Home Assistant plugin updated for Python 3
Re: Home Assistant plugin updated for Python 3
I was thinking about those errors last night, and I think I might know what caused them. Did you originally create those devices as Binary Sensors? Then changed them to normal Sensors? That would probably cause that error.
eme jota ce
Post by eme jota ce »
Not able to see any devices from HA when creating a New Device in Indigo of Home Assistant Agent type. Thoughts?
Here's the log from Indigo with error messages.
Enabling plugin "Home Assistant Agent 2023.1.0" using API v3.0
   Starting plugin "Home Assistant Agent 2023.1.0" (pid 1611)
   Started plugin "Home Assistant Agent 2023.1.0"
Oct 5, 2023 at 3:41:46 PM
   Home Assistant Agent Error      Error in plugin execution MenuAction:
  File "plugin.py", line 551, in get_states
  File "plugin.py", line 780, in send_ws
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/websocket/_app.py", line 252, in send
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/websocket/_core.py", line 285, in send
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/websocket/_core.py", line 313, in send_frame
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/websocket/_core.py", line 527, in _send
  File "/Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages/websocket/_socket.py", line 145, in send
type: socket is already closed.
   Home Assistant Agent Error      Error in plugin execution GetUiDynamicList:
  File "plugin.py", line 237, in get_entity_list
type: ('light',)
   Home Assistant Agent            new device: Starting Agent device for entity ''
   Home Assistant Agent Error      Error in plugin execution ServerReplacedElem:
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/plugin_base.py", line 1385, in device_updated
  File "/Library/Application Support/Perceptive Automation/Indigo 2023.1/IndigoPluginHost3.app/Contents/Resources/PlugIns/plugin_base.py", line 1321, in _dispatch_device_start_comm
  File "plugin.py", line 156, in deviceStartComm
type: list index out of range
   Home Assistant Agent            new device: Stopping Agent device for entity ''
type: ('switch',)
type: ('binary_sensor',)
Just installed the plugin, an hour ago. Have restarted the HA on Rpi and restarted the Indigo Mac a couple times, each.
Here's what I see in Terminal when executing the commands listed earlier in this thread:
ham@MacMiniM2Server ~ % pip3 show websocket-client
Version: 1.6.3
Summary: WebSocket client for Python with low level API options
Home-page: https://github.com/websocket-client/websocket-client.git
Author: liris
Author-email: [email protected]
License: Apache-2.0
Location: /Library/Frameworks/Python.framework/Versions/3.10/lib/python3.10/site-packages
Requires:
Required-by:
gham@MacMiniM2Server ~ % which pip3
/Library/Frameworks/Python.framework/Versions/3.10/bin/pip3
ham@MacMiniM2Server ~ % pip3 list
Package                                           Version
aiofiles                                          23.2.1
anyio                                             4.0.0
async-timeout                                     4.0.3
certifi                                           2023.7.22
cffi                                              1.16.0
cryptography                                      41.0.1
cycler                                            0.12.0
dictdiffer                                        0.9.0
exceptiongroup                                    1.1.3
fonttools                                         4.43.0
h11                                               0.14.0
httpcore                                          0.16.3
httptools                                         0.6.0
httpx                                             0.23.3
idna                                              3.4
ifaddr                                            0.2.0
janus                                             1.0.0
Jinja2                                            3.1.2
kiwisolver                                        1.4.5
MarkupSafe                                        2.1.1
matplotlib                                        3.5.1
multidict                                         6.0.4
numpy                                             1.24.4
packaging                                         23.2
Pillow                                            10.0.1
pip                                               21.2.4
pycparser                                         2.21
pyobjc                                            8.4.1
pyobjc-core                                       8.4.1
pyobjc-framework-Accessibility                    8.4.1
pyobjc-framework-Accounts                         8.4.1
pyobjc-framework-AddressBook                      8.4.1
pyobjc-framework-AdServices                       8.4.1
pyobjc-framework-AdSupport                        8.4.1
pyobjc-framework-AppleScriptKit                   8.4.1
pyobjc-framework-AppleScriptObjC                  8.4.1
pyobjc-framework-ApplicationServices              8.4.1
pyobjc-framework-AppTrackingTransparency          8.4.1
pyobjc-framework-AudioVideoBridging               8.4.1
pyobjc-framework-AuthenticationServices           8.4.1
pyobjc-framework-AutomaticAssessmentConfiguration 8.4.1
pyobjc-framework-Automator                        8.4.1
pyobjc-framework-AVFoundation                     8.4.1
pyobjc-framework-AVKit                            8.4.1
pyobjc-framework-BusinessChat                     8.4.1
pyobjc-framework-CalendarStore                    8.4.1
pyobjc-framework-CallKit                          8.4.1
pyobjc-framework-CFNetwork                        8.4.1
pyobjc-framework-ClassKit                         8.4.1
pyobjc-framework-CloudKit                         8.4.1
pyobjc-framework-Cocoa                            8.4.1
pyobjc-framework-Collaboration                    8.4.1
pyobjc-framework-ColorSync                        8.4.1
pyobjc-framework-Contacts                         8.4.1
pyobjc-framework-ContactsUI                       8.4.1
pyobjc-framework-CoreAudio                        8.4.1
pyobjc-framework-CoreAudioKit                     8.4.1
pyobjc-framework-CoreBluetooth                    8.4.1
pyobjc-framework-CoreData                         8.4.1
pyobjc-framework-CoreHaptics                      8.4.1
pyobjc-framework-CoreLocation                     8.4.1
pyobjc-framework-CoreMedia                        8.4.1
pyobjc-framework-CoreMediaIO                      8.4.1
pyobjc-framework-CoreMIDI                         8.4.1
pyobjc-framework-CoreML                           8.4.1
pyobjc-framework-CoreMotion                       8.4.1
pyobjc-framework-CoreServices                     8.4.1
pyobjc-framework-CoreSpotlight                    8.4.1
pyobjc-framework-CoreText                         8.4.1
pyobjc-framework-CoreWLAN                         8.4.1
pyobjc-framework-CryptoTokenKit                   8.4.1
pyobjc-framework-DataDetection                    8.4.1
pyobjc-framework-DeviceCheck                      8.4.1
pyobjc-framework-DictionaryServices               8.4.1
pyobjc-framework-DiscRecording                    8.4.1
pyobjc-framework-DiscRecordingUI                  8.4.1
pyobjc-framework-DiskArbitration                  8.4.1
pyobjc-framework-DVDPlayback                      8.4.1
pyobjc-framework-EventKit                         8.4.1
pyobjc-framework-ExceptionHandling                8.4.1
pyobjc-framework-ExecutionPolicy                  8.4.1
pyobjc-framework-ExternalAccessory                8.4.1
pyobjc-framework-FileProvider                     8.4.1
pyobjc-framework-FileProviderUI                   8.4.1
pyobjc-framework-FinderSync                       8.4.1
pyobjc-framework-FSEvents                         8.4.1
pyobjc-framework-GameCenter                       8.4.1
pyobjc-framework-GameController                   8.4.1
pyobjc-framework-GameKit                          8.4.1
pyobjc-framework-GameplayKit                      8.4.1
pyobjc-framework-ImageCaptureCore                 8.4.1
pyobjc-framework-IMServicePlugIn                  8.4.1
pyobjc-framework-InputMethodKit                   8.4.1
pyobjc-framework-InstallerPlugins                 8.4.1
pyobjc-framework-InstantMessage                   8.4.1
pyobjc-framework-Intents                          8.4.1
pyobjc-framework-IntentsUI                        8.4.1
pyobjc-framework-IOSurface                        8.4.1
pyobjc-framework-iTunesLibrary                    8.4.1
pyobjc-framework-KernelManagement                 8.4.1
pyobjc-framework-LatentSemanticMapping            8.4.1
pyobjc-framework-LaunchServices                   8.4.1
pyobjc-framework-libdispatch                      8.4.1
pyobjc-framework-LinkPresentation                 8.4.1
pyobjc-framework-LocalAuthentication              8.4.1
pyobjc-framework-LocalAuthenticationEmbeddedUI    8.4.1
pyobjc-framework-MailKit                          8.4.1
pyobjc-framework-MapKit                           8.4.1
pyobjc-framework-MediaAccessibility               8.4.1
pyobjc-framework-MediaLibrary                     8.4.1
pyobjc-framework-MediaPlayer                      8.4.1
pyobjc-framework-MediaToolbox                     8.4.1
pyobjc-framework-Metal                            8.4.1
pyobjc-framework-MetalKit                         8.4.1
pyobjc-framework-MetalPerformanceShaders          8.4.1
pyobjc-framework-MetalPerformanceShadersGraph     8.4.1
pyobjc-framework-MetricKit                        8.4.1
pyobjc-framework-MLCompute                        8.4.1
pyobjc-framework-ModelIO                          8.4.1
pyobjc-framework-MultipeerConnectivity            8.4.1
pyobjc-framework-NaturalLanguage                  8.4.1
pyobjc-framework-NetFS                            8.4.1
pyobjc-framework-Network                          8.4.1
pyobjc-framework-NetworkExtension                 8.4.1
pyobjc-framework-NotificationCenter               8.4.1
pyobjc-framework-OpenDirectory                    8.4.1
pyobjc-framework-OSAKit                           8.4.1
pyobjc-framework-OSLog                            8.4.1
pyobjc-framework-PassKit                          8.4.1
pyobjc-framework-PencilKit                        8.4.1
pyobjc-framework-Photos                           8.4.1
pyobjc-framework-PhotosUI                         8.4.1
pyobjc-framework-PreferencePanes                  8.4.1
pyobjc-framework-PushKit                          8.4.1
pyobjc-framework-Quartz                           8.4.1
pyobjc-framework-QuickLookThumbnailing            8.4.1
pyobjc-framework-ReplayKit                        8.4.1
pyobjc-framework-SafariServices                   8.4.1
pyobjc-framework-SceneKit                         8.4.1
pyobjc-framework-ScreenCaptureKit                 8.4.1
pyobjc-framework-ScreenSaver                      8.4.1
pyobjc-framework-ScreenTime                       8.4.1
pyobjc-framework-ScriptingBridge                  8.4.1
pyobjc-framework-SearchKit                        8.4.1
pyobjc-framework-Security                         8.4.1
pyobjc-framework-SecurityFoundation               8.4.1
pyobjc-framework-SecurityInterface                8.4.1
pyobjc-framework-ServiceManagement                8.4.1
pyobjc-framework-ShazamKit                        8.4.1
pyobjc-framework-Social                           8.4.1
pyobjc-framework-SoundAnalysis                    8.4.1
pyobjc-framework-Speech                           8.4.1
pyobjc-framework-SpriteKit                        8.4.1
pyobjc-framework-StoreKit                         8.4.1
pyobjc-framework-SyncServices                     8.4.1
pyobjc-framework-SystemConfiguration              8.4.1
pyobjc-framework-SystemExtensions                 8.4.1
pyobjc-framework-UniformTypeIdentifiers           8.4.1
pyobjc-framework-UserNotifications                8.4.1
pyobjc-framework-UserNotificationsUI              8.4.1
pyobjc-framework-VideoSubscriberAccount           8.4.1
pyobjc-framework-VideoToolbox                     8.4.1
pyobjc-framework-Virtualization                   8.4.1
pyobjc-framework-Vision                           8.4.1
pyobjc-framework-WebKit                           8.4.1
pyparsing                                         3.1.1
python-dateutil                                   2.8.2
rfc3986                                           1.5.0
sanic                                             22.6.1
sanic-routing                                     22.3.0
sanic-session                                     0.8.0
scipy                                             1.8.0
setuptools                                        58.1.0
six                                               1.16.0
sniffio                                           1.3.0
typing_extensions                                 4.8.0
ujson                                             5.8.0
uvloop                                            0.17.0
websocket-client                                  1.6.3
websockets                                        10.4
zeroconf                                          0.115.2
WARNING: You are using pip version 21.2.4; however, version 23.2.1 is available.
You should consider upgrading via the '/Library/Frameworks/Python.framework/Versions/3.10/bin/python3.10 -m pip install --upgrade pip' command.
Turn on debug logging, then restart the plugin, then post that part of the log (up to first error).
Then delete the HAA devices from Indigo, restart again, and if no errors, attempt to create a device. Then post that log.
eme jota ce
Thank You.
FlyingDiver wrote:Turn on debug logging, then restart the plugin, then post that part of the log (up to first error).
Oct 5, 2023 at 9:13:42 PM
   Home Assistant Agent Debug      logLevel = 10
Oct 5, 2023 at 9:14:00 PM
   Disabling plugin "Home Assistant Agent 2023.1.0"
   Stopping plugin "Home Assistant Agent 2023.1.0" (pid 1611)
   Home Assistant Agent Debug      stop_concurrent_thread called
   Home Assistant Agent Debug      shutdown called
   Stopped plugin "Home Assistant Agent 2023.1.0"
   Starting plugin "Home Assistant Agent 2023.1.0" (pid 21672)
   Home Assistant Agent Debug      startup called
   Home Assistant Agent Debug      Connecting to 'ws://10.0.1.201:8123/api/websocket'
   Home Assistant Agent Error      exception in device_start_comm(new device): list index out of range
   Home Assistant Agent Debug      Service Rustic Oaks._home-assistant._tcp.local. of type _home-assistant._tcp.local. state changed: ServiceStateChange.Added
   Home Assistant Agent Debug      Found HA Servers: {'Rustic Oaks._home-assistant._tcp.local.': {'ip_address': '10.0.1.201', 'port': 8123}}
   Home Assistant Agent Debug      Websocket on_error: Connection to remote host was lost.
Oct 5, 2023 at 9:16:00 PM
   Home Assistant Agent Debug      get_entity_list: filter = 'light', typeId = 'HAdimmerType', valuesDict = <indigo.Dict object at 0x110287bc0>, targetId = 446348291
type: ('light',)
Delete the Indigo device called "new device", which has an empty entity (address) field. Then try again.
eme jota ce
Thanks. Trying again from the top of the instructions
Disabled plugin (which just has one device called HAA Light Test), then restarted it. Here's the log:
   Starting plugin "Home Assistant Agent 2023.1.0" (pid 59778)
   Home Assistant Agent            HAA Light Test: Starting Agent device for entity ''
   Home Assistant Agent Error      exception in device_start_comm(HAA Light Test): list index out of range
Deleted the HAA Light Test device, restarted the plugin. No errors reported in red text but last line in log says "Connection to remote host was lost," below:
Oct 6, 2023 at 7:14:44 AM
   Home Assistant Agent            HAA Light Test: Stopping Agent device for entity ''
Oct 6, 2023 at 7:15:01 AM
   Stopping plugin "Home Assistant Agent 2023.1.0" (pid 59778)
   Starting plugin "Home Assistant Agent 2023.1.0" (pid 60003)
Created New Device, and see the following error in log:
Oct 6, 2023 at 7:17:16 AM
   Home Assistant Agent Debug      get_entity_list: filter = 'light', typeId = 'HAdimmerType', valuesDict = <indigo.Dict object at 0x10988fc30>, targetId = 233094297
type: ('light',)
Oct 6, 2023 at 7:17:50 AM
Well, there's two problems here. One is that the connection to the Home Assistant server is getting dropped, which will break everything else after that. And it's dropping before it even authenticates.
After that, you're creating a new device with an empty address field. Are you selecting a device from the menu popup? Or manually entering the entity address? If the websocket connection wasn't running, then plugin never got the entity list from the HA server, so the menu popup is empty.
So forget about creating any devices until you figure out why the Home Assistant server won't let the plugin connect. My guess is it's a firewall on the rPi, or maybe the Mac.
When it's working properly, you should see log entries like this after plugin restart:
   Home Assistant Agent Debug      Connecting to 'ws://192.168.111.8:8123/api/websocket'
   Home Assistant Agent Debug      Websocket connected
   Home Assistant Agent Debug      Websocket got auth_required for ha_version 2023.10.0, sending auth_token
   Home Assistant Agent Debug      Websocket got auth_ok for ha_version 2023.10.0
   Home Assistant Agent Debug      Websocket reply Success for subscribe_events
   Home Assistant Agent Debug      Websocket reply Success for get_states
Make sure the Home Assistant server is running and stable before you restart the plugin. Don't restart Home Assistant.
eme jota ce
FlyingDiver wrote:When it's working properly, you should see log entries like this after plugin restart:
Thanks, again, FlyingDiver.
Have I missed some place to input a HA user/password in this plugin, or is the Access token al that's needed?
eme jota ce wrote: Have I missed some place to input a HA user/password in this plugin, or is the Access token al that's needed?
Just the access token.
eme jota ce
Thank you. It must be a problem with my HA configuration. For example, I setup LetsEncrypt and dynamic DNS in Home Assistant and wonder if that or something else is preventing the connection on the LAN. When this plugin runs, it tries to contact the HA several times, eventually causing me to get locked out of HA. .
Will update if I find a fix....
Thanks again, FlyingDiver.
eme jota ce
As an update to the connection issues I described above,
Commenting out the LetsEncrypt and DuckDNS remote access lines I had added to HA YAML file for remote access allowed the Home Assistant Agent plugin in Indigo to connect to HA, load many of the devices from HA, and integrate them into Indigo.
Because I hope to transition to use the Indigo Reflector for remote access, it doesn't seem like a significant loss to keep HA on the LAN without (secure) remote access.
I use a CloudFlare tunnel for remote access to the HA server.
EagleDTW
Post by EagleDTW »
Hi Joe,
The sensors have always had values such as numbers so probably never existed as binary_snesors. I realized how to create input_booleans for a couple of other devices instead of them having their values be switches which was causing a bunch of problems. To that end my arm_disarm input boolean is throwing this error: Error device "Arm&Disarm" state key onOffState not defined --which leads me to believe that these errors may be more on the side of HA not defining the values correctly for something coming across in these entities?
-Daniel
EagleDTW wrote:Hi Joe,
-Daniel
At this point I really have no idea what's going on with your system. I can't keep up with multiple users posting about different problems in the same forum thread.
Please open a GitHub issue and include debug logs, annotated as needed to point out the issue you're seeing.
Locked
Return to “Home Assistant Agent”
