Timed Devices plugin
kmarkley
Re: Timed Devices plugin
Post by kmarkley »
@ stuartcolman:
This request is not as straightforward as it seems. Starting the timer when the last tracked device goes off is incompatible with the 'Any Change' logic (which by definition ignores the difference between on and off). Additionally, the plugin would have to either maintain a tally of how many devices are on (which runs the risk of getting out of sync if there are communication hiccups) or repeatedly querying Indigo about the state of devices (which adds considerable overhead). It could be done, but would break the lean structure of the code as it stands now, which I'm not eager to do.
But as I said before, you can use a Persistence Timer to accomplish this for a single device/variable.
kmarkley
Post by kmarkley »
Version 0.0.13 released:
• NEW 'Alive Timer' device type tracks any change (including heartbeat) of another device or variable. Switches to OFF when tracked entity is not updated for user-defined period.
• Plugin devices may now track other plugin devices (but not self)
• Fixed a couple incorrect states on Force On and Force Off
• Update README
howartp
Post by howartp »
Awesome!
vtmikel
Post by vtmikel »
Thanks again for this plugin.
Question:
Is there a way that I can specify a threshold of devices such as what is possible in the activity timer, but that the off timer will not start until the threshold of devices is not met? This way if you have motion, but in a concentrated area, and those sensors are not going "off" then the activity timer also does not expire...
Another way of thinking about it is that I want extensions to be perpetual until the device goes into it's off state.
kmarkley
Post by kmarkley »
New version 0.0.16 posted:
• New 'Running Timer' device tracks accumulated time of other device states. See this thread.
• Minor efficiency improvements
kmarkley
Post by kmarkley »
Sorry for the delayed response.
vtmikel wrote:Is there a way that I can specify a threshold of devices such as what is possible in the activity timer, but that the off timer will not start until the threshold of devices is not met? This way if you have motion, but in a concentrated area, and those sensors are not going "off" then the activity timer also does not expire...
Interesting. All my motion sensors are only on for very brief periods while actively detecting motion. If I understand correctly, yours remain on for some time thereafter.
This should be possible, but it is not clear to me whether it makes more sense as a new device type or an option on the Activity Timer device type. I'll play around with it some this weekend.
kmarkley
Post by kmarkley »
New version 0.0.17 posted.
• new Threshold Timer device type
• clearer device configuration UI
• README fixes
New device type should do what vtmikel is looking for. Should also work for stuartcoleman in the case where threshold = 1.
vtmikel
Post by vtmikel »
kmarkley wrote:New version 0.0.17 posted.
• README fixes
Incredible! Thanks so much! I will test and let you know.
koburg
Post by koburg »
Hi I got this error
Timed Devices Error             "Toerre Trumpler Aktiv" count out of sync [count:-1, max:1]
but the devices is working seems to
and I found that your plugin do not support Nordic letters like
ÆØÅ
dont know if it is displayed correct when you look at it.
kmarkley
Post by kmarkley »
koburg wrote:Hi I got this error but the devices is working seems to
Short version:
This is probably nothing to worry about unless you see it repeatedly, in which case the issue is probably more systemic than just this plugin. You might want to disable/enable the affected device to ensure it gets back in sync.
Long version:
This plugin relies on communication from Indigo about tracked device states. This is pretty reliable, but not bulletproof. Most device types from this plugin are (eventually) self-correcting -- timers expire and/or tracked entities change and the plugin re-evaluates what the device state should be.
But Threshold Timer devices are different. They need to maintain an internal tally of how many tracked entities are on. Incrementing whenever a tracked entity turns on and decrementing when a tracked entity turns off. The bottom line is that if a message from Indigo gets missed, the internal tally can get out of sync with the actual entities being tracked. If the tally drops below zero or is higher than the number of tracked entities, and error is generated as you have seen.
I notice that the Threshold Device this error is about is only tracking a single entity ("max: 1"). This device type is intended to track multiple inputs and you may get better results with one of the other plugin device types like Persist or Lockout.
koburg wrote:and I found that your plugin do not support Nordic letters like
ÆØÅ
I'm not really sure what is entailed to support Nordic letters. Is there a plugin that handles this well that I can try to emulate?
koburg
Post by koburg »
kmarkley wrote: I'm not really sure what is entailed to support Nordic letters. Is there a plugin that handles this well that I can try to emulate?
it is something about the unicode im not learned python code yet but have some courses I wanna try.
I have found some links to maybe a solution for you.
https://www.google.dk/url?sa=t&rct=j&q= ... GMnmSPQXK0
https://www.google.dk/url?sa=t&rct=j&q= ... Tt0bAqQgXj
There are some of the plugin that "don't care" about the nordic letters I will get back when I have located those.
racarter
Post by racarter »
Hi @kmarkley
Downloaded new version but Indigo thinks it's the same as the old one. Did you forget to bump the version number? :wink:
kmarkley
Post by kmarkley »
racarter wrote:Did you forget to bump the version number?
I had bumped the version in the repository, but not the zip file. Thanks for the head's up.
Fixed now.
haavarda
Post by haavarda »
This plugin is really nice. Makes motion triggered lights much easier to set up.
Any idea on how to detect a manual turn on of the lights and induce a override? Is this something that could be added to the plugin?
Håvard
kmarkley
Post by kmarkley »
haavarda wrote:This plugin is really nice. Makes motion triggered lights much easier to set up.
Thanks. Glad it is useful.
haavarda wrote: Any idea on how to detect a manual turn on of the lights and induce a override? Is this something that could be added to the plugin?
I don't think this can be accomplished by the plugin, since the plugin is not actually providing the trigger (just the event for a trigger to respond to).
Presuming that you have something like this:
motion sensors -> Timed Devices device -> trigger -> triggered lights
Then you'd want to add a trigger on the manual switch to disable/enable the trigger in the above chain of causality.
Hope that helps.
