Better Email plugin discussion thread
Re: Better Email plugin discussion thread
Different Computers wrote:I know where you're coming from and appreciate the concern. It's just I've got some legacy zigbee devices that I can't get talking to Indigo, and it would be nice to use them. (Until someone writes a Zigbee plugin of course. :wink:
Let's take this to another thread: http://forums.indigodomo.com/viewtopic. ... 36&t=16225
Gah. That's what I get for making a "simple" change without testing. Try v1.2.8.
Bollar
Post by Bollar »
FlyingDiver wrote:Gah. That's what I get for making a "simple" change without testing. Try v1.2.8.
That appears to have worked - thanks!
Version number is still showing as 1.2.6
Bollar wrote:Version number is still showing as 1.2.6
Fixed. I think.
peteinau
Post by peteinau »
Hi Joe,
Mine seems to work well for a while (usually more than a day, but not a time period I can work out) and then I see the following message in the log
Better Email Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 673, in runConcurrentThread
KeyError: 'key updateFrequency not found in dict'
Better Email Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
If I then go to the configure menu for the plugin and try and try debugging on I get the following message in the log
Better Email Error Error in plugin execution UiValidate:
File "plugin.py", line 567, in validatePrefsConfigUi
NameError: global name 'errorMsgDict' is not defined
I can use the toggle debugging but it doesn't seem to give me any more information than this.
Pete
Sigh. v1.2.9 is up now. I hope I finally stomped that bug.
Different Computers
Post by Different Computers »
I'm full of dumb questions today.
If I'm looking for the plugin to trigger on a subject equal to
Front door open
can the regular expression in the settings just be
Front door open
Yes. If you don't use any of the special regex meta characters, then it's a straight string compare. I probably ought to put in a simple string compare option, since you'll get bitten by punctuation characters.
Be aware that there's currently a bug that messages with no message text (just headers) will fail. I need to look into that.
Different Computers
FlyingDiver wrote:Be aware that there's currently a bug that messages with no message text (just headers) will fail. I need to look into that.
Aaaaand that's my problem! I was sending blank messages.
V1.2.10 has been posted.
In this release:
Events are now specific to an email server. All events (triggers) will need to be edited to select the server.
There are now two kinds of inbound email matching triggers - one for regex expressions, one for plain string matches. All events (triggers) will need to be edited to select the event type.
Misc bug fixes as well, including a work-around for empty email bodies.
peteinau
Post by peteinau »
Hi Joe,
Getting the following messages since upgrading to 1.2.10:
Better Email Error IMAP server connection error: 'key serverID not found in dict'
I've tried deleting and recreating the Server Device, but doesn't seem to change it much.
Pete
peteinau wrote:Hi Joe,
Pete
Did you edit and save all your BetterEmail Events (ie Triggers)?
peteinau
Post by peteinau »
Ahhh... tried hunting around and found a trigger I'd missed! I think I'll need to redo all my folder structure, just too many triggers and devices in Indigo these days.
peteinau wrote:Ahhh... tried hunting around and found a trigger I'd missed! I think I'll need to redo all my folder structure, just too many triggers and devices in Indigo these days.
I'm going to see if I can find a way to protect the code from that error. Put in some defaults of some sort if the keys are missing.
RedYuriPrime
Post by RedYuriPrime »
Hi Joe,
I am having problems getting the plugin to work after upgrading to v1.2.10. Outgoing email works fine, but incoming does not. Problem seems to be at the level of the incoming device, so deleted this and started again, but problem unchanged.
Error shows up as state ‘Failure’ in the devices list, and as a line in the log everytime Better Email executes saying:
"Better Email Error POP server connection error: 'POPServer' object has no attribute 'props' "
With debugging set get nothing more useful:
"Better Email Debug Connecting to POP Server: Better Email Incoming Pop Server
Better Email Error POP server connection error: 'POPServer' object has no attribute 'props'"
Any suggestions :?:
Z-wave system with 80+ devices, Indigo7 on a dedicated MacMini
Controlling lighting, heating, hotwater, security; but still a lot to learn ... :shock:
Locked
Return to “Better Email”
