If you've already installed PILLOW and iTravel can't find it you need to reinstall it under python 2.6.
First disable the plugin
Install pip2.6, if you don't already have it, is easy enough and you can read step by step instructions in this post: http://forums.indigodomo.com/viewtopic. ... 71&t=16723
Now install PILLOW under python 2.6 by Opening a Terminal window (/Applications/Utilities/Terminal) and then at the $ prompt type sudo pip2.6 install PILLOW followed by ENTER
When the $ prompt returns (and it may take some time) type python2.6 (the 2.6 is very important)
You should get a response like:
Mac-mini:~ Michael$ python2.6
--> NOTE NUMBER --> Python 2.6.9 [/u](unknown, Oct 23 2015, 19:19:20) (my comments added)
[GCC 4.2.1 Compatible Apple LLVM 7.0.0 (clang-700.0.59.5)] on darwin
Type "help", "copyright", "credits" or "license" for more information.
>>> Now try import functools
Now try from suds.client import Client
Now try from functools import partial
Now try from PIL import Image
>>>import suds
>>> import functools
>>> exit()Now the plugin
You should be able to simply enable the plugin again and all should be good....
If you haven't downloaded version 0.2.21 you can get it from this link
https://www.dropbox.com/s/rjf1fp4xayj44 ... n.zip?dl=1
It should now find the modules in the right places and run! Hopefully
Let me know how it goes!
This will install PILLOW in the right place and the issue should be resolved.
Now
