[SOLVED]: ZIPATO - Bulb LED RGBW Z-Wave
Discuss how Indigo and Z-Wave work together. If you have a Z-Wave device that's not listed in the Home Automation Hardware forum or in the supported devices web app, report it here.
matt (support)
Re: [SOLVED]: ZIPATO - Bulb LED RGBW Z-Wave
Post by matt (support) »
Define/Sync it then copy/paste the Event Log results into a reply post for us.
opbzil
Post by opbzil »
thanks for the creply Matt,
Here you go.
This is the log from the moment I disconnected by z-stick to the moment I included my new light bulb.
2015-01-29 17:43:44.258 Z-Wave Error serial port communication error: read failed: [Errno 6] Device not configured
2015-01-29 17:43:44.259 Z-Wave Error Z-Stick S2 might be disconnected
2015-01-29 17:43:44.259 Z-Wave Error silently retrying serial connection every 5.0 seconds
2015-01-29 17:43:47.655 Interface Failure lost connection with interface
2015-01-29 17:52:40.002 Z-Wave connected to Z-Stick S2 interface on /dev/cu.SLAB_USBtoUART (firmware 3.07)
2015-01-29 17:52:40.117 Z-Wave found module included in controller with no matching device (missing or disabled): 004 - Dimmable Power Switch
2015-01-29 17:53:03.918 Z-Wave received "002 - Kitchen Motion Sensor" status update is off
2015-01-29 17:53:27.220 Z-Wave received "002 - Kitchen Motion Sensor" status update is on
2015-01-29 17:53:58.445 Z-Wave received "002 - Kitchen Motion Sensor" status update is off
2015-01-29 17:54:10.688 Z-Wave Syncing - started for device "004 - Dimmable Power Switch"
2015-01-29 17:54:10.707 Z-Wave Syncing - retrieved module neighbors list: 1
2015-01-29 17:54:10.708 Z-Wave Syncing - requesting neighbor list update of "004 - Dimmable Power Switch"
2015-01-29 17:54:11.111 Z-Wave Syncing - neighbor list update complete (no change)
2015-01-29 17:54:11.112 Z-Wave Syncing - assigning return route to "004 - Dimmable Power Switch"
2015-01-29 17:54:11.244 Z-Wave Syncing - assigned return route
2015-01-29 17:54:12.825 Z-Wave Syncing - retrieved manufacture and model names: Zipato - 0131, RGBW LED Bulb - 00020002
2015-01-29 17:54:12.952 Z-Wave Syncing - retrieved protocol version 3.92, app version 1.06
2015-01-29 17:54:13.080 Z-Wave Syncing - retrieved class hierarchy: Routing Slave : Mulitlevel Switch : Dimmable Power Switch (04 : 11 : 01, base 26)
2015-01-29 17:54:13.083 Z-Wave Syncing - retrieved command classes: 20v1 73v1 85v1 86v1 27v1 70v1 72v1 33v1 59v1 5Av1 26v2 7Av1 5Ev1
2015-01-29 17:54:13.336 Z-Wave Syncing - retrieved group 1 associations: []
2015-01-29 17:54:13.467 Z-Wave Syncing - added group 1 association to interface
2015-01-29 17:54:13.598 Z-Wave Syncing - retrieved parameter 1 "Color temperature" is 50
2015-01-29 17:54:13.725 Z-Wave Syncing - retrieved parameter 2 "Inclusion mode tapping sensitivity" is 16
2015-01-29 17:54:14.028 Z-Wave Syncing - created device "004 - RGBW LED Bulb"
2015-01-29 17:54:14.052 Z-Wave Syncing - complete
2015-01-29 17:54:14.183 Z-Wave sent "004 - RGBW LED Bulb" status request
2015-01-29 17:54:58.323 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:55:07.463 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 95
2015-01-29 17:55:12.634 Z-Wave sent "004 - RGBW LED in top floor" off
2015-01-29 17:55:16.230 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:55:20.941 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 56
2015-01-29 17:56:53.277 Z-Wave device "004 - RGBW LED in top floor" parameter 1 "Color temperature" changed to 70
2015-01-29 17:56:58.611 Z-Wave sent "004 - RGBW LED in top floor" off
2015-01-29 17:57:01.417 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:57:08.384 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 89
2015-01-29 17:57:15.144 Z-Wave sent "004 - RGBW LED in top floor" status request
2015-01-29 17:57:41.949 WebServer Indigo Touch client connected from 192.168.1.2
2015-01-29 17:57:46.669 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 41
2015-01-29 17:57:50.007 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:58:33.904 Z-Wave received "002 - Kitchen Motion Sensor" status update battery level 100%
2015-01-29 17:58:48.973 Z-Wave sent "004 - RGBW LED in top floor" off
2015-01-29 17:58:51.296 Z-Wave sent "004 - RGBW LED in top floor" off
2015-01-29 17:58:51.927 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:58:53.411 Z-Wave sent "004 - RGBW LED in top floor" off
2015-01-29 17:58:59.380 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:59:01.658 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 100
2015-01-29 17:59:05.683 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 22
2015-01-29 17:59:07.208 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:59:08.679 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 17:59:16.554 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 96
2015-01-29 17:59:21.257 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 46
2015-01-29 17:59:22.230 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 26
2015-01-29 17:59:24.921 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 11
2015-01-29 17:59:24.959 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 0
2015-01-29 17:59:29.009 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 10
2015-01-29 17:59:53.025 WebServer Indigo Touch client connected from 192.168.1.2
2015-01-29 18:01:30.036 Z-Wave received "002 - Kitchen Motion Sensor" status update is on
2015-01-29 18:08:37.628 Z-Wave received "002 - Kitchen Motion Sensor" status update is off
2015-01-29 18:08:40.142 Z-Wave received "002 - Kitchen Motion Sensor" status update is on
2015-01-29 18:12:38.776 Z-Wave received "002 - Kitchen Motion Sensor" status update is off
2015-01-29 18:12:52.962 Z-Wave received "002 - Kitchen Motion Sensor" status update is on
2015-01-29 18:13:24.189 Z-Wave received "002 - Kitchen Motion Sensor" status update is off
2015-01-29 18:13:43.736 Z-Wave received "002 - Kitchen Motion Sensor" status update is on
2015-01-29 18:14:28.155 Z-Wave sent "004 - RGBW LED in top floor" off
2015-01-29 18:14:37.849 Z-Wave sent "004 - RGBW LED in top floor" set brightness to 37
2015-01-29 18:14:39.531 Z-Wave sent "004 - RGBW LED in top floor" on
2015-01-29 18:14:39.876 WebServer Indigo Touch client connected from 192.168.1.2
matt (support)
I believe they changed the firmware on the device and it no longer presents itself (to Indigo) as 2 endpoints/devices.
In the Actions panel UI (Action Group, Trigger, Schedule or Control Page control) have you tried choosing the Type Z-Wave Actions->Set RGB Levels? We need to add a native control to Indigo's main window (and Indigo Touch) so that one can more easily specify a color...
opbzil
Post by opbzil »
thanks!! That did it! It shows up as a pro action though.
So I guess for those that plan to get only Indigo Lite this Zipato RGBW light bulb will only work as a regular light bulb..
I was able to change colours using the SET RGB Levels. Its working nicely now..
just need to play with it now.
as a note the white level seems to overwhelm all others...
DeltaMike1200
ZIPATO - Bulb LED RGBW Z-Wave, set using python
Post by DeltaMike1200 »
Hello,
I have two zipato RGBW led bulbs in my home, they work perfectly.
Now I'm using a action set rgb value to modify there colour.
However I like to set the colour in a Python script because the colour values are stored in variables.
Is this possible in Python ?
haavarda
Post by haavarda »
Are you setting the bulb from variable values today? If that is the case. How do you do that?
Håvard
DeltaMike1200
At this moment I don't know how to use variables, that's the problem.
I have a some Fibaro RGBW modules in my home, with inspiration
found on this forum I've made a Python script to modify the colours at
the same time. The values for the rgb colours are stored in variables.
If I can set the values of the zipato rgbw bulbs I can sync them with
the Fibaro modules, this would be very nice. But my knowledge
of Python is very limited.
haavarda
Post by haavarda »
Yes that would be perfect. Than you can trigger the script on variable change...
There are several Python experts on this forum. Lets hope someone can help with this.
Håvard
DaveL17
Post by DaveL17 »
I'm limited in what I can do from my mobile, but have a look at this thread:
http://forums.indigodomo.com/viewtopic. ... 869#p87855
In particular, how Matt suggests sending a payload to the Fibaro. I can't recall if I had to modify it at all--I don't think I did. You could then take the value from the variables and ship them to the Fib.
If it were me, I'd bypass the variables entirely and put the code in a trigger. When ever the "parent" device changes, change the "children" to match.
Dave
My Plugins and Scripts
DeltaMike1200
The fibaro RGBW control in Python script works, I have five of Fibaro rgb units in use and they
sync there colours perfect.
However I want to do the same with the ZIPATO rgb led bulb and sync the colour to the Fibaro rgb led strips.
Do do this I need to set the rgb values from the Zipato bulb according the variables I created.
I cannot locate the Id numbers of the set rgb levels of the Zipato bulb and therefore cannot use them in Python.
DaveL17
Post by DaveL17 »
Oh, I had it backwards. :D
Perhaps Matt can chime in with the raw commands for the Zipatos.
haavarda
Post by haavarda »
Assuming that the Zipato uses the same command class as the fibaro, I started to play with the code Matt provided as Dave suggested.
And on my Zipato RGBW bulb the raw command 0x33, 0x05, 0x02, 0x02, 0x64 is working for setting the red bulb to 100 red. The script below should then also work, but I have not tested it yet.
payload = [0x33, 0x05, 0x02, 0x02, 0x64]    # Set red to 100
zwavePlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.zwave")
zwavePlugin.executeAction("sendRawZwaveCommand", deviceId=dev.id, props={'payload':payload})
Håvard
DeltaMike1200
Hello Havaarda,
Nice of you to react to the problem.
I've just copied your code into an python action and put the device Id in it.
The code looks like this:
zwavePlugin.executeAction("sendRawZwaveCommand", deviceId=619579665, props={'payload':payload})
No errors and below you can see the log entry
Z-Wave sent "Living_Zipato_RGBW_1" raw command: [33 05 02 02 64]
However nothing happens with the zipato led bulb :(
haavarda
Post by haavarda »
You have to control the brightness of the bulb as well.
Try that and see how it reacts. The script is working on my system.
Håvard
krissh
Post by krissh »
I can't seem to make much sense of this light bulb in Indigo 7.
I have two devices that looks like this
Skjermbilde 2016-11-21 kl. 21.45.27.png (43.65 KiB) Viewed 4707 times
Skjermbilde 2016-11-21 kl. 21.46.03.png (38.41 KiB) Viewed 4707 times
The one called "varm" used to be warm color, turning this on now seems to give "cold white" color.
The only way I found to set the color, is to turn both devices off, then set the color in the UI, from the log:
  Z-Wave                          sent "Zipato lyspaere" off
   Z-Wave                          sent "Zipato lyspaere" set color to 84 42 7, -- --
Both devices are then off in Indigo, but the light bulb has color with low brightness. I can then turn on the device "Zipato lyspaere" and the state is updated in Indigo, nothing happens with the light bulb.
From what I understand the top brightness is "general brightness", the middle brightness (W) is "warm white brightness" and the lower one (W2) is "cold white brightness".
Changing the W brightness will reset the colors:
   Z-Wave                          sent "Zipato lyspaere" set color to -- -- --, 100 --
If the light bulb is off, I turn it on and then try to change the color only minor changes to the light happens, but it remains white
   Z-Wave                          sent "Zipato lyspaere" set color to 38 98 4, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 42 98 52, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 7 98 74, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 25 79 98, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 98 55 74, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 98 58 27, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 56 98 14, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 35 98 16, -- --
   Z-Wave                          sent "Zipato lyspaere" set color to 9 13 98, -- --
I also have some trouble finding a reliable way to set colors and back to warm white with actions.
There is probably something I'm missing here, so some tips would be appreciated :)
Return to “Z-Wave”
