Hubitat Plugin Beta
Re: Hubitat Plugin Beta
Downgraded to 2.2.6? and it installed straight away. Hopefully on track now!
A bit of a steep learning curve, and a few missteps along the way, but now have 3 Hue bulbs and a Aqara Opple 6 button switch working well.
Awesome bit of work Jon.
All 30 buttonssiclark wrote:Aqara Opple 6 button switch working well.
Yes, I fully agree with that statement!siclark wrote:Awesome bit of work Jon.
CliveS
Except, setting colour temps in an action group doesn't seem to work. Might be issued my side and things still better than they were. Still investigating
No worries... I can set using MQQT connector and just publish the MQTT message to set the colour temp in an action group.
Hi Simon,
Good morning and thanks for the updates; pleased the plugin is working for you.
You have Clive to thank for the Aqara Opple 6 button switch working straight away, as he provided me with the info to get yesterday's update done.
What are the Action Group commands you are issuing that aren't working.
I am quite happy to investigate my end, once I understand exactly what the issue is.
Are the colour controls working OK from the Indigo UI?siclark wrote:Except, setting colour temps in an action group doesn't seem to work. Might be issued my side and things still better than they were. Still investigating
Morning Jon,
Cheers Clive, I must have just caught that new update.
So if I have a bulb set as colour and temperature and change temperature in indigo, the plugin sends only the colour change to mqqt, ie no colour temp info, and as the colour hasnt changed, nothing changes. If I have the bulb set as temperature only, then no message is sent.
Sending the raw mqqt message from indigo with the new colour temp in it does change the bulb.
Hopefully a quick fix.
Are you changing the colour / temperature via the Indigo UI or using the Action Group > Device Actions > Light/Appliance Controls > Set RGBW Levels?
I am testing with an INNR LED strip (my only Zigbee colour device) and it appears to work OK AFAICS.
The plugin currently treats colour and white levels separately i.e. it can either be RGB or W but not both at the same time. This is similar to how my LIFX plugin works. I am not sure what the setup is for a Philips Hue Bulb?
I am just trying to focus down on where the exact issue is so that I can fix it for you.
I was trying both, using the Indigo GUI and using set RGBW and neither seemed to work, testing with a Philips white temp only bulb.
I have a Philips RGBW bulb too, so can have a test on that.
To get the white level you have to set the RGB components to zero.
What are the exact levels you are setting?
Can you turn on MQTT logging for that bulb and post the messages going back and forth?
That is set in the plugin config under Hubitat MQTT Filtering - just select the one device.
Cheers.. some more testing to be done, but on first look yes its working now with the indigo gui.
I know we all generally love Indigo but trying to use Hubitat has made me realise how amazing it is even more. The plugin store is miles ahead of Hubitat for simplicity, and even for discovery where their apps are scattered all over the internet,. And this forum is so much easier to use than the one on Hubitat.
Much kudos to Matt, Jay and all the developers.
Hi Simon,
There should have been an error in the Indigo Event Log when you tried to set the White Level in the previous version?
I think the Hubitat Elevation Hub is a useful adjunct to Indigo in that it enables some features not currently available in Indigo. However, there is no way that I would want to use Hubitat as my main Home Automation system - IMHO it would be far too labour intensive and require too much tinkering and maintenance when compared to Indigo.
Thanks for the update.siclark wrote:Cheers.. some more testing to be done, but on first look yes its working now with the indigo gui.
I agree 100%I know we all generally love Indigo but trying to use Hubitat has made me realise how amazing it is even more. The plugin store is miles ahead of Hubitat for simplicity, and even for discovery where their apps are scattered all over the internet,. And this forum is so much easier to use than the one on Hubitat. Much kudos to Matt, Jay and all the developers.
As I said a few months ago
I have been adding different switches and sensors from AliExpress, 99% will work (I did find a Neo Coolcam Zigbee motion sensor that no one can get to work in any HA system, wish I had got the Z-Wave 700 version as that has got a Hubitat driver).
As long as you steer clear of Aqara devices then you have sensors that use button batteries instead of CR123 or CR2 and last 2 years compared to 6 months and cost half the price of both the sensors and the batteries.
And I fully agree about the ease of this forum compared to others.
Well I still stand by that now, as far as I am concerned with Jon's plugin it is a Zigbee module add-on but as for programming in it, no idea, not required here.Is the Hubitat better than Indigo, no it is not, it never will be, and when you consider a lot of Hubitat
users moved to it from Vera, Smarthings, Home Assistant, Homie ect then they really should try Indigo.
I will not be moving over to Hubitat but it is great to extend the Zigbee devices (and Z-wave using the new
700 series chip) into Indigo, I just need to sort mine out, I know it works, Jon has proved that.
CliveS
