thanks
edit: see next post
please download this one, has some more debug info
could you run it with debug checked in plugins/fingscan/config
and send me the log file ..you might want to delete the lines with passwords
edit:- and # of ipDevices you have
edit: see next post
edit: see next post
lroust : for testing please use this one, has some for debugging output
https://www.dropbox.com/s/w58a3ijimcdaj ... Plugin.zip
with lots more more error control and debugging enabled
will check input data consistency and for other issues
will also convert from old data format to new one
I'm not able to get the plug-in version working.
Jan 13, 2014, 12:32:50 PM
Enabling plugin "fingscan 3.0.8"
Starting plugin "fingscan 3.0.8" (pid 75919)
Started plugin "fingscan 3.0.8"
fingscan startup called
fingscan inititializing fing
fingscan Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 950, in runConcurrentThread
File "plugin.py", line 345, in getfingLog
File "/System/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/posixpath.py", line 139, in getsize
<type 'exceptions.OSError'>: [Errno 2] No such file or directory: '/Users/Jeff1/Documents/fing/fing.log'
fingscan Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Disabling plugin "fingscan 3.0.8"
Stopping plugin "fingscan 3.0.8" (pid 75919)
fingscan stopConcurrentThread called
fingscan shutdown called
Stopped plugin "fingscan 3.0.8"
Jeff
Jeff
could you be so kind and check if "fing.bin" is running in "activity monitor" ( in spotlight start activity monitor )
AND have you entered your password in plugins/fingscan/configure?
edit: and please set debug to on in plugins/fingscan/configure
I checked the Activity Monitor on the machine Indigo is running on and fing.bin is running as root
My password is entered correctly in the plugin.
Here's the debug output for a few cycles
Thanks for your hard work on this!
Reloading plugin "fingscan 3.0.8"
Stopping plugin "fingscan 3.0.8" (pid 76622)
Starting plugin "fingscan 3.0.8" (pid 76693)
fingscan Debug my pid: 76693
fingscan Debug indigo variables initialized
fingscan Debug indigo initialized
fingscan Debug get password done
fingscan Debug fing pid= 3031 3032 3033
Stopping plugin "fingscan 3.0.8" (pid 76693)
Jeff
Jeff
https://www.dropbox.com/s/tkxno8vuiuetb ... Plugin.zip
please try this one... does not fix the error, but tolerates it.
please do the following:
1. in activity monitor quit fing.bin
2. install new fingscan.plugin
and thanks for the feedback
https://www.dropbox.com/s/q0o3ah7o5xl7o ... Plugin.zip
ok this one will try to handle different issues with fing:
- if no output generated: kill old fing instances and restart new one with proper parameters
- check if anything returns an error (have covered most places)
- try to recover and restart.
Sorry I didn't get around to testing the .09 version. Just downloaded the .10 version and will test in the next hour or so.
Jeff
Jeff
Just tried the .10 version and it seems to be working fine now. I did go into activity monitor and killed the running Fing.bin and Fingscan instances first. Then installed the new plugin, got verbose debug logging but nothing that looked like an actual error. I turned off the debug feature and the plug-in appears to be working fine. My device variables are updated with current data so I'd call this one good.
Just for the record, my server machine is a MacMini with 16G of memory running OSX 10.9.1, Indigo 6.0.7.
Thanks again!
Thanks again!
Jeff
Jeff
one question: are you also using smartphone radar? there might be a conflict in how fing is used.
As a matter of fact, I do also have smartphone radar. I run both but so far I'm not actually using the info for triggers, etc. I'm still getting to know all this stuff and like to monitor things for a while manually before implementing actions based on these triggers.kw123 wrote:thanks for the feedback
Not sure which I'll use, the Fing Plugin or Smartphone Radar when I do implement actions. I'm saving that decision for after I move into my new house and have things up and running there. I anticipate a bit of trial and error just getting things in the new house to function with my basic setup and would prefer not to introduce another variable while I do that.
Jeff
Jeff
here is the conflict:
fingscan uses 3 files from fing:
- the regular table view of all data ==> fing.data
- the event log, e.g a device connects ==> fing.log ++ very fast way to detect a new or up device ~ 2 seconds ++
- any other fing output i.e. error messages ==> fingeror.log
all these files are read and analyzed by fingscan to improve speed and error handling.
all of them are stored in /users/yourid/Documents/fing
smartphoneradar uses one file, I believe, in /users/yourid/
you could have 2 fing running in parallel, some overhead but it works.
now fingscan checks if fing is already running,
- if not it starts it.
- if it is running it will check if there is any new output generated by fing. if not (after 2 minutes) it "kills" all fing processes and starts fing new with setup for fingscan. That will kill also the fing instance for smartphoneradar.
That WILL disable fing for smartphoneradar.
you might say: why don't you guys get together and work it out ....
i hate the spellchecker fing always gets replaced by ring
Appreciate the additional info. I'll pay attention to which variables are updated and when between the two plug-ins.
Jeff
Jeff
fingscan and smartphone coexistence:
here an easy solution:
in smartphoneradar use the following directory for fing (see attached screenshot, used my userid)
/Users/karlwachs/Documents/fing/fing.data
then both can coexist and share data. (fingscan should be started first to make sure fing is running properly, smartphoneradar assumes you start fing outside smartphoneradar )
- smpr.tiff (120.65 KiB) Viewed 4761 times
