Hue Lights discussion
GlennNZ
Re: Hue Lights discussion
Post by GlennNZ »
MarcoGT wrote:I got an error today with the last version:
Hue Lights Error Error in plugin execution ExecuteAction:
File "plugin.py", line 10334, in recallScene
File "plugin.py", line 8683, in doScene
KeyError: (False,)
Saw this as well - I believe you just need to open the Action that you are trying to execute and select all the options (will be some missing) - it fixed in my case.
Glenn
yes, the field
"Select the Hue Bridge with which this Scene is associated"
is not selected.
If you do not select the bridge, it is set to be False but it should be a number 0-9
please open the action and set the bridge / hub number to 0
When I am back, I will set the the default properly.
MarcoGT
Post by MarcoGT »
Thanks a lot, I will modify then the action
v1.10.21 @ 2022-05-09
* fixed hubnumber default from False to "0" in action execution
this created an error when hubnumber was not selected in device actions edit
KeyError: (False,)
https://github.com/IndigoDomotics/Hue-L ... ag/1.10.21
ps
this will be the last version that is compatible with indigo 2022 AND earlier releases
future releases will require indigo 2022 and run under python3
Github and indigo store are currently not in sync. That should be fixed in the future by Jay/Matt when they have recovered from the indigo v 2022 dev effort
Locked
Return to “Archives”
