Home Assistant plugin updated for Python 3
Re: Home Assistant plugin updated for Python 3
Also, just restarting the plug-in will refresh the device lists. But it’s an asynchronous process, so it might be a minute or two depending on home many HA devices and how fast the HA server is.
EagleDTW
Post by EagleDTW »
Helper switches and binary sensors and regular sensors for the most part out of the 20 that I had defined and enabled the pull down only allows 3 to be defined in the list and chosen, others are not selectable and do not change with the entity state anymore since the upgrade - should I be switching back a version until this is robustly filled out?
There’s something wrong with your setup. I don’t know what. I’m going to need screenshots and debug logs to figure it out. Please open a GitHub issue.
EagleDTW
Post by EagleDTW »
Looks like 3-4 restarts of both the HA plugin and HA server over about an hour has it filling everything out...hopefully all situated now - glad you got this updated for the new Indigo requirements! Thank you!!
EagleDTW
Post by EagleDTW »
I am having a little issue with my 2 AQI sensors showing this error:
Home Assistant Agent Error Websocket state_changed exception: 'key lastUpdated not found in dict'
and this:
Error device "Foobot AQI" state key sensorValue not defined (ignoring update request)
Did both of those Indigo devices exist from the previous plugin version? If so, edit the device and re-save it.
EagleDTW
Post by EagleDTW »
I've resaved these and HA has their values listed, but in Indigo they come up as empty and it is now affecting another set of sensors as well.
Open an issue in GitHub and include a full debug log starting with a plugin restart. Also include the device info from the plugin menu after the plugin has been running for a couple minutes.
Colly
Post by Colly »
Joe,
Is it possible to bring a TV device across from HA? I've linked up 2 TV's in HA so would love to bring them into Indigo.
Colly
Colly wrote:Joe,
Colly
I have a planned update that will let you get the states of an arbitrary HA device, which would let you trigger Indigo events based on TV state changes. I have no current plans to add control of those devices from Indigo.
I am curious, what HA device class are those?
Different Computers
Post by Different Computers »
You weren't asking me, but I was able to look. I don't see anything labeled "device class" on the entity page, but maybe this helps?
  "home_assistant": {
    "installation_type": "Home Assistant Core",
    "version": "2023.6.3",
    "dev": false,
    "hassio": false,
    "virtualenv": true,
    "python_version": "3.11.4",
    "docker": false,
    "arch": "x86_64",
    "timezone": "America/New_York",
    "os_name": "Linux",
    "os_version": "6.2.0-33-generic",
    "run_as_root": true
  "custom_components": {},
  "integration_manifest": {
    "domain": "roku",
    "name": "Roku",
    "codeowners": [
      "@ctalkington"
    "config_flow": true,
    "documentation": "https://www.home-assistant.io/integrations/roku",
    "homekit": {
      "models": [
        "3820X",
        "3810X",
        "4660X",
        "7820X",
        "C105X",
        "C135X"
    "integration_type": "device",
    "iot_class": "local_polling",
    "loggers": [
      "rokuecp"
    "quality_scale": "silver",
    "requirements": [
      "rokuecp==0.18.0"
    "ssdp": [
        "st": "roku:ecp",
        "manufacturer": "Roku",
        "deviceType": "urn:roku-com:device:player:1-0"
    "is_built_in": true
  "data": {
    "entry": {
      "data": {
        "host": "192.168.23.255"
      "unique_id": "REDACTED"
    "data": {
      "info": {
        "name": "Bar TV",
        "brand": "TCL",
        "device_type": "tv",
        "device_location": "Bar",
        "model_name": "75S535",
        "model_number": "A120X",
        "serial_number": "REDACTED4EGHL",
        "version": "12.0.0",
        "network_type": "ethernet",
        "network_name": null,
        "ethernet_support": true,
        "ethernet_mac": "c0:79:82:04:65:3a",
        "wifi_mac": "38:c8:04:a3:9d:e1",
        "supports_airplay": true,
        "supports_find_remote": false,
        "supports_private_listening": true,
        "supports_wake_on_wlan": true,
        "headphones_connected": false
      "state": {
        "available": true,
        "standby": true,
        "at": "2023-09-27T15:16:35.183373"
      "apps": [
          "app_id": "31012",
          "name": "Vudu Movie & TV Store",
          "version": "2.0.62",
          "screensaver": false
          "app_id": "tvinput.hdmi4",
          "name": "AV\u00a0receiver",
          "version": "1.0.0",
          "app_id": "551012",
          "name": "Apple TV",
          "version": "13.5.56",
          "app_id": "13535",
          "name": "Plex - Free Movies & TV",
          "version": "7.8.4",
          "app_id": "13",
          "name": "Prime Video",
          "version": "14.1.2023062023",
          "app_id": "291097",
          "name": "Disney Plus",
          "version": "1.36.2023090701",
          "app_id": "637193",
          "name": "Apple Music",
          "app_id": "61322",
          "name": "Max",
          "version": "55.1.0",
          "app_id": "2285",
          "name": "Hulu",
          "version": "6.74.1",
          "app_id": "75619",
          "name": "HGTV GO",
          "version": "7.0.20",
          "app_id": "12",
          "name": "Netflix",
          "version": "5.1.120088002",
          "app_id": "151908",
          "name": "The Roku Channel",
          "version": "9.3.10",
          "app_id": "75617",
          "name": "Food Network GO",
          "app_id": "31440",
          "name": "Paramount Plus",
          "version": "8.6.20230907",
          "app_id": "593099",
          "name": "Peacock TV",
          "version": "4.9.32",
          "app_id": "73357",
          "name": "Freeform - Movies & TV Shows",
          "version": "5.18.1",
          "app_id": "tvinput.dtv",
          "name": "Live\u00a0TV",
          "version": "1.0.0",
          "app_id": "tvinput.hdmi2",
          "name": "PlayStation 5",
          "version": "1.0.0",
          "app_id": "27536",
          "name": "CBS News",
          "version": "5.26.2",
          "app_id": "837",
          "name": "YouTube",
          "version": "2.22.105005058",
          "app_id": "143924",
          "name": "IP Camera Viewer - Basic",
          "version": "5.3.0",
          "app_id": "tvinput.hdmi3",
          "name": "HDMI\u00a03",
          "version": "1.0.0",
          "app_id": "tvinput.cvbs",
          "name": "AV",
          "version": "1.0.0",
          "app_id": "52937",
          "name": "CAMERA",
          "version": "1.0.0",
          "app_id": "43465",
          "name": "Fubo: Watch Live TV & Sports",
          "version": "4.8.2600",
      "channels": [],
      "app": null,
      "channel": null,
      "media": null
Colly
Post by Colly »
Help from others is always welcome. I kept meaning to get back to this.
Is below what you are referring to?
media_player.sony_xr_65a80j
Colly
Post by Colly »
Ideally from my perspective I’d be able to turn on/off, mute, volume up/down. Happy to live without latter if that was too much work.
Different Computers wrote:You weren't asking me, but I was able to look. I don't see anything labeled "device class" on the entity page, but maybe this helps?
What is that data dump from? I don't recognize it.
Colly wrote:Help from others is always welcome. I kept meaning to get back to this.
Yeah, that's what I need. That's an entity_id, which is the device class plus the unique identifier. I thought it might be media_player, but I wasn't sure.
media_player is a very complicated device type, which has no matching device type in Indigo. So that'll be a lot of work.
Locked
Return to “Home Assistant Agent”
