Alpha Feedback Post
Chockymonster
Re: Alpha Feedback Post
Post by Chockymonster »
There seems to be something up with using the plugin in action groups.
Here's another one:
Fibaro Light Manager            RGB
  Fibaro Light Manager            Colour of LED StairMood is now Custom
  Fibaro Light Manager Error      Error in plugin execution ExecuteAction:
  File "plugin.py", line 1649, in switchOn
<type 'exceptions.KeyError'>: key colourSelect not found in dict
Chameleon
Post by Chameleon »
Chockymonster wrote:There seems to be something up with using the plugin in action groups.
Here's another one:
I'll retest the Action Groups in the morning... but I'm not sure you're using the latest version 0.2.11. Can you check for me?
Regards
Mike
Chameleon
Post by Chameleon »
Reason is that I removed the 'RGB' bug thins morning and the 1649 line number doesn't tie up with my latest version..
Regards
Mike
Chockymonster
Chameleon wrote:Reason is that I removed the 'RGB' bug thins morning and the 1649 line number doesn't tie up with my latest version..
Regards
Mike
Upgraded and checked again.
  Trigger                         Downstairs going up
  Action Group                    Change Stair colour
  Fibaro Light Manager Error      plugin does not have a <CallbackMethod> specified for action id switchOnLed
No RGB errors this time and the error has changed.
One thing I did notice, when the plugin restarts it changes the light settings.
Started plugin "Fibaro Light Manager 0.2.11"
  Z-Wave                          sent "Haydn's Bed - Red" set brightness to 0
  Z-Wave                          sent "Haydn's Bed - Blue" set brightness to 0
  Z-Wave                          sent "Haydn's Bed - Green" set brightness to 0
  Z-Wave                          sent "Haydn's Bed - White" set brightness to 0
  Z-Wave                          sent "Haydn's bed - Composite" set brightness to 0
  Z-Wave                          sent "025 - Red" set brightness to 99
  Z-Wave                          sent "025 - Green" set brightness to 99
  Z-Wave                          sent "025 - Blue" set brightness to 99
  Z-Wave                          sent "025 - White" set brightness to 0
  Z-Wave                          sent "Stair Mood Light" set brightness to 100
  Z-Wave                          sent "TV - Red" set brightness to 10
  Z-Wave                          sent "TV - Green" set brightness to 0
  Z-Wave                          sent "TV - Blue" set brightness to 10
  Z-Wave                          sent "TV - White" set brightness to 10
  Z-Wave                          sent "TV - Composite" set brightness to 100
Does it need to do that on startup? 2 of the lights were on and this changed their values. Especially the brightness!
yassi
Post by yassi »
No issues so far.
But indeed, it changes the setting when the plugin is restarted.
Best,
Yassi
DaveL17
Post by DaveL17 »
Hi Mike - Here's my experience. When I enable the plugin, it turns the device on and the settings in the Indigo UI appear different than last. When I use the Indigo RGBW Controller to turn the device off--the settings revert to the last setting briefly--and then the device goes off. When I turn the device back on using the Indigo RGBW controller, the settings are as they should be.
For me, it seems, it's the Indigo UI stateValue that's not being updated when the plugin is first enabled. That's less of a concern I think than the LED being turned on when the plugin is first enabled, as on a server restart (after a power loss for example) all the LEDs managed by the plugin would turn on. :D
Cheers,
Dave
My Plugins and Scripts
Chameleon
Post by Chameleon »
DaveL17 wrote:Hi Mike - Here's my experience. When I enable the plugin, it turns the device on and the settings in the Indigo UI appear different than last. When I use the Indigo RGBW Controller to turn the device off--the settings revert to the last setting briefly--and then the device goes off. When I turn the device back on using the Indigo RGBW controller, the settings are as they should be.
Cheers,
Dave
Thanks all. I've listened and I've changed the Startup logic. At the same time I'm improving how the linking works. You'll be able to see links and run a report on your setup.
I'll release after a bit more testing
Mike
yassi
Post by yassi »
Hi Mike,
I still have an issue with my triggers.
I have a trigger, which turns on the LED-Stripe when my ATV1 is playing LiveTV and turns it off when Live-TV is "not true".
See my screenshot, can you find something?
Best,
Yassi
Bildschirmfoto 2015-10-21 um 18.45.35.png (18.17 KiB) Viewed 6074 times
Chameleon
Post by Chameleon »
yassi wrote:Hi Mike,
Best,
Yassi
Yes I know how to fix that. Just let me check something..
Chameleon
Post by Chameleon »
Best,
Yassi
Ok - that's dinner cooking now - sorry for the delay :D
This is caused by the recent updates that I've been doing to allow multiple types of bulbs and led to be controlled by the plugin. Unfortunately, if you have a device that we created before I added this field then Indigo doesn't know about it and claims that it doesn't exist. However, it's easy to fix.
There is a new field on the device. If you edit a device and Edit Device Configuration you'll get a screen like this. You've seen it before except that it now has a new field. This field allows users to add a different type of device than a Fibaro Controller:
New Device Screen
New Device Screen
Screen Shot 2015-10-21 at 18.46.34.png (107.99 KiB) Viewed 6052 times
It's called Multi device RGBW (like Fibaro LED Dimmer) see above. This must be checked to remove the error. If it's already checked I suggest that you uncheck it and recheck it. You could also reselect your preset colour. Then click Save. You'll need to do that with any devices that you created before the last update.
Now your device will have the new field added and the Trigger should work fine :D
If not, and I don't think this is the case, the simplest solution is to delete the device and recreate it (along with your trigger I'm afraid).
I'm fairly confident that the first option will work. Let's me know how it goes. Love the idea of turning the lights on and off when the apple TV comes on - you're a geek just like me :)
Mike
yassi
Post by yassi »
Mike,
no prob, I also, don't have to much time to play with Indigo for now :(
I will double check the settings, I suppose that's the reason, I didn't recreate the device after the last update.
Well, that's one of this first things I've done, when my old ATV1 (which runs XBMC) is playing music or Live-Tv the lights will go down... :D
Best,
Yassi
yassi
Post by yassi »
Hi Mike,
well, I've tried it yesterday (I've disabled an renabled the switch), so far looks good, no errors at all for the moment.
The triggers worked as expected.
I think it's good now.
Thanks a lot for your hint!
Best,
Yassi
Chameleon
Post by Chameleon »
Best,
Yassi
Cool
howartp
Post by howartp »
Mike, per archived thread http://forums.indigodomo.com/viewtopic.php?t=9960 you might get asked about supporting some other bulbs. The python code is on that thread if it's a possibility.
Chameleon
Post by Chameleon »
howartp wrote:Mike, per archived thread http://forums.indigodomo.com/viewtopic.php?t=9960 you might get asked about supporting some other bulbs. The python code is on that thread if it's a possibility.
Thanks - I'll review it. I hate reinventing the wheel :D
Mike
