SleepyBed IQ - Free SleepNumber Bed Monitor Plugin
Re: SleepyBed IQ - Free SleepNumber Bed Monitor Plugin
Hi-just installed plugin. All actions and triggers are working but my log keeps filling up with the below. Any ideas? Love the plugin btw.
On vs 1.1.0
SleepyBed IQ Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 160, in runConcurrentThread
File "plugin.py", line 464, in parseBedData
AttributeError: 'NoneType' object has no attribute 'data'
SleepyBed IQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
On vs 1.1.0
Interesting. I need debug log output to track that down. Enable debug logging (Plugins -> SleepyBed IQ-> Toggle Debuggjng). Then reload the plugin and paste in the log into your response from where the plugin reloads to the error.
Turned on debugging and restarted the plugin but it didn't show any additional information. I did notice that the actions work fine (change tilt, sleep # etc) however the custom states are not updated at all eg. anyoneinbed=false always.
log after reloading with debugging on:
Reloading plugin "SleepyBed IQ 1.1.0"
Stopping plugin "SleepyBed IQ 1.1.0" (pid 34075)
Stopped plugin "SleepyBed IQ 1.1.0"
Starting plugin "SleepyBed IQ 1.1.0" (pid 34119)
Started plugin "SleepyBed IQ 1.1.0"
Doesn't look like debugging was turned on. It should look something like this when debugging is on...
If you don't see that kind of output, then debug logging isn't turned on. Be sure you go to the Plugins menu, then SleepyBed IQ, then Toggle Debugging. You will see "SleepyBed IQ Turning on debug logging" appear in the Indigo log. If you don't then there's something wrong with Indio, or the SleepyBed IQ plugin has become corrupted somehow and will need to be re-installed.
SleepyBed IQ Debug Stopping device: Bedroom Bed
SleepyBed IQ Debug Starting device: Bedroom Bed
Stopping plugin "SleepyBed IQ 1.1.0" (pid 96413)
SleepyBed IQ Debug shutdown called
Starting plugin "SleepyBed IQ 1.1.0" (pid 96422)
SleepyBed IQ Debug Initializing Plugin.
SleepyBed IQ Debug startup called
SleepyBed IQ Debug Running plugin version check (if enabled).
SleepyBed IQ Debug Starting runConcurrentThread.
SleepyBed IQ Debug parseBedData called.
SleepyBed IQ Debug parseBedData: Setting device "Bedroom Bed" properties to:
com.nathansheldon.indigoplugin.sleepybed-iq : (dict)
AllowOnStateChange : false (bool)
AllowSensorValueChange : false (bool)
SupportsBatteryLevel : false (bool)
SupportsOnState : true (bool)
SupportsSensorValue : false (bool)
SupportsStatusRequest : true (bool)
accountId : <redacted> (string)
address : <redacted> (string)
base : FlexFit 1 (string)
bedId : <redacted> (string)
bedName : Sheldon Bed (string)
dualSleep : true (bool)
generation : legacy (string)
isKidsBed : false (bool)
macAddress : <redacted> (string)
model : C2 (string)
purchaseDate : 2015-02-17T21:24:56Z (string)
reference : <redacted> (string)
registrationDate : 2015-03-04T19:39:57Z (string)
returnRequestStatus : 0 (integer)
serial : (string)
sku : <redacted> (string)
status : 1 (integer)
timeZone : US/Pacific (string)
version : (string)
zipCode : <redacted> (string)
SleepyBed IQ Debug parseBedData: Setting device "Bedroom Bed" states to:
[{'value': False, 'key': 'leftIsInBed'}, {'value': 34, 'key': 'leftPressure'}, {'value': 50, 'key': 'leftSleepNumber'}, {'value': u'<redacted>', 'key': 'leftSleeperId'}, {'value': u'Elizabeth', 'key': 'leftSleeperName'}, {'value': 480, 'key': 'leftSleepGoal'}, {'value': 0, 'key': 'leftAlertId'}, {'value': u'No Alert', 'key': 'leftAlertText'}, {'value': False, 'key': 'rightIsInBed'}, {'value': 96, 'key': 'rightPressure'}, {'value': 40, 'key': 'rightSleepNumber'}, {'value': u'<redacted>', 'key': 'rightSleeperId'}, {'value': u'Nathan', 'key': 'rightSleeperName'}, {'value': 390, 'key': 'rightSleepGoal'}, {'value': 0, 'key': 'rightAlertId'}, {'value': u'No Alert', 'key': 'rightAlertText'}, {'value': False, 'key': 'anyoneInBed'}, {'value': False, 'key': 'onOffState'}, {'value': False, 'key': 'everyoneInBed'}]
model : C2 (string)
purchaseDate : 2015-02-17T21:25:12Z (string)
serial : (string)
version : (string)
SleepyBed IQ Debug Starting device: Bedroom BedRe: SleepyBed IQ - Free SleepNumber Bed Monitor Plugin
Things slowed down a bit so figured I would try and work this out. I did re-install the plugin as toggling the debug was producing the same results. Unfortunately that did nothing to resolve the problem. However I did get the following when I did the new config as a result of reload/start over.
I am not able to locate my bad when I add the the bed as a new device, the configuration drop down is empty at this point. However if I reload the plugin I get the following logs (same logs debug on or off):
But now I can see my Bed (Gerry) in the device config drop down. I can execute actions against the bed, set sleep number etc but none of the custom state information is updating and the logs file with the same above code.
Thanks for taking another look.
I enter the username/passwd and it verified, click safe and the following results on log file:
Jul 28, 2018 at 11:14:26 AM
Enabling plugin "SleepyBed IQ 1.1.0"
Starting plugin "SleepyBed IQ 1.1.0" (pid 1576)
SleepyBed IQ Your plugin version, v1.1.0, is current.
SleepyBed IQ Error Unable to connect to the SleepIQ service. Error: 'key'
SleepyBed IQ Error Unable to load the list of beds associated with this SleepIQ account. Error: 'key'Code: Select all
l 28, 2018 at 11:26:44 AM
Stopping plugin "SleepyBed IQ 1.1.0" (pid 1576)
Starting plugin "SleepyBed IQ 1.1.0" (pid 1600)
SleepyBed IQ Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)Thanks for taking another look.
Hi.
I need to see the debug log output. Toggling Debugging won't fix the problem, but it'll show me where in the code the problem begins.
The first error clearly indicates that it wasn't able to connect, though that may be intermittent if you're able to send commands to the bed successfully. The second error indicates the plugin isn't getting any data from the SleepIQ service even after connecting. Without the debug logs I cannot tell you any more about the error nor can I attempt to fix it. Please click on the Plugins menu, select SleepyBed IQ then Toggle Debugging. Then go back to the Plugins menu, select SleepyBed IQ then select Reload. Copy the entire log from the point where you reloaded to the point where you see the "AttributeError" message and paste it into your reply. I'll look at the debug logs and see if it's a problem I can fix, or at minimum make the error more helpful.
I am having problems with side of the beds, if a trigger happens or an action is executed the wrong side of the bed reacts.
Hi Rocco.
Do the sides of the bed look correct in the SleepIQ app on you phone and in the SleepIQ web site? The sides may be reversed in the SleepIQ system if you’ve disconnected and reconnected the base of the bed recently.
The settings on my phone and website are correct, they match.... any thoughts.
Another question, should I have my own account on the SleepIQ or does not make any difference.
Thanks you.
Thanks you.
Hmmm. Interesting. I'll look into fixing that. Thanks for the report.
Version 1.2.0 Posted
- Updated Sleep IQ API library to support changes in the Sleep IQ API.
- Added states for separate left and right side head and foot base position values.
- Added action to set the foot and head parts of supported bed bases to precise positions.
Hi, Nathan. I noticed a while back that actions I had set to trigger with Sleep IQ were not occurring. I assumed Sleep Number had messed with their API and was glad to see your update. I'm getting constant 404 errors concerning status info and features list. Before I posted this, I had my wife lay down on the bed and and the plug-in's status changed to on! About a minute after she got up, it turned off! Still churning out 404 errors, though.
That’s strange that it’s still partially working. We only have the one SleepNumber bed for me to test with and it’s an older model. Perhaps there are different API URLs for different models. I should also note that we’re in the United States. If you’re not, I wouldn’t be surprised if Select Comfort set up different URLs for different regions due to different privacy laws. Maybe you could turn on debug logging in the SleepyBed IQ plugin and provide some debug logs from before through after seeing that 404 error. I’m hoping that will help track down the source of the problem.
Hi Nathan,
over the weekend I was getting errors and couldn't validate my sleepIQ login. The latest update fixed that issue. However now I am having the following:
environment-4 year old sleepnumber bed in the USA and plugin has been solid. We use this plugin heavily for several use cases such as night time actions, when to turn on/off overhead fan, A bunch of wakeup action for each of us. Thanks so much or the plugin and hope you can sort out the new issues.
1. I tested the ability to set the % level for head and foot. This works great and a nice addition
2. Presence works as expected. can tell when each person is in bed or out.
3. set sleep number fails-happens using any number between 0 and 100-note I did not try every number but enough to figure the number wasn't the issue.
Nov 23, 2020 at 12:05:44 PM
Action Group test sleep bed
SleepyBed IQ Error Error in plugin execution ExecuteAction:
File "plugin.py", line 608, in setSleepNumber
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/SleepyBed IQ.indigoPlugin/Contents/Server Plugin/sleepyq/__init__.py", line 264, in set_sleepnumber
ValueError: Invalid SleepNumber, must be between 0 and 100
4. set flex presets fails using any of the presets--I also tested using slow and fast speeds with same results:
Nov 23, 2020 at 12:07:30 PM
File "plugin.py", line 637, in selectFlexFitPreset
File "/Library/Application Support/Perceptive Automation/Indigo 7.3/Plugins/SleepyBed IQ.indigoPlugin/Contents/Server Plugin/sleepyq/__init__.py", line 225, in preset
AttributeError: 'int' object has no attribute 'lower'
Nathan, just sent you a PM with the debug log.
