Hue Lights - Free Philips Hue Plugin
nsheldon
Re: Hue Lights - Free Philips Hue Plugin
Post by nsheldon »
Version 1.3.30 Posted
  • Fixed a bug in 1.3.29 that prevented Hue Lights from recognizing the 2nd generation LightStrips.
nsheldon
Post by nsheldon »
Version 1.4.0 Posted
  • Added support for color picker in RGB and HSB color setting actions.
  • Added support for color and white temperature UI features in Indigo.
  • Added Toggle Debugging menu item in Hue Lights plugin menu.
  • Changed Hue Lights to now require Indigo 7 or later.
  • Changed LightStrip Plus handling so it appears with the original Hue LigthStrip model in Edit Device Settings dialog.
  • Updated Hue Group device name to show that it's no longer experimental.
nsheldon
Post by nsheldon »
Version 1.4.1 Posted
  • Fixed a bug with LivingColors light update processing that caused the plugin to crash.
nsheldon
Post by nsheldon »
Version 1.4.2 Posted
  • Fixed a bug with Ambiance Lights selection list in Edit Device Settings dialog that caused them to not appear.
nsheldon
Post by nsheldon »
Version 1.4.3 Posted
  • Fixed a bug with Ambiance Lights Edit Device Settings dialog that wouldn't allow you to save changes.
nsheldon
Post by nsheldon »
Version 1.4.4 Posted
  • Fixed another bug with Ambiance Lights Edit Device Settings dialog that would incorrectly show an error that the device wasn't an Ambiance Light.
nsheldon
Post by nsheldon »
Version 1.4.5 Posted
  • Added automatic detection and loading of new lights and groups. No need to manually reload lights with the Reload Hue Device List menu item.
  • Fixed a bug that incorrectly reported some updated devices as being out of date (from an old Hue Lights plugin version).
  • Improved hue device status updating efficiency to reduce the number of Hue hub queries.
nsheldon
Post by nsheldon »
Version 1.4.6 Posted
  • Fixed a bug that would cause the plugin to crash when updating Ambiance light white levels.
  • Fixed the device startup bug that warned of old devices. The plugin now automatically detects and updates any old Hue Lights devices and simply puts a notice of this in the Indigo log.
  • Changed light and group status update process to use less CPU in mid to large Hue installations.
  • Fixed a potential bug in the startup code that may have caused an infinite device reload loop, and thus high CPU load.
  • Fixed a bug that caused an error when attempting to edit Hue Groups device settings in the Indigo UI.
  • Added some underlying code needed to support scenes and sensors, as well as other Hue features. Scenes and sensors are not yet supported, but it will now be easier to provide limited support in the future.
nsheldon
Post by nsheldon »
Version 1.4.7 Posted
  • Added all Hue Beyond, Entity, Impulse, and Phoenix lights to the appropriate compatable device lists.
  • Added a new Ambiance Ceiling model to the compatible device list.
  • Moved some Hue Phoenix models out of the LivingWhites and into the Ambiance compatible device list. This will require you to re-define or delete and re-create the Phoenix device in Indigo.
nsheldon
Post by nsheldon »
Version 1.4.8 Posted
  • Fixed a bug that would cause an error when editing the Set Hue/Saturation/Brightness action settings.
  • Fixed definition for one model of LivingColors light that was incorrectly placed in the Extended Color/Ambiance bulb group.
nsheldon
Post by nsheldon »
Version 1.4.9 Posted
  • Fixed a bug that didn’t save brightness levels of lights for later recall if using the Turn On built-in Indigo function.
nsheldon
Post by nsheldon »
Version 1.5.0 Posted
  • Added limited Hue Scene support with a Recall Hue Scene action which can activate any scene stored on the Hue hub.
  • Added tool tips to all Hue Lights controlled Indigo UI windows.
  • Fixed automated plugin version checking that wasn’t comparing current and latest versions correctly.
  • Improved Hue Groups device setup dialog so you can see a list of all the lights in the selected group from within the device setup window.
nsheldon
Post by nsheldon »
Version 1.5.1 Posted
  • Added a Recall Hue Scene menu item to Plugins -> Hue Lights menu to easily recall a Hue scene from the Indigo GUI without having to create an Action Group or trigger action.
  • Fixed a UI bug in the Recall Hue Scene action settings window that prevented the Lights Affected list from being populated on initial action creation.
nsheldon
Post by nsheldon »
Version 1.5.2 Posted
  • Added support for another Hue White ambiance bulb (BR13 model).
nsheldon
Post by nsheldon »
Version 1.5.3 Posted
  • Added support for the Hue color cancle and ambiance candle E14 bulbs.
Locked
Return to “Archives”
