Ecobee Version 2.0.3 Pre-release
Re: Ecobee Version 2.0.3 Pre-release
Looking good so far... no issues with my stuff
Joe,
Upgraded to 2.0.5 and was immediately bombarded with a log full of these:
Thinking this happened when upgrading from 2.0.3 to 2.0.4 too. Had to delete all devices and add them back (along with several dependencies). Thoughts/suggestions? Thx!!
Ecobee 2 Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 139, in runConcurrentThread
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 551, in update
AttributeError: EcobeeThermostat instance has no attribute 'occupancy'- FlyingDiver
If it doesn't happen after creating the new devices then I'm not going to worry about it. This is pre-release and the device definitions are changing a lot.chobo wrote:Joe,
Thinking this happened when upgrading from 2.0.3 to 2.0.4 too. Had to delete all devices and add them back (along with several dependencies). Thoughts/suggestions? Thx!!Code: Select all
Ecobee 2 Error Error in plugin execution runConcurrentThread: Traceback (most recent call last): File "plugin.py", line 139, in runConcurrentThread File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 551, in update AttributeError: EcobeeThermostat instance has no attribute 'occupancy'
What model Ecobee(s) do you have?
Just deleted all of the devices again and I'm no longer seeing the error. Using an Ecobee 3 and three remote sensors. Will plan to do this with each pre-release update. Thanks, Joe!FlyingDiver wrote:
Believe something else is at play here... A reboot of the Indigo Server caused this error to return. No changes were made to the devices or the plugin configuration. Exact same error as above. How can I assist in troubleshooting?
- FlyingDiver
Turn on debugging, do the restart again, and post the log lines for the Ecobee plugin.chobo wrote:Believe something else is at play here... A reboot of the Indigo Server caused this error to return. No changes were made to the devices or the plugin configuration. Exact same error as above. How can I assist in troubleshooting?
Hi Joe. Here's the log from Indigo startup until first error with debugging enabled:
Loading plugin "Ecobee 2 2.0.5"
Starting plugin "Ecobee 2 2.0.5" (pid 1302)
Ecobee 2 Debug logLevel = 10
Ecobee 2 Debug macOS 10.13.6, Indigo 7.2.0
Ecobee 2 Debug updateFrequency = 420.0
Ecobee 2 Debug setting temperature scale to F
Ecobee 2 Down: Starting EcobeeThermostat Device ####
Ecobee 2 Debug getDeviceStateList, typeID = EcobeeThermostat, model = ecobee3 Smart, device_type = athenaSmart
Ecobee 2 Debug Down: EcobeeThermostat __init__
Ecobee 2 Ecobee Account: Starting EcobeeAccount Device ####
Ecobee 2 Debug getDeviceStateList, typeID = EcobeeAccount, model = , device_type = None
Ecobee 2 Debug Ecobee Account: __init__ configDone = True
Ecobee 2 Debug EcobeeAccount __init__, using refresh token = ####
Ecobee 2 Debug Token Request with refresh_token = ####
Ecobee 2 Debug Token Refresh OK, access_token = ####, refresh_token = ####, expires_in = 3599
Ecobee 2 Debug Thermostat Update OK, got info on 1 devices
Ecobee 2 Ecobee GR Occupancy: Starting OccupancySensor Device ####
Ecobee 2 Debug getDeviceStateList, typeID = OccupancySensor, model = Occupancy, device_type = None
Ecobee 2 Ecobee Remote - 1: Starting RemoteSensor Device ####
Ecobee 2 Debug getDeviceStateList, typeID = RemoteSensor, model = Remote, device_type = None
Ecobee 2 Ecobee Remote - 2: Starting RemoteSensor Device ####
Ecobee 2 Ecobee Remote - 3: Starting RemoteSensor Device ####
Ecobee 2 Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)- FlyingDiver
You have one Ecobee 3? With three remotes? And when you created the device for the Ecobee 3 (named "Down"?), did it create three Remote Sensor devices as well?
Yes, one Ecobee 3 named Down. The three remotes have been automatically created. (As you can tell, I have changed the names of all Ecobee devices to be a bit simpler).
- FlyingDiver
I think I found a potential race condition in the code. Try this version: https://github.com/FlyingDiver/Indigo-E ... /tag/2.0.6
Downloaded and installed. New error(s):FlyingDiver wrote:I think I found a potential race condition in the code. Try this version: https://github.com/FlyingDiver/Indigo-E ... /tag/2.0.6
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 479, in update
File "/Library/Application Support/Perceptive Automation/Indigo 7.2/Plugins/Ecobee 2.indigoPlugin/Contents/Server Plugin/ecobee.py", line 457, in updatable
AttributeError: EcobeeThermostat instance has no attribute 'ecobee'
OK, the fix is not going to be as easy as I had hoped.
Here's the issue. Looking at your earlier log file, you can see these lines, in this order:
As you can see, Indigo is starting the Thermostat device before the Account device. But the code is sort-of assuming that the Account device was active before it can do Thermostats. On my system, and I guess the other testers, the Account device is always getting started first. I don't think there's any way to force the order. So I need to rethink how the devices are initialized to account for this.
Makes complete sense, Joe. Have run into a somewhat similar timing issue with some of Perry's plugins loading before my Insteon interface initializes. Let me know how I can be helpful as you rethink this.FlyingDiver wrote:OK, the fix is not going to be as easy as I had hoped.
As you can see, Indigo is starting the Thermostat device before the Account device. But the code is sort-of assuming that the Account device was active before it can do Thermostats. On my system, and I guess the other testers, the Account device is always getting started first. I don't think there's any way to force the order. So I need to rethink how the devices are initialized to account for this.Code: Select all
Ecobee 2 Down: Starting EcobeeThermostat Device #### Ecobee 2 Debug Down: EcobeeThermostat __init__ Ecobee 2 Ecobee Account: Starting EcobeeAccount Device #### Ecobee 2 Debug Ecobee Account: __init__ configDone = True
shumon1212
Hi Joe, just tested Pre-release 2.0.6 with my Carrier Cor thermostats. Same exact issue as chobo. I tried to reload the plugin several times, hoping that the Account device would load first, but did not get lucky! Look forward to some more testing.
- FlyingDiver
Go back to 2.0.5. I've deleted the 2.0.6 release. That fix didn't work and just broke other stuff.shumon1212 wrote:Hi Joe, just tested Pre-release 2.0.6 with my Carrier Cor thermostats. Same exact issue as chobo. I tried to reload the plugin several times, hoping that the Account device would load first, but did not get lucky! Look forward to some more testing.
