MyQ API down again
colovin
Re: MyQ API down again
Post by colovin »
The device address is 0. Yes I'm running 7.1.1. 7.2 broke the airfoil plugin which does lots of things on my system. I finally got airfoil pro working (I'm an idiot, someone finally got it to make sense to my dim witted mind) I tried 7.2 but there are so many things that need to be reconfigured, I've set that aside until I can work on that. 7.1.1 is doing everything I need it to do.
Here is the log from reloading MyQ, re-saving the config file to running an action. The device address is still 0 and the garage door is still not saved in the config file.
   MyQ                             Shutting down MyQ
   Stopped plugin "MyQ 7.4.1"
   Starting plugin "MyQ 7.4.1" (pid 10348)
   Started plugin "MyQ 7.4.1"
   MyQ                             Starting MyQ
   MyQ Debug                       statusFrequency = 86400.0
   MyQ Debug                       deviceStartComm: Garage Door Opener (CG0810197CD1): Device Version is up to date
   MyQ Debug                       deviceStartComm: Adding Device Garage Door Opener (CG0810197CD1) (1079833865) to MyQ device list
   MyQ Debug                       myqLogin response = {"SecurityToken":"4fba2670-1363-4b79-ab98-3b53ceaae795"}
   MyQ Debug                       myqLogin successful
   MyQ Debug                       getDevices: 2 Devices
   MyQ Debug                       getDevices: device_family = garagedoor, name = Garage Door Opener, serial_number = CG0810197CD1
   MyQ Debug                       Checking Opener Device: Garage Door Opener (CG0810197CD1) (0) against CG0810197CD1
   MyQ Debug                       getDevices: device_family = gateway, name = Oro Grande, serial_number = GW0200016E50
   MyQ Debug                       availableDeviceList: retList = [(u'CG0810197CD1', u'Garage Door Opener')]
   WebServer                       WD Weather Data Updated
Oct 25, 2019 at 2:32:27 PM
   Trigger                         Running test
   MyQ Debug                       changeDeviceAction, deviceId = 1079833865, actionId = openDoor
   MyQ Debug                       Garage Door Opener (CG0810197CD1): changeDevice: new state = open
   MyQ Error                       Garage Door Opener (CG0810197CD1): changeDevice failure, code: 500, response: {"code":"500.000","message":"An error occurred while processing the request.","description":"Server Error"}
Indigo 7.1.1, OS 10.14.6, MacMini .3.2 GHz 6 Intel Core i7, 64 GB ram
OK, I'll look at that code again tomorrow. This is what pre-releases are for. :lol:
colovin
Post by colovin »
Cool, Thanks!
I hope this one finally fixes it. You will need to edit the devices to select the opener one more time...
https://github.com/FlyingDiver/Indigo-M ... /tag/7.4.2
colovin
Post by colovin »
That worked!! :D Thank you for your diligence with keeping such a great tool working with the ever changing landscape in myQ land.
rsaye
Post by rsaye »
Thanks Joe. Nice work!
Ronnie
colovin
Post by colovin »
It worked one time when I tested it. For actual use it failed with a new error.
MyQ Error                       Garage Door Opener (CG0810197CD1): changeDevice failure, code: 401, response: {"code":"401.101","message":"Unauthorized","description":"The Security Token has expired."}
Does the plugin have something to do with the security token? The phone app still works so my login is still valid.
What happens if you restart the plugin, then try the command? Turn on debug logging first.
colovin
Post by colovin »
Yeah, I had turned off the debug. Here it is reloading the the plugin
 Stopped plugin "MyQ 7.4.2"
   Starting plugin "MyQ 7.4.2" (pid 2303)
   Started plugin "MyQ 7.4.2"
   MyQ                             Starting MyQ
   MyQ Debug                       Garage Door Opener (CG0810197CD1): deviceStartComm: Device version is up to date (2)
   MyQ Debug                       Garage Door Opener (CG0810197CD1): deviceStartComm: Adding device (1079833865) to MyQ device list
   MyQ Debug                       myqLogin response = {"SecurityToken":"2bf81284-150a-46de-855b-9907e94207a8"}
   MyQ Debug                       Checking Opener Device: Garage Door Opener (CG0810197CD1) (CG0810197CD1) against CG0810197CD1
My run test does work
MyQ Debug                       myqLogin response = {"SecurityToken":"aa4fa555-326f-44aa-a891-e1c22537735f"}
But the actual doesn't which I can't recreate at the moment. When you open my mail box it opens the garage door for when I come back from running in the AM and walking in the PM (going for 10k steps a day :-) One of the conditions for it to work is the alarm has to be on. My wife is working on dinner at the moment so she wouldn't be happy if I were start screwing with turning on alarms and such. Not sure why I got the error on the real world application and not on the test because all actions are the same, I just changed the conditions which is a time frame (a AM window and a PM window) Alarm being on and the mail has to have been delivered in the PM so the mail man doesn't open my garage. Test eliminates those conditions. I'll leave the debug on for the next real world experience.
Keep me posted. I might need to detect a failed login attempt and retry. I never did that, because I never had it fail on me.
colovin
Post by colovin »
Here's the whole routine. You can see lots of activities as someone approaches my house. Got the same MyQ error. Opening the mail box is what triggers MyQ. I opened it twice. Second set is running the test routine which worked when I first updated the plugin and after the first failure. This time, a few minutes after the first set it failed.
Oct 27, 2019 at 8:30:00 AM
   Received INSTEON                "Garage I/O Fire - Mail" off
   Trigger                         Running AM
   MyQ Debug                       deviceUpdated: Garage I/O Fire - Mail has changed state: True
   Received INSTEON                "Garage I/O Fire - Mail" on
   MyQ Debug                       deviceUpdated: Garage I/O Fire - Mail has changed state: False
   Received INSTEON                "Garage I/O Photobeam" off
   Trigger                         Photo Beam play sound
   Sent INSTEON                    "Alarm Monitor Delvcam" on
   Sent INSTEON                    "Alert" on
   Schedule                        Photo Beam play sound (delayed action)
   Announcer                       Announcing message "i".
   Received INSTEON                "Garage I/O Photobeam" on
   Trigger                         Running AM
Oct 27, 2019 at 8:34:38 AM
Wow, that's weird. It doesn't even look like it's trying to authenticate.
OK, that was totally my fault.
Grab 7.4.3 from GitHub or the plugin store.
colovin
Post by colovin »
I'm not sure what happened to my morning post. Maybe I didn't hit submit??? (the mind is a terrible thing to waste) but this morning I had said that 7.4.3 had worked on the run test and I'd update you on the real world instance. Well it worked! :D
Oct 27, 2019 at 4:09:44 PM
   Trigger                         Running PM
   Trigger                         Running PM Sunday
   MyQ Debug                       myqLogin response = {"SecurityToken":"ef40fdaa-2e1f-48ab-bfd3-a472f1bbb7eb"}
   MyQ Debug                       myqLogin response = {"SecurityToken":"dfe843a1-fb8b-4d45-8dfc-9e43432ace2c"}
    MyQ Debug                       myqLogin response = {"SecurityToken":"234db612-bc4d-45b3-bd16-3f6a3764818c"}
Sunday is a separate routine because there is no mail delivery to account for. It had the potential to fail because my computer was in VPN which sometimes the servers don't like. I've got an August lock that bitch and moans about it when I'm in VPN. I forgot to take it off. (please note the above, The mind is . .. .) MyQ worked fine. August finally got around to unlocking the door. I edited the log to just show the MyQ. I'll keep the debug menu on for awhile incase something changes.
wideglidejrp
Post by wideglidejrp »
Things were working again after I installed 7.4.3 but now it is not working again. Here is what I am getting....
MyQ Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 79, in runConcurrentThread
File "plugin.py", line 379, in getDevices
File "plugin.py", line 351, in myqLogin
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 816, in json
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/__init__.py", line 307, in loads
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 335, in decode
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 353, in raw_decode
ValueError: No JSON object could be decoded
MyQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
John R Patrick
Author of
Home Attitude
Locked
Return to “MyQ”
