Of course, now that I have got my head around how it works (thanks Joe!)Colly wrote:Hi Clive,
Would you mind sharing a link to the plug you’re using?
The website is https://www.athom.tech
As for the mains plugs, they come in all flavours, UK/EU/AUS/BR/IT/Chile/Israel.ATHOM provides TASMOTA/ESPHome/Homekit pre flashed open sources smart home devices globally.
You can get them preflashed with Tasmota (which I have) and Homekit so remember that when you order.
At present I can control them via Joe's MQTTConnect and Shims, I can also control it via a Hubitat hub plugin that Jon (autolog) is coding and that works both ways, plus you can also control it by HTTP commands (Karl's ears prick up!), all we need now is for Aaron to do a Tasmota addition for his Shelly plugin!
AliExpress site for ordering is https://www.aliexpress.com/item/1005001880012237.html
Cost is £9.64 + £3.48 , 2 for £18.80 + £3.48 and 4 for £38.30 + £3.48 postage.
Quality is very good, solid and comes with a 13A fuse.
They have a lot of other Tasmota devices such as ATHOM pre flashed Tasmota 5V WiFi relay module ESP01S, ATHOM pre flashed Tasmota DHT22 Temperature Humidity Sensor Module esp8266 ,Tasmota bulbs, Tasmota wall switches......
