Hey, glad that worked for you.obyone wrote:Dave you are a star. It worked perfectly.
Thanks very much.
Now to install the remaining 10 Nest thermostats and get them set up
That's a metric ton of thermostats!
Thanks very much.
def actionControlThermostat(self, action, dev):
###### SET HVAC MODE ######
if action.thermostatAction == indigo.kThermostatAction.SetHvacMode:
self.handleChangeHvacModeAction(dev, action.actionMode)
###### SET FAN MODE ######
# elif action.thermostatAction == indigo.kThermostatAction.SetFanMode:
# self.handleChangeFanModeAction(dev, action.actionMode)
Yet Another Nest Thermostat Plugin Obtaining the latest values from NEST.com
Yet Another Nest Thermostat Plugin Error Trouble connecting to the NEST proxy, restarting it.
Yet Another Nest Thermostat Plugin stopping NEST listener thread...
Yet Another Nest Thermostat Plugin launching NEST listener thread and Nest.com proxy...
Yet Another Nest Thermostat Plugin Invalid message:
Yet Another Nest Thermostat Plugin Invalid message: ntents/Server Plugin/nest_api.js:185
Yet Another Nest Thermostat Plugin Invalid message: ion.urls.transport_url.hostname,
Yet Another Nest Thermostat Plugin Invalid message: ^
Yet Another Nest Thermostat Plugin Invalid message: TypeError: Cannot read property 'transport_url' of undefined
Yet Another Nest Thermostat Plugin Invalid message: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Co host:nestSess at nestGet (/Library/Appliclugin/nest_api.js:185:34)
Yet Another Nest Thermostat Plugin Invalid message: ation Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server P at Object.fetchCurrenNestPlugin.indigoPlugin/Contentjs:223:9)
Yet Another Nest Thermostat Plugin Invalid message: est (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugjs:86:7)
Yet Another Nest Thermostat Plugin Invalid message: )
Yet Another Nest Thermostat Plugin Invalid message: tStatus [as fetchStatus] (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Indigos/Server Plugin/nest_api. at Server.processIndigoRequin/Contents/Server Plugin/nest_monitor. at Server.EventEmitter.emit (events.js:98:17 at HTTPParser.parser.onIncoming (http.js:2108:12)
Yet Another Nest Thermostat Plugin Invalid message: at HTTPParser.parserOnHeadersComplete [as onHeadersComplete] (http.js:121:23)
Yet Another Nest Thermostat Plugin Invalid message: at TCP.onread (net.js:527:27)
Yet Another Nest Thermostat Plugin Invalid message: at Socket.socket.ondata (http.js:1966:22)
I often get the same Invalid Message output as Cheezmo does. For me I think it goes back further than Yosemite. When it happens the indigo plugin host process zooms up to 100% cpu usage and sits there (I can always tell because the fans kick in to overdrive). Then I just have to restart the plugin and it calms down.Cheezmo wrote:Hmm, not looking good today though...
Another Nest Thermostat Plugin About to request: http://127.0.0.1:13243/?deviceSerial=XX ... Value=22.2
Yet Another Nest Thermostat Plugin sent "Nest thermostaat" increase heat setpoint to 22.2
Yet Another Nest Thermostat Plugin ** Set target_temperature
01 Nov 2014 12:16:29
Reloading plugin "Yet Another Nest Thermostat Plugin 1.1.2"
Stopping plugin "Yet Another Nest Thermostat Plugin 1.1.2" (pid 67677)
Stopped plugin "Yet Another Nest Thermostat Plugin 1.1.2"
Starting plugin "Yet Another Nest Thermostat Plugin 1.1.2" (pid 67751)
Started plugin "Yet Another Nest Thermostat Plugin 1.1.2"
Yet Another Nest Thermostat Plugin ** NEST Proxy Server has started on Port 13243
Yet Another Nest Thermostat Plugin About to request: http://127.0.0.1:13243/?deviceSerial=XX ... tyName=all
Yet Another Nest Thermostat Plugin DEBUG: Finished deviceStartComm sucessfully
Yet Another Nest Thermostat Plugin /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_api.js:185
Yet Another Nest Thermostat Plugin Invalid message: /Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_api.js:185
Yet Another Nest Thermostat Plugin host:nestSession.urls.transport_url.hostname,
Yet Another Nest Thermostat Plugin Invalid message: host:nestSession.urls.transport_url.hostname,
Yet Another Nest Thermostat Plugin ^
Yet Another Nest Thermostat Plugin TypeError: Cannot read property 'transport_url' of undefined
Yet Another Nest Thermostat Plugin at nestGet (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_api.js:185:34)
Yet Another Nest Thermostat Plugin Invalid message: at nestGet (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_api.js:185:34)
Yet Another Nest Thermostat Plugin at Object.fetchCurrentStatus [as fetchStatus] (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_api.js:223:9)
Yet Another Nest Thermostat Plugin Invalid message: at Object.fetchCurrentStatus [as fetchStatus] (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_api.js:223:9)
Yet Another Nest Thermostat Plugin at Server.processIndigoRequest (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_monitor.js:86:7)
Yet Another Nest Thermostat Plugin Invalid message: at Server.processIndigoRequest (/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/IndigoNestPlugin.indigoPlugin/Contents/Server Plugin/nest_monitor.js:86:7)
Yet Another Nest Thermostat Plugin at Server.EventEmitter.emit (events.js:98:17)
Yet Another Nest Thermostat Plugin Invalid message: at Server.EventEmitter.emit (events.js:98:17)
Yet Another Nest Thermostat Plugin at HTTPParser.parser.onIncoming (http.js12)
Yet Another Nest Thermostat Plugin Invalid message: at HTTPParser.parser.onIncoming (http.js12)
Yet Another Nest Thermostat Plugin at HTTPParser.parserOnHeadersComplete [as onHeadersComplete] (http.js:121:23)
Yet Another Nest Thermostat Plugin at Socket.socket.ondata (http.js22)
Yet Another Nest Thermostat Plugin Invalid message: at Socket.socket.ondata (http.js22)
Yet Another Nest Thermostat Plugin at TCP.onread (net.js:527:27)
