I installed the eclipse broker with the command line:
The broker image is in the Docker desktop Container, and indicates that it is running.docker run -it -d --name genbrkr -p 192.168.3.201883 -v /Users/rss/Documents/mosquitto/mosquitto.conf:/Users/rss/Documents/mosquitto/config/mosquitto.conf eclipse-mosquitto:2
The generic broker is not available to the Indigo MQTT trigger.
If it is possible to use this broker, what is the Indigo configuration?
Note: using ports 1883:1883 and localhost was similarly unproductive.
