released v 7.78.193
download at https://www.indigodomo.com/pluginstore/59/
support for IR 8x8 camera amg88xx. It can be used as sophisticated motion sensor.
released v 7.78.194
- bug fix
- reduced cpu time
- better amg88xx parameters
- cool layout of analogClock for RPI display
- bug fix
- reduced cpu time
released v 7.78.197
= Significantly expanded DISPLAY features
dynamically overlay text/, triangles, lines, histograms, rectangles, points from devices/state or variables contents, Nice Analog clock , ...
= Some smaller bug fixes and exception handling
checkout the video:
https://www.dropbox.com/s/0aa2e9309i2so ... 2.m4v?dl=1
checkout the video:
released v 7.79.199 @https://www.indigodomo.com/pluginstore/59/
fixed beacons not changing
added full amg33 support. color shows the temperature in ºC. This not just an IR sensor but measures temperature
person sitting 2 m away 2 fingers 10 cm away person standing 3 m away The images are scaled up from 8x8 to 512x512 with interpolation in-between the measured points. you can chose 8x8,32x32.. 1024x1024 and w and w/o temp scale
Update frequency can be set, but don't go below 2 secs
released v 7.80.200 @https://www.indigodomo.com/pluginstore/59/
added:
== support for CO2 and VOC sensor SGP30
== for amg88 now offers color image or grey scale
== BLE stack restart if no BLE message for > 100 secs internally on RPI
fixed:
/0 in distance calculations when some RPI positions are not set .
added:
fixed:
- Screen Shot 2018-01-28 at 14.17.17.png (62.39 KiB) Viewed 4516 times
released v 7.80.201 @https://www.indigodomo.com/pluginstore/59/
added:
== support for CO2 and VOC sensor CSS 811
fixed:
== RPI devices not created under certain circumstances
added:
fixed:
posted new version on plugin store https://www.indigodomo.com/pluginstore/59/ and GitHub.com/kw123.
added Sprinkler device and new light sensor VEML7700
just for completeness: all the devices supported:
===iBeacon
beacon
===BLECONNECT for phones
BLEconnect
===BLE temp sensor
BLEsensor
===Temp Pressure humidity quir quality ..
Wire18B20
DHT22
DHT11
TMP102
MCP9808
LM35A
T5403
MS5803
BMP180
BMP280
SHT21
AM2320
BMExx
bme680
pmairquality
sgp30
ccs811
===light: white, RGB infrared, ultraviolet ..
TCS34725
as726x
IS1145
OPT3001
VEML7700
VEML6030
VEML6040
VEML6070
VEML6075
TSL2561
mlx90614
===Infrared Camera
amg88xx
===Movements, gyroscopes, Magetometers
l3g4200
mag3110
hmc5883L
bno055
mpu9255
mpu6050
lsm303
===ADC
ADC121
ina219
ina3221
ADS1x15-1 1 channel
ADS1x15 4 channel
spiMCP3008
spiMCP3008-1
PCF8591-1
PCF8591
===Pulse sensors
INPUTpulse
===Capacitouch sensors
INPUTtouch-1
INPUTtouch-4
INPUTtouch-12
INPUTtouch-16
GPIO inoputs
INPUTgpio-1
INPUTgpio-4
INPUTgpio-8
INPUTgpio-26
===Distance, prximity
ultrasoundDistance
vl503l0xDistance
vcnl4010Distance
vl6180xDistance
apds9960
===special programs for you to design
mysensors
myprogram
===GPIO outpu
OUTPUTgpio-1-ONoff
OUTPUTgpio-1 1 channel
OUTPUTgpio-4
OUTPUTgpio-10
OUTPUTgpio-26 26 channel
===Radio
TEA5767
===DAC
MCP4725
PCF8591dac
===various display types
display
neopixel
neopixel-dimmer
neopixelClock
===sprinkler
===car
combine beacons to detect status of car
===iBeacon
beacon
BLEconnect
===BLE temp sensor
BLEsensor
Wire18B20
DHT22
DHT11
TMP102
MCP9808
LM35A
T5403
MS5803
BMP180
BMP280
SHT21
AM2320
BMExx
bme680
pmairquality
sgp30
ccs811
TCS34725
as726x
IS1145
OPT3001
VEML7700
VEML6030
VEML6040
VEML6070
VEML6075
TSL2561
mlx90614
===Infrared Camera
amg88xx
l3g4200
mag3110
hmc5883L
bno055
mpu9255
mpu6050
lsm303
===ADC
ADC121
ina219
ina3221
ADS1x15-1 1 channel
ADS1x15 4 channel
spiMCP3008
spiMCP3008-1
PCF8591-1
PCF8591
===Pulse sensors
INPUTpulse
INPUTtouch-1
INPUTtouch-4
INPUTtouch-12
INPUTtouch-16
GPIO inoputs
INPUTgpio-1
INPUTgpio-4
INPUTgpio-8
INPUTgpio-26
ultrasoundDistance
vl503l0xDistance
vcnl4010Distance
vl6180xDistance
apds9960
mysensors
myprogram
===GPIO outpu
OUTPUTgpio-1-ONoff
OUTPUTgpio-4
OUTPUTgpio-10
===Radio
TEA5767
===DAC
MCP4725
PCF8591dac
display
neopixel
neopixel-dimmer
neopixelClock
===sprinkler
===car
posted v 7.85.219 on indigo store and GitHub.com/kw123.
This version allows the use of authentication keys (secure no password login) when ssh or sftp to the RPI
see viewtopic.php?f=187&t=20789 how to install and use it.
Added some functions to sprinkler device
fixed a bug with VEML7700 light sensor
posted v 7.86.220 on indigo store and GitHub.com/kw123.
Added CO2 sensor MH-Z19, it is an IR light sensor that measures absorption in the IR spectrum. this is the version with the serial to I2C converter : "10000ppm MH-Z16 NDIR CO2 Sensor with I2C/UART Interface Adaptor"
This sensor has an accuracy of ~5% (+-25ppm at not mall Co2 levels)
can be used for detection of larger changes of CO2 eg blowing at it ( values goes from 410 to ~1400ppm) , cooking detection in kitchen, CO2 in heating rooms....
Fixed a bug introduced in the last versio: parameters file was not tagged as updated on the RPI
- Screen Shot 2018-06-10 at 21.28.19.png (219.41 KiB) Viewed 4320 times
released v 7.88.222 indigo store and GitHub.com/kw123.
added:
==Lightning detection sensor as3935
this sensor-- ~ $23-- detects lighting strikes up to 30km away. Best is to use 2 or more in your house to suppress miss identified electric disturbances. The plugin sets a variables
lightningEventDate = date of last event if >=1 detectors fired
lightningEventDevices = number of detectors detecting event, only if >1
you can set the time window when 2 detectors must fire to be considered one event in config (secs to minutes)
This allows for a really nice early warning for an approaching thunderstorm
You can set sensitivities to suppress disturbances in device edit ... eg with a electric drill on/off you can simulate a lighting event holding it next to the device
there is a also a board that simulates lighting, but it works ONLY on an arduino (5V with the connectors fitting onto the arduino board)
I have tried "switch doc lab" and "playing w fusion devices " versions. The switch doc has some issues with fixed i2c address, (either 0x02 or 0x03 are fixed per device ) and they do not show up on an i2cdetect scanned you need to add a pulp resistor for i2c if this is your only i2c device.
The "playing w fusion devices" works flawless . Still waiting for some Chinese versions.
YOU NEED to set the tuning capacitor use on the board in device edit. It is written on the package (mine were: fusion 48pF, switch do 72 pF) -- don't throw the package away!
==CO2 sensor MH-Zxx (use MH-Z19 .. latest device version) IR absobption through i2c and Serial
this is the latest version of the CO2 sensors. with serial support. added several features to set sensitivity etc.
==added recovery from hanging sftp sessions
in very rare circumstances a sftp port was occupying the socket that piBeacon was using to receive messages from the RPI. The plugin now can recover from that - after a reload killing that process when restarting the socket listener
Fixed
==fixed bug for display updates, changing access rights of parameter file.
if you want to know: had to add "chown pi:pi parameters " after update of file to make it changeable to regular program (was set to root; root)
== change web server to suppress logging:
added:
Fixed
added device type "launch program"
see plugin store or GitHub/kw123
new release : 7.90.224:
added support for up to 4 floor levels (eg basement, ground floor, 1, 2. or if you are in the the US: basement, ground floor, 2. floor, 3 floor) for ibeacon position display (think that should be enough floor levels)
see indigo store or GitHub for download
new release 7.91.22
supports indigo status broadcasts , currently used by home way plugin
new version 7.92.232
bugfix and 2 new sensors:
- RG11 optical rain sensor no mechanical parts, has an option to trigger on the first rain drop and "bucket" size is variable from 0.0001 .. 0.001 .. 0.01 inches.
- si7021 temperature and humidity
v 7.93.237 posted
1. !! IMPORTANT!! BUG FIX. the parameters file was not properly updated on the RPIs with slow connections and under some circumstances
(touch temp/touchFile was not always executed and then the RPI does not know that there is a new parameters file)
2. added full support for RG11 rain sensor
