Santa Control Page Icons
Chameleon
Post by Chameleon »
Hi all
I've had a couple of requests for the background and icons that I used on the Santa Control Page I uploaded yesterday in txt and zip formats. If you missed the control page templates you can download them here:
Most people seem to have more luck using the zip file and expanding it!
I also used some icons to make the page look pretty.
You can download and unzip these and put them in the following folder:
  • /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebserver/images/controls/static
Finally you can download the night sky background I used from here:
You'll need to download and unzip this file and put the PNG file in the following folder:
  • /Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebserver/images/backgrounds
This image is designed to fit exactly on a iPhone 5S but that's the size that the Control Page Template is designed for anyway. I've found it works just as well on a 4s, 5s, 6, 6Plus and the latest 6s and 6s plus models. It also works ok on my iPad.
Once you've copied the files to the correct locations you can create a Control Page, update the background to Night Sky and then drag the Control Page text file over the top of the page and everything should be displayed. You can then each field to point to your device and add any other graphics (e.g. cookies, cows and carrots) to the page along with the North Pole Symbol.
Hope that helps
Regards
Mike
TOPS
Re: Santa Control Page Icons
Post by TOPS »
:D Excellent work Mike.....
Chameleon
Post by Chameleon »
TOPS wrote::D Excellent work Mike.....
Thanks - my pleasure...
Mike
RogueProeliator
Post by RogueProeliator »
Thanks for that, Mike... my son checked it many times throughout the day! Quote: "Mom has a Santa tracker too, but dad's is cooler!" :)
Return to “iFindStuff”
