LCD Creator - Room-O-Matic or ANY Control Page
Colorado4Wheeler
Post by Colorado4Wheeler »
NOTICE
The original post, including information, screen shots, installation & documentation has been moved to THIS OTHER THREAD.
The rest of this topic has been left intact.
keifer1
Re: New Plugin: LCD Creator - Room-O-Matic or ANY Control Pa
Post by keifer1 »
WOW,
Computer Keith
Mt Pleasant SC - Charleston
Indi-Go -Go-Go
Colorado4Wheeler
keifer1 wrote:WOW,
My wife made a similar comment when I finally came to bed at 3:30am after uploading this early this morning :D.
matt (support)
Post by matt (support) »
Neat plugin – thanks for sharing!
Colorado4Wheeler
Updated today, see original post for release notes, minor typo was fixed.
Londonmark
Post by Londonmark »
I have this working for Weather Underground and it's great, but the device I have created for my Tado thermostat doesn't seem to populate with any values - when I check in Device Details, all the fields are empty. I've switched on debugging, but nothing's showing. Any thoughts?
M
Londonmark
Restarting the server seems to have kicked it into life. Will keep an eye on it and see if it updates.
Colorado4Wheeler
I'll check the plugin, maybe the issue is that the states didn't update after you made changes to the properties. If that is the case it should only fail to update right after a property change, and instead of restarting your server you could restart the LCD Creator plugin itself for the same results.
Return to “LCD Creator”
