Pretty easy to add, I'll put that in the next release as well.dnomode wrote:maximum that we can extend the ON time length?
Powermiser Plugin
- Colorado4Wheeler
Re: New Plugin: Powermiser
Right on. Thx.
Edmond
Edmond
Re: Powermiser Plugin
Edmond- for your kitchen, have you considered a motion sensor setup? I created (thanks to the forums users) a motion flow that says when the lights are on ( a virtual switch is set to on if any kitchen light is on) if motion is sensed after the vswitch is on, start a countdown of 10 minutes. If no motion is sensed before countdown, lights turn off, if motion is sensed before the timer hits zero, it resets and gives another 10 minutes...dnomode wrote:Great plugin. Thanks.
I have several timers setup that require 5 to 9 steps to accomplish what I want. Not even close to how nice this plugin is. Thanks
I was wondering if it's possible to add a warning that your lights are about to turn off and a maximum that we can extend the ON time length? For example, 5 minutes before the Kitchen Light turn off Indigo dims the lights by 45% and the back up to the original level. This allows my wife to hit the on button again to add 30 more minutes. Every push will give us an addition 30 minutes of ON time up to a max of 2 hours.
Would something like this work with this plugin?
Thanks for the great plugin.
Edmond
-Brian
-Brian
- Colorado4Wheeler
While that is completely legitimate, the purpose of Powermiser was to cut down on how many triggers you have in your system to accomplish the simple task of turning lights off automatically. So instead of 20 triggers for 20 rooms and 20 lights, you can create 1 or 2 Powermiser devices that do the exact same thing without the need for motion sensors at all, let alone the triggers and stuff that go along with turning things off.dz1rfj wrote:for your kitchen, have you considered a motion sensor setup
That is exactly what Powermiser does but without all the extra setup in Indigo.dz1rfj wrote:start a countdown of 10 minutes. If no motion is sensed before countdown, lights turn off, if motion is sensed before the timer hits zero, it resets and gives another 10 minutes...
I do use motion sensor, however my motion sensors don't detect us if we are standing around and working in the same spot or sitting at the kitchenette. When my motion sensors do detect someone it adds 30 minutes to the timer.dz1rfj wrote:
Makes sense, about the motion not triggering if sitting still, I use two , one at the kitchen table, and on on the other side..I look forward to the plugin supporting zwave, as I would love to be able to use those features. I use the motion because my wife was yelling at me every the lights turned off..the motion leaves them on a bit longer than needed, but if she is happy, well, you know the saying. The power miser sounds awesome, and I look forward to using it...
-Brian
-Brian
How about adding additional devices to trigger?
IE I use the DSC plugin with motion sensors to trigger lights, it would be great if i could select one of the motion sensors to trigger this plugin.
Great work on all your plugins, keep 'em coming!
Korey
Korey
Loved the Powermiser plug-in, and have been using for some time now.
However, lately, it has ceased to function, and is no longer configurable. When I try adding a new auto-off device, the "Device" field is blank (see attachment), and I cannot proceed without being able to select a device to control.
I have removed the plug-in, reinstalled, re-synced all Indigo devices, to no avail.
Any help would be appreciated. Thank you.
– Kevin
– Kevin
- ishot-1.jpg (47.98 KiB) Viewed 6461 times
- Colorado4Wheeler
I'll take a look this week at the release on the store, not sure why it would suddenly break on you. Did you change anything or upgrade?
You might try doing another fresh install with the following steps if you didn't take them all before.
disable the plugin
stop the Indigo server
exit Indigo
delete the plugin file
delete the plugin preference file
restart the server
re-install the plugin
I've found in some cases that the plugin preferences file can get into a bad state (this has happened to some of my plugins) and I've found that deleting the preferences file can set things right. An added bonus of recreating the preferences file is that it will ensure the preferences file itself is clean and up to date and reflects the latest configuration options only.
tl;dr: in some of my plugins, I write values to the preferences file on an interval basis--for example, poll intervals--which results in routine read/writes of the preferences file itself. I'm not sure, but I suspect that there are situations where a user opens or closes the configuration file at the same time that the plugin is trying to read from or write to it (and may be exacerbated depending on if/how Indigo caches the preferences file during these operations. This is not Indigo's fault and (regardless) I plan to move to a different architecture to try to eliminate this rare problem in the future.
disable the plugin
exit Indigo
restart the server
My Plugins and Scripts
Hello,
I'm also having the same problem that Kevin is having.
I've also tried the below
Edmond
Any Ideas?You might try doing another fresh install with the following steps if you didn't take them all before.
disable the plugin
exit Indigo
restart the server
Edmond
- Colorado4Wheeler
I'll see if I can download the plugin store copy today and replicate the problem on a fresh Indigo.
Not sure if this will help or not, however I get the following error when the Configure Auto Off window opens u.
Any ides?
Edmond
Any ides?
Edmond
Oct 7, 2018, 1:06:01 PM
EPS - Powermiser Error Exception in ui._cacheResults line 206: object of type 'NoneType' has no len()
CODE: if len(results) == 0 or index == "" or targetId == 0: return
EPS - Powermiser Error Error in plugin execution GetUiDynamicList:
TypeError: Expecting an object of type list; got an object of type NoneType insteadRe: Powermiser Plugin
As did Edmond, I tried the reinstall using the steps that DaveL17 suggested. The plug-in still does not populate the "Devices" field, so I have nothing to select.
I notice the following errors in the log when Powermiser was installed, however (see attachment).
I apologize for not responding sooner, I simply did not check the forum for a response until this week.
– Kevin
– Kevin
- ishot-1.jpg (120.99 KiB) Viewed 5946 times
"I'll take a look this week at the release on the store, not sure why it would suddenly break on you. Did you change anything or upgrade?"
In response from this earlier question: I did upgrade to Indigo 7, and then Indigo 7.2, but I can't pinpoint exactly when the plug-in stopped functioning.
What is also odd is I have several devices that were programmed to shut off using Powermiser before this failure of the plug-in was noticed. The plug-in still seems to be working with those devices (despite the missing "Devices" field). However, I can no longer program new devices, nor modify existing ones.
– Kevin
– Kevin
