deviceEnteredGeo=Home
deviceGeoDistance=4.84
deviceInGeoRange=true
distanceHome=4.84
geoDistanceDisplay=4 ml and 4423 ft
geoHomeDistanceDisplay=4 ml and 4423 ft
realDistanceHome=4 ml and 5126 ft
distanceHome=4.84
Thanks Jasonsnowjay wrote:I have my units set to Imperial and according to the manual the "Range of GeoFence" value should be set to feet. I entered in 500 and have a device well outside that range (see below) but it still indicates that it is within the GeoFence. Just wondering if the distance is really miles or there is something else going on here.
deviceEnteredGeo=Home deviceGeoDistance=4.84 deviceInGeoRange=true distanceHome=4.84 geoDistanceDisplay=4 ml and 4423 ft geoHomeDistanceDisplay=4 ml and 4423 ft realDistanceHome=4 ml and 5126 ft
deviceGeoDistance=45220.27
distanceHome=8.56
geoDistanceDisplay=8 ml and 2980 ft
geoHomeDistanceDisplay=8 ml and 2980 ft
I am having similar issues. Geo range set to 275 (I don't know if meters or feet??) and I am several miles away, it still shows me as being in range. Maybe this is just a bug with those of us using imperial units?snowjay wrote:I'm not sure it's calculating correctly or I have something set wrong.
I set my GeoFence to 26400 feet (5 miles)
I have a device reporting over 8 miles away, yet it still says it's within the GeoFence.
Details:Code: Select all
deviceGeoDistance=45220.27 deviceInGeoRange=true distanceHome=8.56 geoDistanceDisplay=8 ml and 2980 ft geoHomeDistanceDisplay=8 ml and 2980 ft
Thanks for the messages. You're probably right. I'm currently completing a full analysis of distance calculations today so I should have a release for all of you later on.snowjay wrote:It looks like the GeoFence distance # is in meters even though Imperial is selected. I looked at the GeoFence outline on the dynamic map and it was way bigger than 5 miles. I cut it down to 10000 and it created a fence of about 6 miles which is more accurate. Devices still show in the fence though.
Edit: if I change the units to meters it looks like everything is working fine now.
New version now available that works with Metric, Imperial and Metressnowjay wrote:No worries Mike, thanks for your work on this plugin! I don't mind using meters for now, I'm used to the metric system on my bikes anyway.
Can't wait to check out the new plugin as well.
Jason
Hi DaveTOPS wrote:Hi Mike,
Great work as ever, where do I find the new version,
Dave
I'll run a few tests. However it should work fine I've not had any reported issues for a while on this. There are somethings that you could eliminate for me:dnomode wrote:Hello Mike,
I'm seeing the same problem. I'm set to Imperial and the Range of the Geolocation is set to 500. I was several miles away and the system reported me at home. I'm on version 1.02.03
Any ideas?
Thanks for your help?
Edmond
60 secondsa) What is the current reporting period (value of the secondsNextUpdate) state for the device. It can be as long as an hour if the battery is low.
I only installed the plugin 1 week ago and it always shows my wife and I at home.b) Is it always the same problem? Sometimes the Apple API isn't as proactive as we'd like and can take a while to give us a new location
I switched to metric this morning and switched back this evening. I'll see tomorrow if it helps. The range seemed to switch from 500 ft to 29 meters when switching to metric (i thinkc) Can you convert to Metric (in the iFindStuff Configuration) - allow it to run for 30 mins and then revert back to imperial? Occasionally in the early days of experimentation with the plugin these numbers can get confused and this should remove any rogue data. When you complete the changes, in each case have a look at the range for the GeoFence (edit the device) and see if the changes it's made are sensible- i.e. is the conversion correct.
