- Triggers on received mail for both IMAP and POP. Optional deletion of received mails after processing.
- Subject and message text contents available as device states for triggers, conditionals, or action use.
- Scriptable actions for sending emails, polling servers, or clearing unsent message queues.
- Full variable or device state substitution for all components of outgoing email messages.
- Event triggers based on regular expression pattern matching.
- Automatic or user-programmed polling schedules
Better Email plugin - Official Release
- FlyingDiver
This plugin provides the capability to use multiple IMAP, POP, and SMTP servers. Capabilities include:
- FlyingDiver
Re: Better Email plugin
Version 0.0.4 released:
Update checking added, cleaned up the plugin menu, plus some minor error message improvements.
Bug reports, feature requests, and any other suggestions welcome.
- FlyingDiver
Version 0.0.5 released:
Event triggers based on Regular Expression matching for email subject or email body is now available.
- FlyingDiver
Version 0.0.6 released:
Unicode is now supported in all email fields. Charset UTF-8 is encoded as quoted-printable.
- FlyingDiver
Re: Better Email plugin - Official Release
Version 1.0.0 released. Pretty much the same as 0.0.6.
- FlyingDiver
Version 1.0.1 released. Allows for triggers and conditional testing based on the message's sender (From header), as well as message subject and content.
- FlyingDiver
Version 1.1.1 released. Enables use of IMAP IDLE mode for poll-less handling of email messages. Testing with my IMAP provider shows messages are processed within seconds of email reception at the server. Not all IMAP servers support IDLE mode.
https://dl.dropboxusercontent.com/u/756 ... -1.1.1.zip
- FlyingDiver
Current version is 1.2.5. Updates since 1.1.1 include support for unicode strings in received (IMAP/POP) message components.
The plugin now uses the GitHub Updater (ghpu) module for semi-automatic installation of new versions.
https://github.com/FlyingDiver/BetterEm ... v1.2.5.zip
- FlyingDiver
Current version is 1.2.6.
Fixes issue with SSL config for iCloud (and possibly other providers).
- FlyingDiver
Current version is 1.2.10. In this release:
Events are now specific to an email server. All events will need to be edited to select the server.
There are now two kinds of inbound email matching triggers - one for regex expressions, one for plain string matches. All events will need to be edited to select the event type.
Misc bug fixes as well, including a work-around for empty email bodies.
- FlyingDiver
Current version is v1.2.13.
This version fixes a number of bugs, and has first pass support for status icons in the Indigo device list UI.
- FlyingDiver
Current version is 1.2.14: https://github.com/FlyingDiver/Indigo-B ... 1.2.14.zip
You will probably need to install this version manually, as this version changes the GitHub repository and plugin in (removes the space in the name).
Sorry for the inconvenience.
I was having an issue where the default email configuration within Indigo was receiving authentication failures trying to pull from Gmail POP. So I researched the issue, and found that your plugin should provide advanced email function to Indigo, and decided to give it a try. I am unable to find any documentation on what I should do to configure your plugin, and if I select "Configure", it just takes me to a dialogue to set up for update notifications - nothing showing where you configure the plugin to check for email. So I went back to the regular email configuration dialog in Indigo to see if anything was changed there, but nothing different, and I still get authentication errors.
Looking though this thread, it looks like everyone is using your plugin just fine, but without some documentation, I can't see where I go to configure anything - please help.
- FlyingDiver
You have to create a BetterEmail device for each server (POP, IMAP, or SMTP) you want to communicate with. So just go to the New Devices dialog and pick BetterEmail.JeffS wrote:I was having an issue where the default email configuration within Indigo was receiving authentication failures trying to pull from Gmail POP. So I researched the issue, and found that your plugin should provide advanced email function to Indigo, and decided to give it a try. I am unable to find any documentation on what I should do to configure your plugin, and if I select "Configure", it just takes me to a dialogue to set up for update notifications - nothing showing where you configure the plugin to check for email. So I went back to the regular email configuration dialog in Indigo to see if anything was changed there, but nothing different, and I still get authentication errors.
