HI!
I have been using the Shelly plugin since its release with great success.
With the recent purchase of a new house with a European-style gas boiler, instead of using a 24VAC interposing relay,I am in the process of using a Shelly Uni to interface the unusual 18VDC boiler thermostat circuit with the 24VAC Ecobee thermostat. The immediate implementation does not require integration of the Shelly with Indigo (the Ecobee will be used with the Ecobee2 plugin!), but it would be handy to have the Uni in Indigo to allow use of the devices's temperature sensing and second input and output for associated devices.
However, it appears after a forum search that the Shelly plugin does not (yet?) have support for the Uni. Is there any chance that this might be included in a forthcoming update? Or will I need to to use the Shelly MQTT or MQTT Shims plugins to implement this. For simplicity of configuration and use, the Shelly plugin is my preference.
If there are no plans for its addition to the Shelly plugin, I note that another use has opted for the Uni for a garage door opener, so some notes on experiences in integration with Indigo would be of interest.
mclass
