- Updated supported device list by moving it into a separate Python file for easier maintenance
- Added support for the Hue White A19 extension bulb.
Hue Lights - Free Philips Hue Plugin
Re: Hue Lights - Free Philips Hue Plugin
Version 1.3.15 Posted
Version 1.3.16 Posted
- Added support for the Phoenix wall light.
Version 1.3.17 Posted
- Updated Phoenix support so it appears in the LivingWhites device list instead of the color Hue bulbs list.
Version 1.3.18 Posted
- Fixed incompatibility with Indigo 6.1.8 that caused every HTTP connection to the Hue hub to generate a "Starting new HTTP connection (1)..." entry in the Indigo log.
Version 1.3.19 Posted
- Added support for new Phoenix light model.
Version 1.3.20 Posted
- Fixed the pairing process to work with hub firmware versions released on or after April 2016.
- Simplified hub pairing process (much less complicated now).
- Improved plugin configuration window error checking.
Version 1.3.21 Posted
- Added support for the Osram Lightify CLA60 Tunable White bulb.
Version 1.3.22 Posted
- Fixed error when attempting to obtain device status from Osram CLA60 lights. Light now appears as a Living Whites bulb.
- Improved light status gathering method to prevent plugin crashes if a light device doesn't have an expected property.
Version 1.3.23 Posted
- Added ability to use an Indigo variable for the ramp rate in all actions that have a ramp rate parameter.
- Added ability to use Indigo variables and other Indigo dimmers as the brightness source in actions that have a 0 to 100 percent scale brightness parameter (i.e. the "Set Hue/Saturation/Brightness" and "Set Color Temperature" actions. The "Set Brightness with Ramp Rate" action already had this capability).
- Added ability to use an Indigo variable for color temperature in the "Set Color Temperature" action.
Version 1.3.24 Posted
- Fixed a bug that caused the plugin to hang then crash after adding a Hue Group device.
Version 1.3.25 Posted
- Added support for 2 Hue White Ambiance bulb models.
- Fixed bug that caused the plugin to crash if a light had no color information from the Hue hub.
Version 1.3.26 Posted
- Actually added the 2nd Hue White Ambiance model ID this time.
Version 1.3.27 Posted
- Fixed (hopefully) a bug that caused the plugin to crash when updating a bulb that doesn’t support the hue/saturation feature.
Version 1.3.28 Posted
- Added support for the Hue bulb v3, Hue White v2 and Hue White v3.
Version 1.3.29 Posted
- Added support for additional Hue light models.
