Home Assistant plugin updated for Python 3
Different Computers
Re: Home Assistant plugin updated for Python 3
Post by Different Computers »
FlyingDiver wrote:
Different Computers wrote:You weren't asking me, but I was able to look. I don't see anything labeled "device class" on the entity page, but maybe this helps?
What is that data dump from? I don't recognize it.
that's from URL:8123/config/devices/device/ and it's the Roku TV integration
Ah. I don't fetch or use that info in the HAA plugin. I only use the device state info reported over the websocket API.
I'd also point out that that's a "Roku" specific integration, using a custom device type. Not a generic TV device. That would require a Roku only device in the HAA plugin, which isn't going to happen.
EagleDTW
Post by EagleDTW »
Hi Joe,
This is already an open issue on github (issue #2), I had been perusing the logs and I'm not sure that they're as clean as I would like put up to github or anywhere else with personal data included, what are your suggestions?
Thank you,
Daniel
EagleDTW wrote:Hi Joe,
Thank you,
Daniel
Add the Entity information (plugin menu command) to the GitHub issue. I should be able to track it down from there.
EagleDTW
Post by EagleDTW »
Done! Thanks, Joe!!
-Daniel
Pre-release available for testing: https://github.com/FlyingDiver/Indigo-H ... g/2023.1.0
This version adds "generic" devices so you can see and trigger on the state of ANY Home Assistant entity. I think. Needs testing.
Should also fix all reported issues with state errors.
EagleDTW
Post by EagleDTW »
will check in your 2023.1.0 - the overall Indigo release 2023.1.0 unfortunately there are a lot of plugins that are not yet compatible 7/24 that I may be forced to wait on updates over the next couple of weeks.
EagleDTW wrote:will check in your 2023.1.0 - the overall Indigo release 2023.1.0 unfortunately there are a lot of plugins that are not yet compatible 7/24 that I may be forced to wait on updates over the next couple of weeks.
Purely coincidence that the plugin version matches the most recent Indigo release. This plugin does not require the latest Indigo.
I don't think there's many plugins that are not already Python3 that are actively being worked on (to make them Python3 compatible). If you're using ones that the developer isn't actively working on, you should be looking for alternatives.
Colly
Post by Colly »
Quick check of latest version and I can see both TV's with various different states.
EagleDTW
Post by EagleDTW »
Hi Joe,
Unfortunately did not fix and in fact even more sensors are coming up as undefined and giving error although fully present in HA.
Newer error too:
Action Collection Error state id (sensorValue) isn't available for device model Home Assistant sensor - action not configured correctly
And this warning when Insteon button press:
Received INSTEON "Atrium Light Master" on
Home Assistant Agent Warning Websocket unknown message type: {"id": 1, "type": "event", "event": {"event_type": "insteon.button_on", "data": {"address": "451a", "group": 1}, "origin": "LOCAL", "time_fired": "2023-10-04T17:12:56.075133+00:00", "context": {"id": "01HBXTV9GB7W383KTHZS", "parent_id": null, "user_id": null}}}
Daniel
I need to see the actual error message.
EagleDTW wrote: Newer error too:
What action are you attempting? Did you confirm the action is properly configured?
EagleDTW wrote: And this warning when Insteon button press:
Well, that's a warning not really an error. But I can add that message type to the ignore list. I'm not sure I want to know why you're bridging Insteon devices to Home Assistant.
jay (support)
Post by jay (support) »
EagleDTW wrote:unfortunately there are a lot of plugins that are not yet compatible 7/24 that I may be forced to wait on updates over the next couple of weeks.
Our recommendations...
EagleDTW
Post by EagleDTW »
Hi @Jay,
I added to that topic to see what if any traction updates may come for 2023.1, thanks for the advice!
-Daniel
EagleDTW
Post by EagleDTW »
Hi Joe,
These are the errors:
Oct 4, 2023 at 5:09:32 PM
   Error                           device "Foobot AQI" state key sensorValue not defined (ignoring update request)
   Error                           device "US AQI" state key sensorValue not defined (ignoring update request)
...+ Jewish Calendar sensors
Oct 4, 2023 at 5:15:00 PM
I think the action is something internal to Indigo because I don't do anything with any of the sensor values except for converting a sensor value for the Jewish Calendar in HA that have some sensors in wrong timezone and format that get manipulated with a script in Indigo schedules.
Insteon is peculiar as I'm not doing anything with the HA instances of them and have a PLM for Indigo to control them separately but seems like when they're activated that they send a warning message as well.
Thank you,
Daniel
I really don't know why those sensor devices are having a problem. I would delete the Indigo devices and recreate them. If that doesn't fix it, open a new GitHub issue and include the output of the entity dump menu command. Also screen shots of the device config dialog, and the device info (right click menu).
For the second error, post the Python script you're running in that action.
And the Insteon thing isn't really an error. It's a warning from the plugin that I received an event message from HA that I don't recognize. I've added it to the internal ignore list, so it'll go away in the next update.
Locked
Return to “Home Assistant Agent”
