messages - seems to do something, but......
Aug 15, 2016, 9:20:27 AM
BetterEmail Debug Clearing all SMTP Queues
****** I activate the trigger device, and now, finally, the plug-in sees all the older pending emails (which should have been deleted) plus the new one...
Aug 15, 2016, 9:20:46 AM
BetterEmail Debug [email protected]: IDLE Event Received
BetterEmail Debug [email protected]: Doing checkMsgs
BetterEmail Debug [email protected]: msg_ids = ['1 2 3 4 5 6 7 8 9 10']
BetterEmail Debug [email protected]: Checking Message # 1
BetterEmail Debug [email protected]: Fetching Message # 1
BetterEmail Debug Received Message Subject: Hello from your IoT Button G030JF053347NAFM: SINGLE
BetterEmail Debug Received Message From: AWS Notifications <[email protected]>
BetterEmail Debug Received Message ID: <0101015680c70c4d-84140fcf-6bf3-4a8c-a66e-3e6dec84b560-000000@us-west-2.amazonses.com>
BetterEmail Debug Checking Triggers for Device [email protected] (664960021)
BetterEmail Debug Checking Trigger Better Email IOTbuttonLongPress (429389513), regexMatch
BetterEmail Debug Checking Device State messageSubject for Pattern: LONG
BetterEmail Debug No Match for Trigger Better Email IOTbuttonLongPress (429389513)
BetterEmail Debug Checking Trigger Better Email IOTbuttonSinglePress (1152249399), regexMatch
BetterEmail Debug Checking Device State messageSubject for Pattern: SINGLE
BetterEmail Debug Executing Trigger Better Email IOTbuttonSinglePress (1152249399), match: SINGLE
BetterEmail Debug Checking Trigger Better Email IOTbuttonDoublePress (1841385603), regexMatch
Action Collection Better Email IOTbutton SINGLE received
BetterEmail Debug Checking Device State messageSubject for Pattern: DOUBLE
BetterEmail Debug No Match for Trigger Better Email IOTbuttonDoublePress (1841385603)
BetterEmail Debug Deleting message # 1
Sent INSTEON "FamilyRoom Cylinder Lamps" off
BetterEmail Debug [email protected]: Checking Message # 2
BetterEmail Debug [email protected]: Fetching Message # 2
BetterEmail Debug Received Message ID: <0101015680ca73cb-f245d3ab-bb47-4a6f-b51c-a8bb7b27ce6c-000000@us-west-2.amazonses.com>
BetterEmail Debug Deleting message # 2
****** etc. etc. for the rest of the pending emails
- FlyingDiver
It's acting like Gmail isn't handling IDLE properly. Turn that off and set a fairly short poll time instead.
And you'll need to delete all the old emails by hand. The plugin won't delete a message it thinks it's already dealt with.
If I disable IDLE and enable polling, the shortest time allowed is 1 minute intervals. That is the same time as used by the Indigo built in POP email receiver.
I was using Better Email primarily because of the "near instant" response, rather than the support for smarter parsing or other email protocols.
Is there any other fix? Is there a free IMAP provider other than Google that is more reliable and trustworthy that anyone can recommend?
- FlyingDiver
One of the problems is that Gmail isn't really IMAP. It's a proprietary server protocol that they attempt to make look like IMAP.
That said, was this previously working? If so, has anything changed that you know of?
You can get a free iCloud account from Apple that works correctly, as I recall. I figure Apple is more trustworthy than Google, at least when it comes to not data-mining your emails. YMMV.
Thanks for your help!
The Better Email plugin works with Gmail using IDLE, it just stops working after some long period of time, approx 24 to 48 hours, but I have not watched over it closely enough to tell you the exact duration.
For recommendation of alternative IMAP, I'm hoping someone that is using a mail provider with the Better Email plug-in can chime in. I should have been more specific - I am looking for feedback on possible alternative IMAP providers that are known to work flawlessly with this plug-in and IDLE. From that, I can choose the company/privacy policy/trustworthiness, etc. from my end.
Thanks again!
Thanks again!
- FlyingDiver
If that's the case, it's almost certain that Gmail is doing something weird on their end and shutting down the connection improperly.
What I would do is schedule an action that restarts the plugin every 24 hours, like this:
Or, you could disable and re-enable the Gmail IMAP device. I think that will probably also work.
plugin = indigo.server.getPlugin("com.flyingdiver.indigoplugin.betteremail")
if plugin.isEnabled():
plugin.restart()
Could not send any email...
" BetterEmail Error HighPerfPro SMTP: SMTP server connection error: character mapping must return integer, None or unicode"
- FlyingDiver
Does your smtp server login or password include Unicode characters?shapa wrote:Could not send any email...
No, only latin, as well as some non-numeric ($, *, $, #)
Tried alpha-numeric password with no success
From the server log:
07:37:27.808 4 SMTPI-187239([213.152.xx.xx]:31900) [78.40.149.16]:587 <- [213.152.xx.xx]:31900 incoming connection(highperf.pro)
07:37:27.808 5 SMTPI-187239([213.152.xx.xx]:31900) out: 220 highperf.pro ESMTP CommuniGate Pro is glad to see you!\r\n
07:37:28.463 5 SMTPI-187239([213.152.xx.xx]:31900) inp: ehlo macserver.local
07:37:28.463 5 SMTPI-187239([213.152.xx.xx]) out: 250-highperf.pro we trust you macserver.local\r\n250-DSN\r\n250-SIZE\r\n250-STARTTLS\r\n250-AUTH LOGIN PLAIN CRAM-MD5 DIGEST-MD5 GSSAPI MSN NTLM\r\n250-ETRN\r\n250-TURN\r\n250-ATRN\r\n250-NO-SOLICITING\r\n250-HELP\r\n250-PIPELINING\r\n250 EHLO\r\n
07:37:28.483 5 SMTPI-187239([213.152.xx.xx]) inp: STARTTLS
07:37:28.483 5 SMTPI-187239([213.152.xx.xx]) out: 220 please start a TLS connection\r\n
07:37:28.579 4 SMTPI-187239([213.152.xx.xx]) TLS-163859(DHE_AES256_SHA) connection accepted for DOMAIN(highperf.pro)
07:37:28.620 5 SMTPI-187239([213.152.xx.xx]) s-inp: ehlo macserver.local
07:37:28.620 5 SMTPI-187239([213.152.xx.xx]) s-out: 250-highperf.pro we trust you macserver.local\r\n250-DSN\r\n250-SIZE\r\n250-AUTH LOGIN PLAIN CRAM-MD5 DIGEST-MD5 GSSAPI MSN NTLM\r\n250-ETRN\r\n250-TURN\r\n250-ATRN\r\n250-NO-SOLICITING\r\n250-HELP\r\n250-PIPELINING\r\n250 EHLO\r\n
07:37:28.641 5 SMTPI-187239([213.152.xx.xx]) s-inp: AUTH CRAM-MD5
07:37:28.641 5 SMTPI-187239([213.152.xx.xx]) SASL-0(CRAM-MD5) out: <[email protected]>
07:37:28.641 5 SMTPI-187239([213.152.xx.xx]) s-out: 334 PDE4NzIzOS4xNDc5MTA5MDQ3QGhpZ2hwZXJmLnBybz4=\r\n
07:37:28.662 3 SMTPI-187239([213.152.xx.xx]) read failed. Error Code=connection closed by peer
07:37:28.662 5 SMTPI-187239([213.152.xx.xx]) s-out: 535 SASL protocol has been interrupted\r\n
07:37:28.662 4 SMTPI-187239([213.152.xx.xx]) TLS connection is closing
07:37:28.662 4 SMTPI-187239([213.152.xx.xx]) closing connection
07:37:28.662 4 SMTPI-187239([213.152.xx.xx]) releasing stream
