Two factor authentication - a couple of questions
aderrington
Re: Two factor authentication - a couple of questions
Post by aderrington »
Hi.
Is there any news on an update that will include 2FA?
I've not used the plugin before but would love to give it a go.
Thanks.
bjones
Post by bjones »
I'd love to get 2FA support for this plugin! Apple is really pushing 2FA and this plugin makes fingscan very reliable for me.
durosity
Post by durosity »
Unfortunately the plugin author briefly reappeared after some illness back in September with plans for updating his plugins but has since disappeared again. I hope he is ok.
midd
Post by midd »
So now that the FindmyFirends plugin has been released, I'm wondering if a separate icloud account with no 2FA could be setup for iFindStuff?
M4 Mac mini.
GlennNZ
Post by GlennNZ »
Hi
If you are referring to my plugin/IFindFriendsMini here:
http://forums.indigodomo.com/viewtopic. ... 22&t=19950
(Note the similar but different terms - ifindstuff, ifindfriendsMini, FindmyFriends apple service )
Then yes - it does the job of some of the functions of ifindstuff. (without needing 2fa). Particularly for me the option of showing location as address and as google map image on a control page. It does this through FindmyFriends data which ifindstuff does not access.
You can still (I believe) use iFindStuff without 2FA. (although I am not sure that is now possible on os11 and above)
I did initially look at updating ifindstuff to use this data source( hopefully temporarily until author back). But was massive change to the code which I almost didn’t recover from. Somewhat unfamiliar code base, and completely different data sets obtained - plus different way of getting them. Because of that I found it easier to move to new plugin altogether (and tidier/neater I knew what was happening )
They work differently - ifindfriendsMini uses FindmyFriends data - ifindstuff uses apple account details (so for multiple devices need to be logged in as multiple users).iFindstuff gets a lot of data - but no one has 2FA working for more than a few hours with the base library which is pyicloud (https://github.com/picklepete/pyicloud) This library is now python 3 only.
Welcome to give iFindFriendsMini a try and post any questions over there.
Glenn
Return to “iFindStuff”
