So I made a try to update and I have this :
Stopping plugin "Hue Lights" (pid 10967)
Stopped plugin "Hue Lights"
Upgrading plugin "Hue Lights" to newer version 0.10.1 (previous version moved to trash)
Loading plugin "Hue Lights 0.10.1"
Starting plugin "Hue Lights 0.10.1" (pid 20638)
Started plugin "Hue Lights 0.10.1"
Hue Lights Loaded 8 bulb(s)
Hue Lights Error exception in deviceStartComm(HUE 4 Cuisine): 'xy'
Hue Lights Error exception in deviceStartComm(HUE 5 Hall): 'xy'
Hue Lights Error exception in deviceStartComm(HUE 6 Entree): 'xy'
Hue Lights Error exception in deviceStartComm(HUE 7 SdB Bas): 'xy'
Hue Lights Error exception in deviceStartComm(HUE 8 SdB Haut): 'xy'
Hue Lights Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 309, in runConcurrentThread
File "plugin.py", line 897, in getBulbStatus
<type 'exceptions.KeyError'>: 'xy'
Hue Lights Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
24 juin 2013 19:37:00
Schedule Compteur Placards
I'm using 6.0.0 b7 so I was after b2, and had the problem with ASCII...
1, 2, 3 are HUE, others are Living White, 4 & 5 with probably the model 001 and the 6, 7 & 8 with the new device model 003.
Hope this help.
EDIT : I installed beta 10, but it's the same errors :
24 juin 2013 19:46:56
Emails on POP server mail.. will be scanned every 3 minutes
24 juin 2013 19:46:57
Trigger Startup Indigo
Connected to USB ActiveHome Interface
CM15 firmware version 2
CM15 disabled internal RF to power line relaying
Indigo Cocoa client authenticated (192.168.19.31)
Trigger Démarrage : Dialectic
Error (client) IDNotUniqueError
Trigger Démarrage : Broadcast
Sent X10 all units off (house code I)
Sent X10 "Salle de bain" off
