just some more tools:
to stop any action on the RPI:
terminal
ssh pi@ ...
sudo killall -9 python
as for the full temp directory:
The only file that can actually grow is
/home/pi/pibeacon/temp/display.inp
That file is created by actions on the indigo server and when no OUTPUT device for a monitor is defined then it can grow, as the display.py program is not running and does not clear that file.
Questions and Comment on my most ambitious PiBeacon project
Re: Questions and Comment on my most ambitious PiBeacon proj
It is pibeacon-parameters that is filled up. Deleting the directory it fills back up before any successful connections.
Can you do the killall?
The parameter file is a simple copy from the pibeacon directory
So do
sudo killall - 9 python
Do Send all to the rpi in indigo
sudo python master.py
Do
ls -l temp/
To check
So do
Do
ls -l temp/
To check
When doing a sudo python master, it says no such file exist.
I have a master.zip, but don't know how to call or unzip?
Side question: Does this mean everything went through ok :
2019-11-19 17:04:00 sbin/ping -c 1 -W 40 -o 10.0.1.41 return-code: 0
cd pibeacon
pi@raspberrypi:~/pibeacon $ sudo python master.py
19-16:29:30 master execMaster L:1637 Lv:30 ========================= starting master version: 11.3
Killed
pi@raspberrypi:~/pibeacon $ cp: error writing '/home/pi/pibeacon/temp/beacon_parameters': No space left on device
cp: error writing '/home/pi/pibeacon/temp/parameters': No space left on device
19-16:29:35 piBeaconUtils readJson L:1942 Lv:30 cBY:master Line 1939 has error=No JSON object could be decoded, fname:/home/pi/pibeacon/temp/parameters, data:
19-16:29:36 piBeaconUtils readJson L:1942 Lv:30 cBY:master Line 1939 has error=No JSON object could be decoded, fname:/home/pi/pibeacon/temp/parameters, data:
19-16:29:36 master execMaster L:1687 Lv:30 START.. indigoServer IP:>><<
19-16:29:37 master execMaster L:1698 Lv:50 hw clock info: ('', 'hwclock: Cannot access the Hardware Clock via any known method.\nhwclock: Use the --verbose option to see the details of our search for an access method.\n')
19-16:29:38 master execMaster L:2177 Lv:40 Line 1721 has error=[Errno 28] No space left on device
19-16:29:39 master <module> L:2183 Lv:30 exit at end of master
Killed
Check the size of parameters in pibeacon directory
Or should we do an online session with teamviewer?
