olympus
Re: piBeacon presence monitoring plugin discussions
Post by olympus »
I found the pibeacon folder, but piwebserver.log does not exist. I attempted to restart web server #1 and it said communication with the plugin timed out, showing this in the log.
  Error (client)                  timeout waiting for plugin response from com.karlwachs.piBeacon for request UiAction
  Error (client)                  received unexpected packet response UiAction (waiting for GetUiDynamicList)
Dec 11, 2015, 11:00:25 PM
  piBeacon                        web server restarted unsuccessfully, giving up
The dot is on and I can pick it up on my phone.
could you download the new version 0.9.11 and try again?
olympus
Post by olympus »
Definitely. I'll get on that now and report back.
if you still get that error
open terminal and type:
python '/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/piwebserver.py' 10.0.1.2 9931
and post the error message
and set debug level to 1 or any odd number
.. and do a menu/print config (last line) and post (remove your password first)
olympus
Post by olympus »
No luck.
I first tried to restart web server #1 and the same thing happened as before. I then tried pushing the config to it again, but that didn't seem to help. I'm still seeing this in Indigo's log.
This is what I get when running that command.
sh: line 2: /Users/karlwachs/Documents/piBeacon/piwebserver.log: No such file or directory
olympus
Post by olympus »
 pi configuration                debugLevel Indigo            0
  pi configuration                debugLevel Pi                1
  pi configuration                myIp Number                  10.0.1.2
  pi configuration                WiFi key_mgmt                NONE
  pi configuration                WiFi Password
  pi configuration                WiFi SSID
  pi configuration                Router IP                    10.0.1.254
  pi configuration                Seconds UP to DOWN           90.0
  pi configuration                enable FINGSCAN interface    1
  pi configuration                Parameters for each PI
  pi configuration                  # R# IP#          beacon-MAC         port UserID       Password
  pi configuration                  1  0 10.0.1.19                    9931 pi           password
  pi configuration                EXPERT parameters for each PI:
  pi configuration                MaxCall BLE bfsend           300
  pi configuration                ask BLE for x Msgs           3
  pi configuration                colct x secs bf snd          60
  pi configuration                reboot pi after sec          86400
  pi configuration
  pi configuration                defined beacons   indigoName             Status     ignore   LastUp[s] ExpTime -- defined beacons   indigoName             Status     ignore   LastUp[s] ExpTime
  pi configuration                Ignore this family of beacons with the following first 12 characters in their UUID
oops you don't have a directory ...karlwachs.. thats an easy fix.. give me 5
this is in the code:
userName = pwd.getpwuid( os.getuid() )[0]
userName = "karlwachs" <-- this should not be there..
olympus
Post by olympus »
That makes sense. Should I just remove that line?
please download 0.9.12 that should fix the web server error
olympus
Post by olympus »
Awesome. I now have a piwebserver.log and this is it's contents.
2015-12-11 23:27:25 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:27:29 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:27:33 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:27:36 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:27:40 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:27:43 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:27:47 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:27:51 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:27:54 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:27:58 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:29:02 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:29:05 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:29:09 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:29:12 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:29:16 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:29:22 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:29:25 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:29:29 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:29:32 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:29:36 --------   Pi Webserver started  params: 192.168.1.136 9931
2015-12-11 23:30:02 --------   Pi Webserver started  params: 192.168.1.136 9930
2015-12-11 23:30:05 --------   Pi Webserver started  params: 192.168.1.136 9930
My lan is 10.0.1.0.
another oops that my mac ip number .. 5 minutes
self.myIP="192.168.1.136"
olympus
Post by olympus »
No worries at all. I'm impressed with your response time.
Return to “piBeacon”
