Support For Fibro RGBWW controller
Colorado4Wheeler
Re: Support For Fibro RGBWW controller
Post by Colorado4Wheeler »
The concept is pretty straightforward, it sends the native command through indigo. I’ll see if I can whip up a stress test script to see if it is your system or the Homebridge server. I get slight delays sometimes but I use HKB on about 20 hue lights and it works perfectly 99% of the time.
rehafer
Post by rehafer »
Now that I’m back home I’ve discovered some other devices that are miss behaving. Regular switches not accepting commands or showing the right state; all working fine via Indigo touch.
I had better trouble shoot this first.
rehafer
Post by rehafer »
A follow up after some experiments: erratic HomeKit behavior is fixed by restarting the Indigo server, but gets wonky again after a few days. Looks like the next step is to burn my HomeKit Bridges and rebuild them on my next day off.
Colorado4Wheeler
How many HKB server devices are you running?
HKB isn't really that needy, I haven't found that it degrades much over time but I did build an action into it to restart one or all of your HKB servers. I restart mine daily as a force of habit since BETA when they would frequently go offline and then lose their entire configs, but my dev system hasn't had HKB restarts in who-knows-when and it is still strong.
It's possible you have another plugin that is degrading over time and chewing up resources and that, in turn, slows down HKB. Nest can be a real resource hog.
rehafer
Post by rehafer »
I hadn’t thought of another plugin chewing resources. Things had been working fine until recently which me think for corrupt files.
Maybe I’ll try a daily restart now and start watching for hogs. I do use the Nest Home plugin.
Colorado4Wheeler
Yea, Nest has a memory leak somewhere, I've had it grow to 300MB. That's another I restart daily.
rehafer
Post by rehafer »
In a related question; how do you automate reloading your Nest plugin, or do you do it manually?
Colorado4Wheeler
Manually in a schedule's action:
# Nest Restart
plugin = indigo.server.getPlugin("com.corporatechameleon.nestplugBeta")
if plugin.isEnabled():
	plugin.restart()
rehafer
Post by rehafer »
rehafer
Post by rehafer »
When I execute the ‘Restart All Servers’ command for HKB I don’t see anything in the log; is the expected?
Colorado4Wheeler
Unless you are on a strange version of HKB there should be no action like that. And, yes, when that happens you should be seeing all of your HKB servers shutting down and then restarting.
Screen Shot 2018-07-28 at 3.40.49 PM.png (34.32 KiB) Viewed 4875 times
rehafer
Post by rehafer »
Yes it was restart all accessory servers; got that straightened out. Restarting a 4:45 every morning
Back to the original Fibaro problem. Siting where I can watch the Indigo log and the light strip. While trying to change the color via the home app I often see
Z-Wave Error                    chr() arg not in range(256)
which corresponds to the color change not working.
Plus simulation data
	##### DEVICE DATA DUMP #####
	address : 21
	batteryLevel : None
	blueLevel : 11.18871719
	brightness : 58
	buttonGroupCount : 0
	configured : True
	defaultBrightness : 58
	description :
	deviceTypeId : zwColorDimmerType
	displayStateImageSel : DimmerOn
	displayStateValRaw : 58
	displayStateValUi : 58
	enabled : True
	energyAccumBaseTime : 2000-01-01 00:00:00
	energyAccumTimeDelta : 0
	energyAccumTotal : 0.04
	energyCurLevel : 4.8
	errorState :
	folderId : 0
	     com.perceptiveautomation.indigoplugin.zwave : (dict)
	          SupportsColor : true (bool)
	          SupportsEnergyMeter : true (bool)
	          SupportsEnergyMeterCurPower : true (bool)
	          SupportsEnergyMeterReset : true (bool)
	          SupportsGasMeterReset : true (bool)
	          SupportsRGB : true (bool)
	          SupportsRGBandWhiteSimultaneously : true (bool)
	          SupportsTwoWhiteLevels : false (bool)
	          SupportsWaterMeterReset : true (bool)
	          SupportsWhite : true (bool)
	          address : 21 (integer)
	          indigoObjVersion : 6 (integer)
	          modelNameAndFirmware : RGBW Controller (FGRGBWM), firmware 25.25 (string)
	          propsPushTickler : 2 (string)
	          tempAlwaysFalse : false (bool)
	          userConfigVal009 : 1 (integer)
	          userConfigVal010 : 10 (integer)
	          userConfigVal012 : 255 (integer)
	          userConfigVal013 : 2 (integer)
	          userConfigVal016 : true (bool)
	          userPollAfterActivity : true (bool)
	          userPollInterval : 0 (integer)
	          userPollingEnabled : true (bool)
	          userWakeInterval : 60 (integer)
	          version : 25.25 (string)
	          zwAppVersMajor : 25 (integer)
	          zwAppVersMinor : 25 (integer)
	          zwAssociationsMap : (dict)
	               g1 : (list)
	                    Item : 1 (integer)
	               g2 : (list)
	                    Item : 1 (integer)
	               g3 : (list)
	                    Item : 1 (integer)
	               g4 : (list)
	                    Item : 1 (integer)
	               g5 : (list)
	                    Item : 1 (integer)
	          zwAssociationsMapStr : 1:[1] 2:[1] 3:[1] 4:[1] 5:[1] (string)
	          zwClassCmdBase : 38 (integer)
	          zwClassCmdMap : (dict)
	               c112 : 1 (integer)
	               c114 : 1 (integer)
	               c133 : 1 (integer)
	               c134 : 1 (integer)
	               c32 : 1 (integer)
	               c38 : 1 (integer)
	               c39 : 1 (integer)
	               c49 : 2 (integer)
	               c50 : 2 (integer)
	               c51 : 1 (integer)
	               c96 : 3 (integer)
	          zwClassCmdMapStr : 20v1 60v3 26v1 86v1 27v1 72v1 70v1 31v2 32v2 33v1 85v1 (string)
	          zwClassIds : (list)
	               Item : 4 (integer)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          zwClassInstanceCountMap : (dict)
	          zwClassInstanceCountMapStr : - none - (string)
	          zwClassName : Dimmable Power Switch (string)
	          zwConfigVals : (dict)
	               p10 : 10 (integer)
	               p12 : 255 (integer)
	               p13 : 2 (integer)
	               p16 : 1 (integer)
	               p8 : 0 (integer)
	               p9 : 1 (integer)
	          zwConfigValsStr : 16:1 8:0 9:1 10:10 12:255 13:2 (string)
	          zwDevSubIndex : 0 (integer)
	          zwEncryptClassCmdMap : (dict)
	          zwEncryptClassCmdMapStr : - none - (string)
	          zwEncryptionStatusStr : Not Supported (string)
	          zwEndpointClassMap : (dict)
	               e1 : (list)
	                    Item : 38 (integer)
	               e2 : (list)
	                    Item : 38 (integer)
	               e3 : (list)
	                    Item : 38 (integer)
	               e4 : (list)
	                    Item : 38 (integer)
	               e5 : (list)
	                    Item : 38 (integer)
	          zwEndpointClassMapStr : 1:[26], 2:[26], 3:[26], 4:[26], 5:[26] (string)
	          zwEndpointDevTypeMap : (dict)
	               e1 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e2 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e3 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e4 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	               e5 : (list)
	                    Item : 17 (integer)
	                    Item : 1 (integer)
	          zwEndpointDevTypeMapStr : 1:(11 : 01), 2:(11 : 01), 3:(11 : 01), 4:(11 : 01), 5:(11 : 01) (string)
	          zwFeatureListStr : routing, beaming, energyMeter (string)
	          zwLibType : 3 (integer)
	          zwManufactureId : 271 (integer)
	          zwManufactureName : Fibaro System (string)
	          zwMeterSubTypeFlags : 5 (integer)
	          zwMeterSupportsReset : true (bool)
	          zwMeterType : 1 (integer)
	          zwModelDefnVers : 4 (integer)
	          zwModelId : 151003136 (integer)
	          zwModelName : RGBW Controller (FGRGBWM) (string)
	          zwNodeNeighbors : (list)
	               Item : 1 (integer)
	               Item : 2 (integer)
	               Item : 3 (integer)
	               Item : 8 (integer)
	               Item : 9 (integer)
	               Item : 12 (integer)
	               Item : 14 (integer)
	               Item : 15 (integer)
	               Item : 20 (integer)
	          zwNodeNeighborsStr : 1, 2, 3, 8, 9, 12, 14, 15, 20 (string)
	          zwProtoVersMajor : 3 (integer)
	          zwProtoVersMinor : 52 (integer)
	          zwShowMainUI : true (bool)
	          zwShowManualModifyConfigParmUI : false (bool)
	          zwShowPollingUI : true (bool)
	          zwShowSubmitModelInfoUI : false (bool)
	          zwShowWakeIntervalUI : false (bool)
	          zwWakeInterval : 0 (integer)
	greenLevel : 0.0
	lastChanged : 2018-07-29 16:05:04
	lastSuccessfulComm : 2018-07-29 16:05:04
	ledStates : []
	model : RGBW Controller (FGRGBWM)
	onBrightensToDefaultToggle : False
	onBrightensToLast : True
	onState : True
	ownerProps : com.perceptiveautomation.indigoplugin.zwave : (dict)
	          g1 : (list)
	               Item : 1 (integer)
	          g2 : (list)
	               Item : 1 (integer)
	          g3 : (list)
	               Item : 1 (integer)
	          g4 : (list)
	               Item : 1 (integer)
	          g5 : (list)
	               Item : 1 (integer)
	          c112 : 1 (integer)
	          c114 : 1 (integer)
	          c133 : 1 (integer)
	          c134 : 1 (integer)
	          c32 : 1 (integer)
	          c38 : 1 (integer)
	          c39 : 1 (integer)
	          c49 : 2 (integer)
	          c50 : 2 (integer)
	          c51 : 1 (integer)
	          c96 : 3 (integer)
	     zwClassIds : (list)
	          Item : 4 (integer)
	          Item : 17 (integer)
	          Item : 1 (integer)
	          p10 : 10 (integer)
	          p12 : 255 (integer)
	          p13 : 2 (integer)
	          p16 : 1 (integer)
	          p8 : 0 (integer)
	          p9 : 1 (integer)
	          e1 : (list)
	               Item : 38 (integer)
	          e2 : (list)
	               Item : 38 (integer)
	          e3 : (list)
	               Item : 38 (integer)
	          e4 : (list)
	               Item : 38 (integer)
	          e5 : (list)
	               Item : 38 (integer)
	          e1 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e2 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e3 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e4 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          e5 : (list)
	               Item : 17 (integer)
	               Item : 1 (integer)
	          Item : 1 (integer)
	          Item : 2 (integer)
	          Item : 3 (integer)
	          Item : 8 (integer)
	          Item : 9 (integer)
	          Item : 12 (integer)
	          Item : 14 (integer)
	          Item : 15 (integer)
	          Item : 20 (integer)
	pluginId : com.perceptiveautomation.indigoplugin.zwave
	pluginProps : com.eps.indigoplugin.homekit-bridge : (dict)
	protocol : ZWave
	redLevel : 57.89110065
	remoteDisplay : True
	states : States : (dict)
	     accumEnergyTimeDelta : 0 (integer)
	     accumEnergyTimeDelta.ui : 0 seconds (string)
	     accumEnergyTotal : 0.04 (real)
	     accumEnergyTotal.ui : 0.04 kWh (string)
	     blueLevel : 11.18871719 (real)
	     blueLevel.ui : 11 (string)
	     brightnessLevel : 58 (integer)
	     curEnergyLevel : 4.8 (real)
	     curEnergyLevel.ui : 4.8 W (string)
	     greenLevel : 0.00000000 (real)
	     greenLevel.ui : 0 (string)
	     onOffState : on (on/off bool)
	     redLevel : 57.89110065 (real)
	     redLevel.ui : 58 (string)
	     whiteLevel : 0.00000000 (real)
	     whiteLevel.ui : 0 (string)
	subModel : Composite
	supportsAllOff : False
	supportsColor : True
	supportsRGB : True
	supportsRGBandWhiteSimultaneously : True
	supportsStatusRequest : True
	supportsWhite : True
	version : 25.25
	whiteLevel : 0.0
	whiteLevel2 : None
	whiteTemperature : None
	##### DEVICE SIMULATION DATA #####
	Service :
		alias : Color Strip
		model : Composite
		subModel :
		indigoType : indigo.DimmerDevice
		pluginType : indigo.DimmerDevice.com.perceptiveautomation.indigoplugin.zwave.zwColorDimmerType
		type : Lightbulb
		desc : Lightbulb
		objId : 1826503808
		serverId : 697542815
		invertOnState : False
		convertFahrenheit : False
		required : (List)
			On : True
		optional : (List)
			Hue : 348.403692038
			Saturation : 100.0
			ColorTemperature : 4610
			Name
			Brightness : 58
		native : True
		requiresPlugin : (List)
		actions : (List)
			Action : (HomeKitAction)
				Characteristic : On
				When : equal
				Value : False (bool)
				Value2 : 0 (bool)
				Command : device.turnOff
				Arguments : [1826503808]
				monitors : {1826503808: 'attr_onState'}
				Characteristic : On
				When : equal
				Value : True (bool)
				Value2 : 0 (bool)
				Command : device.turnOn
				Characteristic : Hue
				When : between
				Value : 0.0 (float)
				Value2 : 100000.0 (float)
				Command : homekit.commandSetDeviceColor
				Arguments : [1826503808, 697542815, '=service=', 'Hue', '=value=']
				monitors : {1826503808: 'attr_whiteTemperature'}
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				Arguments : [1826503808, 0]
				monitors : {1826503808: 'attr_redLevel'}
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				monitors : {1826503808: 'attr_blueLevel'}
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				monitors : {1826503808: 'attr_greenLevel'}
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				monitors : {1826503808: 'attr_whiteLevel'}
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				monitors : {1826503808: 'attr_whiteLevel2'}
				Characteristic : Saturation
				When : between
				Value : 0.0 (float)
				Arguments : [1826503808, 697542815, '=service=', 'Saturation', '=value=']
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				Characteristic : ColorTemperature
				When : between
				Value : 0.0 (float)
				Arguments : [1826503808, 697542815, '=service=', 'ColorTemperature', '=value=']
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				When : equal
				Value : STUB (str)
				Value2 : 0 (str)
				Command : STUB
				Characteristic : Brightness
				When : between
				Value : 0 (int)
				Value2 : 100 (int)
				Command : dimmer.setBrightness
				Arguments : [1826503808, '=value=']
				monitors : {1826503808: 'attr_brightness'}
		loadOptional : False
		characterDict : (Dict)
			On : True
			Saturation : 100.0
			Brightness : 58
			Hue : 348.403692038
Does this tell you anything?
BTW, actions from the Flux FED plugin don't even show up in the log, so kind of iffy
Colorado4Wheeler
Please open a ticket on GitHub and follow the instructions for the log. Be sure to restart your server beforehand so all the extra junk isn't in there and then we'll want logs that show the value being sent to Indigo when you get that error so I can sample the conversion and see if it's trying to go over 256.
Return to “HomeKit Bridge”
