Having an issue with the volume of the announcements.
const fs = require("fs");
let Alexa = require('alexa-remote2');
let alexa = new Alexa();
// Default speech settings for creating SSML
// Amazon's SSML Reference: https://developer.amazon.com/docs/custom-skills/speech-synthesis-markup-language-ssml-reference.html
var defaultVoice = "Amy";
var defaultLang = "en-US";
// see: https://www.gehrig.info/alexa/Alexa.html
// cookie starts with x-amzn-dat and ends with =" csrf=12345780
let cookie = {};
var cookieFile = "/Users/TV/Desktop/Alexa/my-cookie.json";
var deviceFile = "/Users/TV/Desktop/Alexa/my-devices.json";
// Load last cookie from file
if (fs.existsSync(cookieFile)) cookie = JSON.parse(fs.readFileSync(cookieFile));
alexa.init({
cookie: cookie, // cookie if already known, else can be generated using email/password
email: '...', // optional, amazon email for login to get new cookie
password: '...', // optional, amazon password for login to get new cookie
proxyOnly: true,
proxyOwnIp: 'localhost',
proxyPort: 3001,
proxyLogLevel: 'info',
bluetooth: true,
logger: console.log, // optional
alexaServiceHost: 'pitangui.amazon.com', // optional, e.g. "pitangui.amazon.com" for amazon.com, default is "layla.amazon.de"
//userAgent: '...', // optional, override used user-Agent for all Requests and Cookie determination
acceptLanguage: 'en-US', // optional, override Accept-Language-Header for cookie determination
amazonPage: 'amazon.com', // optional, override Amazon-Login-Page for cookie determination and referer for requests
useWsMqtt: true, // optional, true to use the Websocket/MQTT direct push connection
cookieRefreshInterval: 7*24*60*1000 // optional, cookie refresh intervall, set to 0 to disable refresh
function (err) {
if (err) {
console.log(err);
return;
argCommand = ''
argDetail = ''
argDevice = ''
console.log('>>>>START<<<<<')
for (let j = 0; j < process.argv.length; j++) {
if (j == 2) {
argCommand = process.argv[j]
if (j == 3) {
argDetail = process.argv[j]
if (j == 4) {
argDevice = process.argv[j]
console.log(j + ' -> ' + (process.argv[j]));
console.log('>>>>END<<<<<')
// Save cookie to file so it can be used next time, as long as it is still valid.
saveCookie();
if (argCommand !== '') {
if (argDetail !== '') {
if (argDevice !== '') {
sendCommand(argCommand, argDetail, [argDevice]);
} else {
sendCommand(argCommand, argDetail)
// Change the sendCommand call below to send a command to one or more of your Alexa devices.
//sendCommand("ssml", "This is an english test from Indigo.");
// Here are a few other example calls.
//sendCommand("speak", "This is a test to one device only.", ["Study Echo Dot"]);
//sendCommand("singasong", "", "SERIALNUMBER");
//sendCommand("weather", "", "Family Room");
//Send custom SSML string
let customSSML = "<speak>" +
"<lang xml:lang='en-UK'>" +
"<say-as interpret-as='interjection'>hiya. guess what.</say-as>" +
"I wanna tell you a secret" +
"<break time='500ms'/>" +
"<amazon:effect name='whispered'>I can see your browser history.</amazon:effect>" +
"<break time='1s'/>" +
"<say-as interpret-as='interjection'>schwing. oh my.</say-as>" +
"<break time='1500ms'/>" +
"<say-as interpret-as='interjection'>ha ha. gotcha.</say-as>." +
'</lang>' +
'</speak>';
sendCommand("ssml", customSSML, ["Study Echo Dot"]);
// Pause so the command has a chance to be sent. Then exit.
setTimeout(function(){
process.exit();
},5000);
function saveCookie() {
// Save cookie (and device data for reference).
console.log("Saving cookie to file: " + cookieFile);
try {
// Save device data
fs.writeFileSync(deviceFile, JSON.stringify(alexa.serialNumbers, null,4));
// Save cookie
if (alexa.cookieData) {
if (alexa.cookieData.csrf) {
fs.writeFileSync(cookieFile, JSON.stringify(alexa.cookieData,null,4));
} else {
throw new Error("alexa.cookieData is invalid or missing 'csrf' property.");
} else {
throw new Error("alexa.cookieData is null or empty.");
} catch (e) {
console.log("Error saving cookie and/or list of devices: " + e.message);
function sendCommand(command, value, deviceIDs) {
try {
// See createSequenceNode function in alexa-remote.js for a list of commands.
// If no devices are specified, the command will be sent to ALL devices.
if (!deviceIDs) deviceIDs = getAllDeviceSerialNumbers();
if (!Array.isArray(deviceIDs)) deviceIDs = [deviceIDs];
// Build list of commands
// The 'ssml' and 'announcement' commands support sending to multiple devices at once. The other commands do not.
let allCommands = [];
if (['ssml','announcement'].includes(command)) {
let thisCommand = {};
thisCommand.command = command;
thisCommand.value = (command == 'ssml') ? stringToSSML(value) : value;
allCommands.push(thisCommand);
} else {
deviceIDs.forEach(function(name) {
thisCommand.value = value;
thisCommand.device = name;
console.log("Sending command(s):\n" + JSON.stringify({
devices: deviceIDs,
commands: allCommands,
},null,4));
alexa.sendMultiSequenceCommand(deviceIDs, allCommands);
return;
} catch (e) {
console.log("Error sending command: \n" + JSON.stringify(e, null, 4));
function stringToSSML(input) {
if (input.startsWith('<speak>')) {
// Input is already in SSML format.
return input;
} else {
// Encapsulate string in XML using default voice/lang values, if provided.
let output;
output = input;
if (defaultLang) output = '<lang xml:lang="' + defaultLang + '">' + output + '</lang>';
if (defaultVoice) output = '<voice name="' + defaultVoice + '">' + output + '</voice>';
output = '<speak>' + output + '</speak>';
return output;
function getAllDeviceSerialNumbers() {
let serials = [];
Object.values(alexa.serialNumbers).forEach(function(dev){
serials.push(dev.serialNumber);
return serials;
