Thanks for your help Karl.
Edmond
Edmond
you might want to check your download folder.
remove any *.indigoPlugin" files
otherwise you will run into the same problem again at the next update
Thats a good idea.
Edmond
Edmond
Hello Karl,
Im wondering if the rpi can monitor 4 different Bluetooth dongles. What I was thinking about doing is running long usb cables to different parts of my house, each with a usb dongle plugged into one end and the other end into my rpi. That way one rpi can monitor 4 different areas of my house.
Would this be possible?
Edmond
Edmond
I guess it's easier and cheaper to have 4 rpi Setup.
I dont believe the bluez library supports more than 1 dongle. Have not seen that idea discussed anywhere.
A very long UBS cable would require an active element in between to refresh it. I believe ...
I have one that is 10 m long and it has an amplifier in the middle was ~$20 Don't know if you can add several together.
may I suggest to go the opposite route:
put an rPi in to every room. It can not just do iBeacons, but also any kind f input and output device
The next version is supporting
-several different temp/humifity/pressure sensors
-regular GPIOpin input and output. you can use them to do door/window sensors etc, switch on / off things, or for ir beam detection etc, keypad entry
-analog input 4/8 channels with 10/16 bit resolution : could be used for other sensors that deliver an analog voltages. The plugin has an option to multiply / offset the values and display e.g a measured 75 mV as 39.5ºF or 3cm or 5inches (for rain detection) etc depending on your device volt- xx-unit conversion.
- analog out 12 bit for precision voltage output. Currently only one device supported. Could be used to drive eg position motors etc. Or in the next version we could add recorded sound so you could play that on a speaker at the door.
- to be added is a counter input for e.g. rain amount or we could attach a power meter..
==> the options are endless as the rPi has a real OPSys and the current load is max 10-20 % with several sensors ibeacons etc running in parallel.
The total cost: ~ $50 for the rPi
$1-20 for special sensors / output devices.
Compared to insteon sensors $30-90 each
I am just exited about the potential..
Right on, that sounds pretty cool. I cant wait to play with it.
updated the docs for the new version for the setup of rPi, sensors, scripts etc in the sections of the main piBeacon thread
http://forums.indigodomo.com/viewforum.php?f=187
Tried to install the latest version. After upgrading I get the following message in the log:
piBeacon piBeacon --V 1.11.1 initializing
piBeacon in Line '430' has error='[Errno 2] No such file or directory: '/users/wey3/documents/piBeacon/rejected/rejectedByPi.json''
And it seems after that the beacons stay on the status "expired"
Regards,
Wouter
Regards,
Wouter
could you check if the "/documents/piBeacon/rejected" exists?.
this is not really an error message, just that the file does not exist. will change that.
You need to push the new files to your rPis.
And the rpis will need ~ 5 minutes to download all the libraries.
you can check if the rPis are running:
open terminal:
ssh pi@ipnumber
enter password
then type
ps -ef | grep python
you should see something like this:
you might not see the sensor py files if you have none defined
open terminal:
ssh pi@ipnumber
enter password
then type
root 2367 1 0 10:18 ? 00:00:01 python /home/pi/callbeacon.py
root 2470 1 0 10:18 ? 00:00:00 /usr/bin/python /home/pi/sensors.py
root 2472 1 0 10:18 ? 00:00:00 sudo /usr/bin/python /home/pi/beaconloop.py
root 2477 2472 3 10:18 ? 00:01:17 /usr/bin/python /home/pi/beaconloop.py
root 2519 1 0 10:18 ? 00:00:01 /usr/bin/python /home/pi/getsensorvalues.py
root 5239 1 0 10:56 ? 00:00:00 /usr/bin/python /home/pi/receiveGPIOcommands.py 9999
pi 5282 5267 0 10:57 pts/0 00:00:00 grep --color=auto python
I checked the folder: the folder exists, the file is not.
Installed the latest version again. I had to configure the rpi's because the list of the rpi was empty. After send config and restart, two of the three rpi's are doing the update of the libraries. One seems to do it also but does not show the processes you mentioned.
Two rpi's are showing:
The other one:
None of the beacons are updated and are showing "expired".
Regards Wouter
root 2477 1 0 18:51 ? 00:00:01 python /home/pi/callbeacon.py
root 2584 1 0 18:51 ? 00:00:00 /usr/bin/python /home/pi/sensors.py
root 2588 1 0 18:51 ? 00:00:00 sudo /usr/bin/python /home/pi/beaconloop.py
root 2589 2588 1 18:51 ? 00:00:16 /usr/bin/python /home/pi/beaconloop.py
pi 3483 2651 0 19:07 pts/1 00:00:00 grep --color=auto pythonCode: Select all
pi 2668 2612 0 19:14 pts/1 00:00:00 grep --color=auto pythonRegards Wouter
This look correct.
For the ones without processes running do
sudo python callbeaconloop.py
Then do again ps - ef ....
Check if the programs are running.
I am out for 2 more hours. Will look into it when I am back home.
This look correct.
Because I also had to go away, I downgraded to the previous version, configured the rPi's, rebooted and everything is working again.
I will not be much at home the next few days but if I have to do/check something please let me know.
Regards
Wouter
Regards
Wouter
