"Send port for process has no send right"
This forum is where we've moved the discussions of the original Airfoil plugin that shipped with Indigo 5/6 (and is now open source). You may continue to ask questions in this subforum, just make sure that it's not about the new Airfoil Pro plugin that shipped with Indigo 7 (ask those questions below).
Gelfin
Post by Gelfin »
I'm using Yosemite 10.10.1, Indigo 6.0.18, Airfoil Plugin 1.1.7 with Airfoil 4.8.11. The plugin appears to be working as advertised, but whenever the plugin is enabled, it spams my system.log with thousands and thousands of these:
11:18:39 AM IndigoPluginHost: AppleEvents: Send port for process has no send right, port=( port:34271/0x85df rev:1,send:0,d:0 limit:5) (findOrCreate()/AEMachUtils.cp #526) com.apple.root.default-qos.overcommit
I'm probably switching to a Sonos setup for audio distribution soon anyway, but in the meantime, any idea what I could poke to make this better behaved?
matt (support)
Re: "Send port for process has no send right"
Post by matt (support) »
Looks like another Yosemite gremlin. I'm not sure what is causing it, but there are reports of that being logged in lots of apps under Yosemite (including Automator).
manwithavan
Post by manwithavan »
Same here.
bgaiser7
Post by bgaiser7 »
Any news on this? It's killing me!
IndigoPluginHost[6861]: AppleEvents: Send port for process has no send right, port=( port:30575/0x776f rcv:1,send:0,d:0 limit:5) (findOrCreate()/AEMachUtils.cp #526) com.apple.root.default-qos.overcommit
M
ay 20 15:41:17 --- last message repeated 989 times ---
Really is filling logs...
palantir
Post by palantir »
Yep. Same issue here.
MacMini on OS-X 10.10.4, Running Indigo 6.1.2
Airfoil plug-in 1.1.9
Airfoil 4.8.14
When I stop the Airfoil plug-in, the error messages stop... Anyone any clue?
Ronald
Return to “Old Airfoil Discussions”
