So I bought a couple Nonda Aiko beacons. But when I charge them up, they dont show up as devices on my Indigo piBeacon folder. So I thought I need to update perhaps to the latest plugin. I did that and my Event log shows:
Starting plugin "piBeacon 7.100.269" (pid 36020)
Started plugin "piBeacon 7.100.269"
piBeacon initializing ...
piBeacon path To files: =================
piBeacon indigo /Library/Application Support/Perceptive Automation/
piBeacon installFolder /Library/Application Support/Perceptive Automation/Indigo 7/
piBeacon plugin.py /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon-2.indigoPlugin/Contents/Server Plugin/
piBeacon Plugin params /Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.karlwachs.piBeacon/
piBeacon PluginLogFile /Library/Application Support/Perceptive Automation/Indigo 7/Logs/com.karlwachs.piBeacon/plugin.log
piBeacon Plugin short Name piBeacon
piBeacon my PID 36020
piBeacon Critical Error --------------------------------------------------------------------------------------------------------------
piBeacon Critical Error The pluginName is not correct, please reinstall or rename
piBeacon Critical Error It should be /Libray/....../Plugins/piBeacon.indigoPlugin
piBeacon Critical Error It is: /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon-2.indigoPlugin
piBeacon Critical Error please check your download folder, delete old *.indigoPlugin files or this will happen again during next update
piBeacon Critical Error ---------------------------------------------------------------------------------------------------------------
File "plugin.py", line 8619, in runConcurrentThread
File "plugin.py", line 8639, in dorunConcurrentThread
File "plugin.py", line 8424, in initConcurrentThread
AttributeError: 'Plugin' object has no attribute 'indigoInputPORT'
piBeacon Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
piBeacon Error in Line '2493' has error='[Errno 2] No such file or directory: u'/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/Plugins/com.karlwachs.piBeacon/dataVersion''
piBeacon Error Error in plugin execution runConcurrentThread:
I have reloaded the plugin and now piBeacon does not work. No beacons deteected:
Log shows this:
an 27, 2019 at 2:54:51 PM
v7.100.269 of plugin piBeacon is already installed but is disabled (enabling)
Loading plugin "piBeacon 7.100.269"
Starting plugin "piBeacon 7.100.269" (pid 40388)
piBeacon plugin.py /Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/
piBeacon my PID 40388
piBeacon myLogSet setting parameters -- logFileActive= standard; logFile= ; debugLevel= []
piBeacon testing if variable enableTimeTracking_piBeacon is == on/off/print-option to enable/end/print time tracking of all functions and methods (option:'',calls,cumtime,pcalls,time)
piBeacon --V 7.100.269 initializing --
piBeacon starting UpdateRPIqueues
piBeacon .. config read from files
piBeacon .. def startup(self): setting variables, debug .. finished
piBeacon .. starting tcpip stack
piBeacon .. tcpip stack started
piBeacon .. checking sensors
piBeacon .. checking devices tables
piBeacon .. checking BLEconnect
piBeacon .. checking beacons
piBeacon .. initalized, starting loop
Jan 27, 2019 at 2:57:16 PM
piBeacon return code from fix ("spawn sftp -o ConnectTimeout=15 [email protected]\r\[email protected]'s password: \r\nPermission denied, please try again.\r\r\[email protected]'s password: \r\nPermission denied, please try again.\r\r\[email protected]'s password: \r\nAuthentication failed.\r\r\nConnection closed\r\r\n", 'expect: spawn id exp9 not open\n while executing\n"expect "sftp" { send "quit\\r" }"\n (file "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/piBeacon.indigoPlugin/Contents/Server Plugin/updateParamsFTP.exp" line 50)\r\n') trying again to configure PI
And Beacon status in Indigo shows IPconnection and BLE down
