Stopped the server, deleted the plugin from the plugins folder, started the server, executed the 1.2.72 version of the plugin
2015-05-24 21:14:00.204 Application Stopping plugin "NEST Home" (pid 14282)
2015-05-24 21:14:01.342 Application Stopped plugin "NEST Home"
2015-05-24 21:14:01.343 Application Upgrading plugin "NEST Home" to newer version 1.2.70 (previous version moved to trash)
2015-05-24 21:14:01.618 Application Loading plugin "NEST Home 1.2.70"
2015-05-24 21:14:01.622 Application Starting plugin "NEST Home 1.2.70" (pid 57803)
2015-05-24 21:14:03.486 Application Started plugin "NEST Home 1.2.70"
2015-05-24 21:14:04.546 NEST Home Error versionCheck: There was an error parsing the server's version file.
2015-05-24 21:14:04.761 NEST Home Setting up the API...
2015-05-24 21:14:04.762 NEST Home Refreshing NEST map from home.nest.com...
2015-05-24 21:14:05.582 NEST Home Secure connection to Nest API devices secured...
2015-05-24 21:14:06.278 NEST Home Secure connection to Nest API structures secured...
2015-05-24 21:14:06.279 NEST Home Nest Has detected the following devices...1 NEST Thermostats and: 8 NEST Protects
2015-05-24 21:14:06.344 NEST Home Refreshing NESTs...
2015-05-24 21:14:06.351 NEST Home Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 1419, in runConcurrentThread
File "plugin.py", line 608, in refreshNests
<type 'exceptions.TypeError'>: cannot concatenate 'str' and 'int' objects
2015-05-24 21:14:06.352 NEST Home Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2015-05-24 21:14:16.354 NEST Home Setting up the API...
2015-05-24 21:14:16.356 NEST Home Refreshing NEST map from home.nest.com...
2015-05-24 21:14:17.141 NEST Home Secure connection to Nest API devices secured...
2015-05-24 21:14:17.862 NEST Home Secure connection to Nest API structures secured...
2015-05-24 21:14:17.862 NEST Home Nest Has detected the following devices...1 NEST Thermostats and: 8 NEST Protects
2015-05-24 21:14:17.994 NEST Home Refreshing NESTs...
2015-05-24 21:14:18.021 NEST Home Error Error in plugin execution runConcurrentThread:
2015-05-24 21:14:18.023 NEST Home Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2015-05-24 21:14:28.021 NEST Home Setting up the API...
2015-05-24 21:14:28.022 NEST Home Refreshing NEST map from home.nest.com...
2015-05-24 21:14:28.531 NEST Home Secure connection to Nest API devices secured...
2015-05-24 21:14:29.221 NEST Home Secure connection to Nest API structures secured...
2015-05-24 21:14:29.222 NEST Home Nest Has detected the following devices...1 NEST Thermostats and: 8 NEST Protects
2015-05-24 21:14:29.288 NEST Home Refreshing NESTs...
2015-05-24 21:14:29.295 NEST Home Error Error in plugin execution runConcurrentThread:
2015-05-24 21:14:29.296 NEST Home Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2015-05-24 21:14:39.296 NEST Home Setting up the API...
2015-05-24 21:14:39.297 NEST Home Refreshing NEST map from home.nest.com...
2015-05-24 21:14:39.999 NEST Home Secure connection to Nest API devices secured...
2015-05-24 21:14:40.669 NEST Home Secure connection to Nest API structures secured...
2015-05-24 21:14:40.670 NEST Home Nest Has detected the following devices...1 NEST Thermostats and: 8 NEST Protects
2015-05-24 21:14:40.734 NEST Home Refreshing NESTs...
2015-05-24 21:14:40.739 NEST Home Error Error in plugin execution runConcurrentThread:
2015-05-24 21:14:40.740 NEST Home Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
2015-05-24 21:14:50.740 NEST Home Setting up the API...
2015-05-24 21:14:50.741 NEST Home Refreshing NEST map from home.nest.com...
2015-05-24 21:14:51.737 NEST Home Secure connection to Nest API devices secured...
2015-05-24 21:14:52.448 NEST Home Secure connection to Nest API structures secured...
2015-05-24 21:14:52.449 NEST Home Nest Has detected the following devices...1 NEST Thermostats and: 8 NEST Protects
2015-05-24 21:14:52.513 NEST Home Refreshing NESTs...
2015-05-24 21:14:52.518 NEST Home Error Error in plugin execution runConcurrentThread:
I just noticed that the version in the error is the old .70 not the expected .72.
So, I re downloaded but first looked at the info.plist contents to verify that I have the correct version:
<plist version="1.0">
<dict>
<key>PluginVersion</key>
<string>1.2.72</string>
<key>ServerApiVersion</key>
<string>1.19.0</string>
<string>NEST Home</string>
<key>CFBundleIdentifier</key>
<string>com.corporatechameleon.nestplugBeta</string>
<key>CFBundleVersion</key>
<string>1.0.0</string>
<key>CFBundleURLTypes</key>
<array>
<dict>
<key>CFBundleURLName</key>
<string>http://forums.indigodomo.com/viewforum.php?f=170</string>
</dict>
</array>
</dict>
</plist>
Executed the fresh download. A window popped up saying i already have version .72 installed. The new errors continue but the Nests status stays green now. I have not tested their function.
I only deleted the plugin. To completely remove the plugin and all settings, what else must I do?
