Hubitat Plugin Beta
autolog
Re: Hubitat Plugin Beta
Post by autolog »
MarcoGT wrote:Isn't there a device definition for a roller shutter controller?
There isn't currently in the Hubitat Plugin. Have you got one defined in Hubitat and are you publishing it via the MQTT App and if so what definition are you using?
Given we are talking about two separate systems (Indigo and Hubitat) you need to be more specific about which platform you are asking about (or both). ;)
MarcoGT
Post by MarcoGT »
I have added to Hubitat the Fibaro Roller Shutter 2 using a User Driver for the Roller Shutter 3.
In Indigo I can see it as "contact sensor", this is one of the property defined in the MQTT.
I can see in Hubitat with all the parameters
autolog
Post by autolog »
Can you do a screen grab of the published node [fully expanded] in MQTT EXplorer and post it here?
MarcoGT
Post by MarcoGT »
Here we are :)
autolog
Post by autolog »
Thanks for the screengrab. :)
Is that all there was for that node - just $properties?
As previously mentioned , the plugin doesn't currently support this type of device.
I will setup a test device and look at adding code to handle this.
This could take a week or so, :)
MarcoGT
Post by MarcoGT »
Yes in the tree I only have $properties, nothing else
MarcoGT
Post by MarcoGT »
I bought a "Silvercrest" Zigbee motion sensor and I can add it without any problem to Indigo through the plugin.
But when there is a active/incative event I get this error:
Hubitat Bridge Error            Error detected in 'hubHandler' method 'handle_message'. Line '627' has error=''key id 1254321619 not found in database''
autolog
Post by autolog »
MarcoGT wrote:Hi,
Update: Discussed with Marco over IM and a plugin restart resolved it. There is anintermittent bug that I will investigate. :)
MarcoGT
Post by MarcoGT »
Soon I have to pull the trigger and buy the roller shutter controller.
Any plan to include it in Hubitat (Zigbee) otherwise I need to buy the more expensive Z-wave and control them directly with Indigo
autolog
Post by autolog »
Hi Marco,
MarcoGT wrote:Soon I have to pull the trigger and buy the roller shutter controller.
Blinds / Shades / Roller Shutter is supported in the soon to be released Hubitat Plugin beta update. I have programmed the logic to handle this and tested it with a Hubitat Virtual Shade device. It works for that and therefore should work for a Zigbee device but obviously I haven't tested this.
Just ironing out the last few gremlins in the alpha testing. :)
MarcoGT
Post by MarcoGT »
I updated the plugin to v2022.0.1 (on two Indigo installations) and on both of them I cannot connect to the MQTT broker (it says "disconnected");
in the device preferences the "MQTT Broker Devices" is empty and if I try to save the preferences I got an error saying I have to select a broker I want to publish.
Is this anything new from the latest release?
Thank you
Marco
autolog
Post by autolog »
You need to setup a Hubitat Bridge > MQTT Broker device to point at your MQTT Broker.
Tick the boxes in MQTT Publications and MQTT Subscriptions for homie (Hubitat)
This will then appear in the pull-down for the Hub you are setting.
This was added to allow the plugin to connect to multiple brokers.
7rdr7
Post by 7rdr7 »
Hi Jon,
I just upgraded to Indigo 2022.1 and all good so far. There are a couple of plugins that I don't expect to be upgraded for future Indigo releases, one being PowerView. Given this thread, it seems hopeful that I could implement a Hubitat, use your Hubitat Plugin, and the Hubitat Hunter Douglas API to support my shades. Does this seem like a reasonable approach?
Thanks, Ron
autolog
Post by autolog »
Hi Ron,
I don't know anything about the Hubitat Hunter Douglas API. However, assuming it creates shade devices in Hubitat and that these can be exposed via the Hubitat MQTT App, then it should work OK.
If necessary, changes could be made to the Hubitat plugin but it should hopefully already support shades? :)
7rdr7
Post by 7rdr7 »
Thanks Jon! I’ll give it a try .
Return to “Hubitat”
