Recommended Z-Wave Lock?
Re: Recommended Z-Wave Lock?
The Yale lock arrived and added to Indigo without a problem.
I did try to mess around with sending raw Z-Wave commands to add users, but no luck. I did get things that Indigo can already to do work (like lock the door: [98 1 255]) But add user didn't work, at least not the way I tried it. I tried [99 1 10 1 2 2 2 2] and [99 1 10 1 0x050 0x050 0x050 0x050] both should set user 10 to PIN 2222, but no luck. I was able to delete the PIN for user 10 with [98 1 10 0], so I assume I just have a syntax error.
- matt (support)
- Site Admin
- Contact:
That's interesting. It worked (so thanks for that!). I was also able to delete the PIN with the 99 1 10 0 command. Indigo confirms removing the PIN, but not adding it.matt (support) wrote:For PIN 2222, try:
[99 1 10 1 50 50 50 50]
Also, the log entry is confusing to me:
Z-Wave sent "Yale Side Door" raw command [63 01 0A 01 32 32 32 32]Insteon / Z-Wave / Bryant Evolution Connex /Tesla / Roomba / Elk M1 / SiteSage / Enphase Enlighten / NOAA Alerts
- matt (support)
- Site Admin
- Contact:
I'm not if the module isn't reporting back the PIN add or if it Indigo just isn't logging it. If you turn on debug logging (in Z-Wave Configure) then you can see what raw messages the lock is sending.
Indigo always logs raw commands in hexadecimal (and does not prefix them with 0x).
Here is the Yale Locks Z-Wave Developer User & Reference Guide:
http://www.pepper1.net/zwavedb/uploads/ ... dd8b72.pdf
For whomever decides to undertake this, FYI, Indigo doesn't set the current date/time on the lock and that's required for timed access.
FYI, here are the logs from adding and deleting a user PIN:
Z-Wave Debug RCVD nonceFetch: node 046
Z-Wave Debug SENT nonceReport: 01 11 00 13 2E 0A 98 80 0D 8B D1 FB 9A 71 75 27 25 11 E0
Z-Wave Debug RCVD encryptedPacket: 00 71 05 70 0A (decrypted)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0A 00 04 00 2E 04 71 05 70 0A FF
Z-Wave Debug . . requestAlarmSensorStatus: node 046, endpoint None, cmdClass 71, type 112, value 10, classSubKey 71700A
Z-Wave sent "Yale Side Door" raw command [63 01 0A 00]
Z-Wave Debug SENT nonceReport: 01 11 00 13 2E 0A 98 80 20 0F 2F AE 37 BA 32 8D 25 18 60
Z-Wave Debug RCVD encryptedPacket: 00 71 05 21 0A (decrypted)
Z-Wave Debug RCVD requestAlarmSensorStatus: 01 0A 00 04 00 2E 04 71 05 21 0A FF
Z-Wave Debug . . requestAlarmSensorStatus: node 046, endpoint None, cmdClass 71, type 33, value 10, classSubKey 71210A
Z-Wave received "Yale Side Door" status update is onInsteon / Z-Wave / Bryant Evolution Connex /Tesla / Roomba / Elk M1 / SiteSage / Enphase Enlighten / NOAA Alerts
I'll have a quick read later and see if I fancy this.
- durosity
Of course you fancy this.howartp wrote:I'll have a quick read later and see if I fancy this.
On a complete unrelated side note remember I know where you live.
That's the spirit.howartp wrote:I'll have a quick read later and see if I fancy this.
What features would you expect of this?
I have no lock to test against, so I'll be coding blind and I don't know what features the inferior competitors provide.
I believe I just heard Durosity volunteer to send you a shiny new Z-wave lock!howartp wrote:I have no lock to test against, so I'll be coding blind and I don't know what features the inferior competitors provide.
Terry
My Wishlist:howartp wrote:What features would you expect of this?
- User PIN management: Keep a database of 4 & 8 digit PINs and be able to add & delete to all enrolled locks from Indigo. If accessible via an Indigo Schedule, this would allow temporary entrance for contractors, without having to use the onboard temporary access command. Almost everyone would use this since PIN management via the keypad is painful.
- Set the device specific features (automatic relock, all code lockout, privacy, etc.
I can think of two people who will test the code.
Well if he doesn't, I'll pop round and remove it from his door!roussell wrote:I believe I just heard Durosity volunteer to send you a shiny new Z-wave lock!howartp wrote:I have no lock to test against, so I'll be coding blind and I don't know what features the inferior competitors provide.
Terry
(Having sent OTA ZWave commands to it, to add me a custom PIN so I can open it first)
Having glanced at the PDF, setting pins and the other features should be ok.
I'm not volunteering to maintain a database of codes in the first release, but I'll provide ability to set and clear the codes yourself.
