Siri will not control a device if already in desired state
DVDDave
Re: Siri will not control a device if already in desired sta
Post by DVDDave »
Londonmark wrote:Have tried making the change, but it doesn't seem to have worked. I'm still finding that if I manually switch on lights, Siri won't switch them off.
Did you reload the plugin?
Londonmark
Post by Londonmark »
Yes. Reloaded. Restarted Indigo Server. Restarted computer. Still no dice.
Londonmark
Have now sorted it in a way that suggests something else may not be quite right...
I had originally made the change in the Indigo 7.2 plugin folder. I've now made the same change in the Indigo 7 plugin folder and it works. Something somewhere is pointing to the wrong path.
Return to “homebridge-indigo (deprecated)”
