Tesla Battery Gateway Plugin
Re: Tesla Battery Gateway Plugin
Okay - that was the reported previous issue
Can overcome by restarting after setting command - but does risk leaving the battery and backup off if commands fails ? (Which was reason I didn’t progress)
Have fixed the issue in 0.4.2 up now
Glenn
Glenn
petematheson
Back to this error now:
Tesla Battery Error Method Not Allowed
If I log in and hit start it starts instantly, no gateway restart or anything from what I can see?
Tesla Battery Debug logLevel = 10
Tesla Battery Debug User prefs saved.
Tesla Battery Debug Debugging on (Level: 10)
Action Group Tesla PW Backup
Tesla Battery Debug setFanSpeed Called as Action.
Tesla Battery Debug Thread Send Login Basic called. Number of Active Threads:2
Tesla Battery Debug Calling https://192.168.0.161/api/login/Basic with payload:{'username': 'installer', 'force_sm_off': False, 'password': xxxxxxx', 'email': u'[email protected]'}
Tesla Battery Debug {"email":"pete@xxxxxxx","firstname":"Tesla","lastname":"Energy","roles":["Provider_Engineer"],"token":"UXzn0onLxxxxxxxJlYM9V24JG77WpgQ==","provider":"Basic","loginTime":"2020-05-12T08:11:25.112290392+01:00"}
Tesla Battery Debug UXzn0xxxxxxxM9V24JG77WpgQ==
Tesla Battery Debug Change Operation called. Number of Active Threads:2
Tesla Battery Debug Calling https://192.168.0.161/api/operation with headers:{'Authorization': 'Bearer UXzn0onxxxxxxxxx4JG77WpgQ=='} and payload {'backup_reserve_percent': 0.0, 'mode': u'backup'}
Tesla Battery Debug update Tesla Meters Called
Tesla Battery Debug ThreadSendCOmmand called. Number of Active Threads:2
Tesla Battery Debug sendcommand called
Tesla Battery Debug HTTPS CURL result:
Tesla Battery Debug ReturnCode:0
Tesla Battery Debug Text :<closed file '<fdopen>', mode 'rb' at 0x10f70e9c0>
Tesla Battery Debug Error Running command. ?Powerwall offline
Tesla Battery Debug update Tesla Grid Status Called
Tesla Battery Debug Text :<closed file '<fdopen>', mode 'rb' at 0x10f70e780>
That doesn’t look great
Doesn’t seem to be recognising either command or token
Try 0.4.4
Try 0.4.4
petematheson
Unfortunately not
extToSpeak :
Tesla Battery Debug Calling https://192.168.0.161/api/login/Basic with payload:{'username': 'installer', 'force_sm_off': False, 'password': xxxxxx', 'email': u'pete@xxxxxxxx'}
Tesla Battery Debug {"email":"pete@xxxxxxx","firstname":"Tesla","lastname":"Energy","roles":["Provider_Engineer"],"token":"aKaht0lxxxxxxxFRMuOqw==","provider":"Basic","loginTime":"2020-05-12T08:31:58.866239999+01:00"}
Tesla Battery Debug aKaht0lxxxxxxxxRMuOqw==
Tesla Battery Debug Reserve Percentage is :0.0 and prior 0
Tesla Battery Debug Calling https://192.168.0.161/api/operation with headers:{'Authorization': 'Bearer aKahtxxxxxxxMuOqw=='} and payload {'backup_reserve_percent': 0.0, 'mode': u'backup'}
Tesla Battery Error {"code":403,"error":"Unable to POST to resource","message":"User does not have adequate access rights"}
Tesla Battery Error change Operation failed.
extToSpeak :
Ok
Thats a different error for some reason
Have you set the reserve percentage in the action? Says 0.0 which may cause issues
Found something
Try 0.4.5
Try 0.4.5
petematheson
Changed reserve to 1 and errored below:
Tesla Battery Debug Calling https://192.168.0.161/api/login/Basic with payload:{'username': 'installer', 'force_sm_off': False, 'password': 'xxxxx', 'email': 'pete@xxxxxxx'}
Tesla Battery Debug {"email":"pete@xxxxxx","firstname":"Tesla","lastname":"Energy","roles":["Provider_Engineer"],"token":"R9YyxxxxxqXFXitdcWag==","provider":"Basic","loginTime":"2020-05-12T08:39:49.865609746+01:00"}
Tesla Battery Debug R9Yy4FVxxxxxxhqXFXitdcWag==
Tesla Battery Debug Reserve Percentage is :1.0 and prior 1
Tesla Battery Debug Calling https://192.168.0.161/api/operation with headers:{'Authorization': 'Bearer R9Yy4FVpFGe-ou_CAbw_xxxxxdcWag=='} and payload {'backup_reserve_percent': 1.0, 'mode': 'backup'}
Tesla Battery Error change Operation failed. Unsure why. Check error message.
Tesla Battery Error Restarting Sitemaster
Tesla Battery Debug setConfigCompleted called. Number of Active Threads:2
Tesla Battery Debug Calling https://192.168.0.161/api/sitemaster/run with headers:{'Authorization': 'Bearer R9Yy4FVpFGe-ou_CAbwxxxxxxxxxFXitdcWag=='}
Tesla Battery Error {"code":403,"error":"Unable to GET to resource","message":"User does not have adequate access rights"}
try 0.4.6
Very much shot in dark - otherwise probably need to sort out own installer access to resolve.
But error has changed - from method not allowed, to authorisation now?
Skip 0.4.6
Feel more confident about 0.4.7 - give me 5
Pete, don’t give Glenn your credentials - he might try summoning your Powerwall off the wall!
Oh wait, it’s only me does that with Tesla cars.
Shipping would be a bit much!howartp wrote:Pete, don’t give Glenn your credentials - he might try summoning your Powerwall off the wall!
Oh wait, it’s only me does that with Tesla cars.![]()
Try 0.4.7- up there now - vaguely confident.
Also those error messages you are getting, is when login as installer (which have to be to change mode/settings) it turns off the battery/backup so called 'sitemaster'
With this off - the calls for info by the plugin fail as you are seeing.
Once mode changed, then need to restart sitemaster and get battery up and running again.
(added that a few versions ago - yet to be tested as haven't logged in yet)
A Blackout - at any stage during this would be just that a proper blackout - as battery is off, with no backup function.
No sure what would happen if in a actual grid-outage and you tried changing settings with the plugin - probably battery off, house dead/Indigo dead and no way of turning on again (although you can plug a 9V battery into the Gateway service ports to cold jump start -I have done that once!)
So you can see the risk of allowing mode changes via plugin/code?
Glenn
Never claim that when releasing annoying bug fixes - it always backfires!GlennNZ wrote:vaguely confident.
petematheson
Didn't work, but also didn't kill the PW this time
Tesla Battery Debug Text :<closed file '<fdopen>', mode 'rb' at 0x11097f5d0>
Tesla Battery Debug Calling https://192.168.0.161/api/login/Basic with payload:{'username': 'installer', 'force_sm_off': False, 'password': 'xxxxx', 'email': 'pete@xxxxx'}
Tesla Battery Debug {"email":"pete@xxxxx","firstname":"Tesla","lastname":"Energy","roles":["Provider_Engineer"],"token":"xMlRzxxxxoyQtYw==","provider":"Basic","loginTime":"2020-05-12T08:59:55.031570923+01:00"}
Tesla Battery Debug xMlxxxxxxx4UToyQtYw==
Tesla Battery Debug Calling https://192.168.0.161/api/operation with headers:{'Authorization': 'Bearer xMlRz68Cxxxxx4UToyQtYw=='} and payload {'backup_reserve_percent': 1.0, 'mode': 'backup'}
Tesla Battery Error {"code":500,"error":"invalid character 'b' looking for beginning of value","message":"Unable to set operational mode"}
Tesla Battery Debug Calling https://192.168.0.161/api/sitemaster/run with headers:{'Authorization': 'Bearer xMlRz68CpxxxxxxxHEA38rU4UToyQtYw=='}
Tesla Battery Debug
Tesla Battery Error Error setconfigComplete Operation : ValueError('No JSON object could be decoded',)
File "plugin.py", line 621, in setsitemasterRun
jsonResponse = r.json()
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/requests/models.py", line 816, in json
return complexjson.loads(self.text, **kwargs)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/__init__.py", line 307, in loads
return _default_decoder.decode(s)
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 335, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/Library/Application Support/Perceptive Automation/Indigo 7.4/IndigoPluginHost.app/Contents/Resources/PlugIns/simplejson/decoder.py", line 353, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
Tesla Battery Debug Error setting OperationNo JSON object could be decoded
Tesla Battery Debug update Tesla Battery Called
Tesla Battery Debug SUCCESS Text :{u'percentage': 0}
Tesla Battery Debug Json results:{u'percentage': 0}
Tesla Battery Debug sendcommand r.json result:{u'percentage': 0}
Tesla Battery Debug
Ok
Powerwall - is still running because plugin did successfully restart it. So that bit works - just the operational mode change isn't
Try :0.4.8
FIxes some of those errors and trys something different for operationalmode.
Otherwise - try a few other types of modes and see how goes
Up reserve Battery to 20 etc. There may be lower limit and API setting does not equal App % setting completely.
Try :0.4.8
petematheson
Tesla Battery Error {"code":500,"error":"RealMode must be either backup, self_consumption, or autonomous","message":"Unable to set operational mode"}
