Hue Lights discussion
jroach
Re: Hue Lights discussion
Post by jroach »
OK, that's easy enough...I thought I had to get into the developers area of my bridge:(
The name of the two devices are:
- Hall by bathroom downstairs
- Back door by Laundry room
Here is the log: (I trimmed the ned of th blog for brevity but searched on the two names above to make certain they were included at least once)
Oct 31, 2019 at 11:34:21 AM
Hue Lights Turning on debug logging
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.2/api/G-rSEQMMIb815fW3 ... dY0/lights
Hue Lights Debug Got response {u'42': {u'swversion': u'5.127.1.26420', u'name': u'Master bath left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-09T17:53:13'}, u'uniqueid': u'00:17:88:01:02:20:e6:0d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'43': {u'swversion': u'5.127.1.26420', u'name': u'Master bath right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-09T17:53:15'}, u'uniqueid': u'00:17:88:01:02:30:5f:9a-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'25': {u'swversion': u'5.127.1.26420', u'name': u'Family Room mica lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:13'}, u'uniqueid': u'00:17:88:01:10:36:9c:2c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'26': {u'swversion': u'1.46.13_r26312', u'name': u'Tripod lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T23:34:19'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:e6:c8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 113, u'ct': 385}, u'manufacturername': u'Philips', u'swconfigid': u'28823930', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'27': {u'swversion': u'1.46.13_r26312', u'name': u'Front Porch ambiance', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:50'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:50:0c:fc-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362}, u'manufacturername': u'Philips', u'swconfigid': u'28823930', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'20': {u'swversion': u'5.127.1.26581', u'name': u'Front porch color', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:46:38'}, u'uniqueid': u'00:17:88:01:00:d9:28:36-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'21': {u'swversion': u'5.127.1.26420', u'name': u'Front door hall 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:04:07'}, u'uniqueid': u'00:17:88:01:10:50:63:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'22': {u'swversion': u'5.127.1.26420', u'name': u'Front door hall 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:18'}, u'uniqueid': u'00:17:88:01:10:50:7a:a3-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'46': {u'swversion': u'1.55.8_r28815', u'name': u'Hall by bathroom downstairs', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-30T20:20:20'}, u'productid': u'Philips-LWV002-1-ST19CFDLv1', u'uniqueid': u'00:17:88:01:06:c2:e6:43-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 530}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue filament bulb', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'DDBBC361', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'vintagebulb'}, u'type': u'Dimmable light', u'modelid': u'LWV002'}, u'44': {u'swversion': u'5.127.1.26581', u'name': u'Patio by Pizza Oven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-19T18:49:39'}, u'uniqueid': u'00:17:88:01:00:d9:1a:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'45': {u'swversion': u'1.55.8_r28815', u'name': u'Back door by Laundry room', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-30T20:20:18'}, u'productid': u'Philips-LWO002-1-G25CFDLv1', u'uniqueid': u'00:17:88:01:08:14:b4:b4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 530}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue filament bulb', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'447445D5', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'vintagebulb'}, u'type': u'Dimmable light', u'modelid': u'LWO002'}, u'28': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:45'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:7d:7c:17-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'29': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:22'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:b0:f5-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'40': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen table 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-10T08:04:18'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:fb:16:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'9DC82D22', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'41': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen table 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-10T08:04:12'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:bc:d5:92-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'9DC82D22', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'1': {u'swversion': u'5.127.1.26420', u'name': u'Front Room Tiffany', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-18T09:14:26'}, u'uniqueid': u'00:17:88:01:02:30:06:73-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 126, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'5.127.1.26420', u'name': u'Entertainment Center Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:42:17'}, u'uniqueid': u'00:17:88:01:02:79:f9:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Entertainment Center Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:50:01'}, u'uniqueid': u'00:17:88:01:00:f4:35:3f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Library 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:15'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:73:d3:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Library 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:36:35'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:60:d1:ae-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 2, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Library 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:35:52'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:60:d1:84-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'6': {u'swversion': u'5.127.1.26420', u'name': u'Basement Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:42:34'}, u'uniqueid': u'00:17:88:01:00:eb:db:04-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7827, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5609, 0.3811], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 215}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'9': {u'swversion': u'5.127.1.26420', u'name': u'Basement Landing', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:51'}, u'uniqueid': u'00:17:88:01:02:09:83:79-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Library 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:34:00'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:73:f8:67-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'11': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:30:59'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:32:d3:55-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2034, 0.3244], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'10': {u'swversion': u'5.127.1.26420', u'name': u'Kitchen Sink', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:41:43'}, u'uniqueid': u'00:17:88:01:10:56:0f:aa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 13401, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5052, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'39': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen under counter', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-06T08:57:17'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:4b:dd:d6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'12': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:33:28'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:34:34:ce-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2034, 0.3244], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'15': {u'swversion': u'5.127.1.26420', u'name': u'Upstairs hall color', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:41:14'}, u'uniqueid': u'00:17:88:01:00:eb:ee:9b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 153, u'sat': 251}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'16': {u'swversion': u'5.127.1.26420', u'name': u'Upstairs hall ambiance', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:04:37'}, u'uniqueid': u'00:17:88:01:02:09:68:11-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'19': {u'swversion': u'5.127.1.26420', u'name': u'Butler 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:40:53'}, u'uniqueid': u'00:17:88:01:02:20:e5:1f-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'18': {u'swversion': u'5.127.1.26420', u'name': u'Butler 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:40:59'}, u'uniqueid': u'00:17:88:01:10:26:db:b3-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'31': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:30:53'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:d6:0f-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'30': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:30:38'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:b0:b0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'37': {u'swversion': u'5.127.1.26420', u'name': u'Patio South Side Color Spot', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-08T09:09:00'}, u'uniqueid': u'00:17:88:01:03:97:fc:ba-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'36': {u'swversion': u'5.127.1.26420', u'name': u'Patio North Side Color Spot', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-08T09:09:06'}, u'uniqueid': u'00:17:88:01:03:97:fc:4d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'35': {u'swversion': u'1.46.13_r26312', u'name': u'Bar light right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T23:34:25'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:04:eb:1f:fe-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 102, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'34': {u'swversion': u'1.46.13_r26312', u'name': u'Bar light left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:36:15'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:04:eb:1e:9e-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 102, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'32': {u'swversion': u'5.127.1.26581', u'name': u'Hall Light Stairway Landing', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:47:24'}, u'uniqueid': u'00:17:88:01:00:d9:1a:22-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 153, u'sat': 251}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}}
Hue Lights Debug Loaded lights list - {u'42': {u'swversion': u'5.127.1.26420', u'name': u'Master bath left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-09T17:53:13'}, u'uniqueid': u'00:17:88:01:02:20:e6:0d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'43': {u'swversion': u'5.127.1.26420', u'name': u'Master bath right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-09T17:53:15'}, u'uniqueid': u'00:17:88:01:02:30:5f:9a-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'25': {u'swversion': u'5.127.1.26420', u'name': u'Family Room mica lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:13'}, u'uniqueid': u'00:17:88:01:10:36:9c:2c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'26': {u'swversion': u'1.46.13_r26312', u'name': u'Tripod lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T23:34:19'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:e6:c8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 113, u'ct': 385}, u'manufacturername': u'Philips', u'swconfigid': u'28823930', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'27': {u'swversion': u'1.46.13_r26312', u'name': u'Front Porch ambiance', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:50'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:50:0c:fc-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362}, u'manufacturername': u'Philips', u'swconfigid': u'28823930', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'20': {u'swversion': u'5.127.1.26581', u'name': u'Front porch color', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:46:38'}, u'uniqueid': u'00:17:88:01:00:d9:28:36-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'21': {u'swversion': u'5.127.1.26420', u'name': u'Front door hall 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:04:07'}, u'uniqueid': u'00:17:88:01:10:50:63:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'22': {u'swversion': u'5.127.1.26420', u'name': u'Front door hall 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:18'}, u'uniqueid': u'00:17:88:01:10:50:7a:a3-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'46': {u'swversion': u'1.55.8_r28815', u'name': u'Hall by bathroom downstairs', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-30T20:20:20'}, u'productid': u'Philips-LWV002-1-ST19CFDLv1', u'uniqueid': u'00:17:88:01:06:c2:e6:43-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 530}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue filament bulb', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'DDBBC361', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'vintagebulb'}, u'type': u'Dimmable light', u'modelid': u'LWV002'}, u'44': {u'swversion': u'5.127.1.26581', u'name': u'Patio by Pizza Oven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-19T18:49:39'}, u'uniqueid': u'00:17:88:01:00:d9:1a:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'45': {u'swversion': u'1.55.8_r28815', u'name': u'Back door by Laundry room', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-30T20:20:18'}, u'productid': u'Philips-LWO002-1-G25CFDLv1', u'uniqueid': u'00:17:88:01:08:14:b4:b4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 530}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue filament bulb', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'447445D5', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'vintagebulb'}, u'type': u'Dimmable light', u'modelid': u'LWO002'}, u'28': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:45'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:7d:7c:17-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'29': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:22'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:b0:f5-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'40': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen table 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-10T08:04:18'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:fb:16:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'9DC82D22', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'41': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen table 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-10T08:04:12'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:bc:d5:92-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'9DC82D22', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'1': {u'swversion': u'5.127.1.26420', u'name': u'Front Room Tiffany', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-18T09:14:26'}, u'uniqueid': u'00:17:88:01:02:30:06:73-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 126, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'5.127.1.26420', u'name': u'Entertainment Center Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:42:17'}, u'uniqueid': u'00:17:88:01:02:79:f9:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Entertainment Center Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:50:01'}, u'uniqueid': u'00:17:88:01:00:f4:35:3f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Library 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:15'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:73:d3:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Library 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:36:35'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:60:d1:ae-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 2, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Library 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:35:52'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:60:d1:84-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'6': {u'swversion': u'5.127.1.26420', u'name': u'Basement Door', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:42:34'}, u'uniqueid': u'00:17:88:01:00:eb:db:04-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7827, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5609, 0.3811], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 215}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'9': {u'swversion': u'5.127.1.26420', u'name': u'Basement Landing', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:51'}, u'uniqueid': u'00:17:88:01:02:09:83:79-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'8': {u'swversion': u'1.46.13_r26312', u'name': u'Library 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:34:00'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:73:f8:67-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'11': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:30:59'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:32:d3:55-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2034, 0.3244], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'10': {u'swversion': u'5.127.1.26420', u'name': u'Kitchen Sink', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:41:43'}, u'uniqueid': u'00:17:88:01:10:56:0f:aa-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 800, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 13401, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5052, 0.4152], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT007'}, u'39': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen under counter', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-06T08:57:17'}, u'productid': u'Philips-LST002-1-LedStripsv3', u'uniqueid': u'00:17:88:01:04:4b:dd:d6-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 40, u'maxlumen': 1600, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue lightstrip plus', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'A25796CB', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'huelightstrip'}, u'type': u'Extended color light', u'modelid': u'LST002'}, u'12': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:33:28'}, u'productid': u'Philips-LCT014-1-A19ECLv4', u'uniqueid': u'00:17:88:01:02:34:34:ce-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2034, 0.3244], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'swconfigid': u'56D25448', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT014'}, u'15': {u'swversion': u'5.127.1.26420', u'name': u'Upstairs hall color', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:41:14'}, u'uniqueid': u'00:17:88:01:00:eb:ee:9b-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 153, u'sat': 251}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'16': {u'swversion': u'5.127.1.26420', u'name': u'Upstairs hall ambiance', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:04:37'}, u'uniqueid': u'00:17:88:01:02:09:68:11-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'19': {u'swversion': u'5.127.1.26420', u'name': u'Butler 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:40:53'}, u'uniqueid': u'00:17:88:01:02:20:e5:1f-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'18': {u'swversion': u'5.127.1.26420', u'name': u'Butler 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:40:59'}, u'uniqueid': u'00:17:88:01:10:26:db:b3-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 454}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'31': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:30:53'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:d6:0f-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'30': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 3', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:30:38'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:b0:b0-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'37': {u'swversion': u'5.127.1.26420', u'name': u'Patio South Side Color Spot', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-08T09:09:00'}, u'uniqueid': u'00:17:88:01:03:97:fc:ba-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'36': {u'swversion': u'5.127.1.26420', u'name': u'Patio North Side Color Spot', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-01-08T09:09:06'}, u'uniqueid': u'00:17:88:01:03:97:fc:4d-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 250, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color spot', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'spotbulb'}, u'type': u'Extended color light', u'modelid': u'LCT003'}, u'35': {u'swversion': u'1.46.13_r26312', u'name': u'Bar light right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T23:34:25'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:04:eb:1f:fe-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 102, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'34': {u'swversion': u'1.46.13_r26312', u'name': u'Bar light left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:36:15'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:04:eb:1e:9e-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 102, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'32': {u'swversion': u'5.127.1.26581', u'name': u'Hall Light Stairway Landing', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:47:24'}, u'uniqueid': u'00:17:88:01:00:d9:1a:22-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 153, u'sat': 251}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}}
Hue Lights Debug Starting parseAllHueLightsData.
Hue Lights Debug parseAllHueLightsData: There are 39 lights on the Hue bridge and 34 Indigo devices controlling Hue devices.
Hue Lights Debug Starting updateGroupsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.2/api/G-rSEQMMIb815fW3 ... dY0/groups
Hue Lights Debug Got response {u'11': {u'name': u'Custom group for $lights', u'lights': [u'10', u'11', u'12', u'15', u'16', u'18', u'19', u'21', u'22', u'28', u'29', u'30', u'31', u'32'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'bri': 254, u'ct': 153, u'sat': 251}}, u'10': {u'name': u'discoAGroupEven', u'lights': [u'2'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 1, u'ct': 153, u'sat': 204}}, u'13': {u'name': u'Master bedroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'14': {u'name': u'Night light', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'1': {u'name': u'Family room', u'lights': [u'2', u'3', u'4', u'5', u'7', u'8', u'25', u'26', u'34', u'35'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 38402, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 102, u'ct': 366, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'3': {u'name': u'Hall', u'lights': [u'46', u'15', u'16', u'32', u'22', u'21'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': False, u'hue': 34076, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'bri': 254, u'ct': 153, u'sat': 251}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'Kitchen', u'lights': [u'40', u'41', u'11', u'12', u'28', u'29', u'30', u'31', u'18', u'19', u'10', u'39'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'bri': 254, u'ct': 454, u'sat': 203}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Front room', u'lights': [u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 126, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'4': {u'name': u'Security', u'lights': [u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'7': {u'name': u'Bathroom', u'lights': [u'42', u'43'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'hs', u'bri': 254, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}, u'6': {u'name': u'Outdoor', u'lights': [u'45', u'44', u'6', u'20', u'27', u'36', u'37'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'bri': 1, u'ct': 500, u'sat': 192}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'discoAGroupOdd', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 1, u'ct': 153, u'sat': 204}}, u'8': {u'name': u'discoAGroup', u'lights': [u'2', u'3'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 1, u'ct': 153, u'sat': 204}}}
Hue Lights Debug Loaded groups list - {u'11': {u'name': u'Custom group for $lights', u'lights': [u'10', u'11', u'12', u'15', u'16', u'18', u'19', u'21', u'22', u'28', u'29', u'30', u'31', u'32'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': True, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 34076, u'colormode': u'xy', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'bri': 254, u'ct': 153, u'sat': 251}}, u'10': {u'name': u'discoAGroupEven', u'lights': [u'2'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 1, u'ct': 153, u'sat': 204}}, u'13': {u'name': u'Master bedroom', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'14': {u'name': u'Night light', u'lights': [], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'alert': u'none'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'1': {u'name': u'Family room', u'lights': [u'2', u'3', u'4', u'5', u'7', u'8', u'25', u'26', u'34', u'35'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 38402, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 102, u'ct': 366, u'sat': 204}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'3': {u'name': u'Hall', u'lights': [u'46', u'15', u'16', u'32', u'22', u'21'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': False, u'hue': 34076, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.3144, 0.3301], u'bri': 254, u'ct': 153, u'sat': 251}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Hallway'}, u'2': {u'name': u'Kitchen', u'lights': [u'40', u'41', u'11', u'12', u'28', u'29', u'30', u'31', u'18', u'19', u'10', u'39'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'bri': 254, u'ct': 454, u'sat': 203}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Kitchen'}, u'5': {u'name': u'Front room', u'lights': [u'1'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 126, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'4': {u'name': u'Security', u'lights': [u'9'], u'state': {u'any_on': False, u'all_on': False}, u'action': {u'on': False, u'bri': 1, u'alert': u'select'}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'7': {u'name': u'Bathroom', u'lights': [u'42', u'43'], u'state': {u'any_on': True, u'all_on': True}, u'action': {u'on': True, u'alert': u'select', u'colormode': u'hs', u'bri': 254, u'ct': 366}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Bathroom'}, u'6': {u'name': u'Outdoor', u'lights': [u'45', u'44', u'6', u'20', u'27', u'36', u'37'], u'state': {u'any_on': True, u'all_on': False}, u'action': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'bri': 1, u'ct': 500, u'sat': 192}, u'recycle': False, u'sensors': [], u'type': u'Room', u'class': u'Other'}, u'9': {u'name': u'discoAGroupOdd', u'lights': [u'3'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 1, u'ct': 153, u'sat': 204}}, u'8': {u'name': u'discoAGroup', u'lights': [u'2', u'3'], u'state': {u'any_on': False, u'all_on': False}, u'recycle': False, u'sensors': [], u'type': u'LightGroup', u'action': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'bri': 1, u'ct': 153, u'sat': 204}}}
Hue Lights Debug Starting parseAllHueGroupsData.
Hue Lights Debug Starting updateSensorsList.
Hue Lights Debug Starting parseAllHueSensorsData.
Hue Lights Debug Starting updateLightsList.
Hue Lights Debug Sending command to bridge: http://192.168.1.2/api/G-rSEQMMIb815fW3 ... dY0/lights
Hue Lights Debug Got response {u'42': {u'swversion': u'5.127.1.26420', u'name': u'Master bath left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-09T17:53:13'}, u'uniqueid': u'00:17:88:01:02:20:e6:0d-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': True, u'colormode': u'ct', u'alert': u'select', u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'ct': 366}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW004'}, u'43': {u'swversion': u'5.127.1.26420', u'name': u'Master bath right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-09T17:53:15'}, u'uniqueid': u'00:17:88:01:02:30:5f:9a-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': True, u'reachable': False, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'25': {u'swversion': u'5.127.1.26420', u'name': u'Family Room mica lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:13'}, u'uniqueid': u'00:17:88:01:10:36:9c:2c-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 77, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'26': {u'swversion': u'1.46.13_r26312', u'name': u'Tripod lamp', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T23:34:19'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:11:e6:c8-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 113, u'ct': 385}, u'manufacturername': u'Philips', u'swconfigid': u'28823930', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'27': {u'swversion': u'1.46.13_r26312', u'name': u'Front Porch ambiance', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:50'}, u'productid': u'Philips-LTW015-1-A19CTv2', u'uniqueid': u'00:17:88:01:03:50:0c:fc-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 800, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance lamp', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 362}, u'manufacturername': u'Philips', u'swconfigid': u'28823930', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW015'}, u'20': {u'swversion': u'5.127.1.26581', u'name': u'Front porch color', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:46:38'}, u'uniqueid': u'00:17:88:01:00:d9:28:36-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 14988, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.4575, 0.4101], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 366, u'sat': 141}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'21': {u'swversion': u'5.127.1.26420', u'name': u'Front door hall 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:04:07'}, u'uniqueid': u'00:17:88:01:10:50:63:cd-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'22': {u'swversion': u'5.127.1.26420', u'name': u'Front door hall 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-16T09:05:18'}, u'uniqueid': u'00:17:88:01:10:50:7a:a3-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'46': {u'swversion': u'1.55.8_r28815', u'name': u'Hall by bathroom downstairs', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-30T20:20:20'}, u'productid': u'Philips-LWV002-1-ST19CFDLv1', u'uniqueid': u'00:17:88:01:06:c2:e6:43-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 530}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue filament bulb', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'DDBBC361', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'vintagebulb'}, u'type': u'Dimmable light', u'modelid': u'LWV002'}, u'44': {u'swversion': u'5.127.1.26581', u'name': u'Patio by Pizza Oven', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-19T18:49:39'}, u'uniqueid': u'00:17:88:01:00:d9:1a:da-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 600, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7826, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.5416, 0.3807], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 500, u'sat': 192}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT001'}, u'45': {u'swversion': u'1.55.8_r28815', u'name': u'Back door by Laundry room', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-10-30T20:20:18'}, u'productid': u'Philips-LWO002-1-G25CFDLv1', u'uniqueid': u'00:17:88:01:08:14:b4:b4-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 530}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue filament bulb', u'state': {u'on': True, u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'alert': u'select'}, u'manufacturername': u'Philips', u'swconfigid': u'447445D5', u'config': {u'function': u'decorative', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'vintagebulb'}, u'type': u'Dimmable light', u'modelid': u'LWO002'}, u'28': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:45'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:7d:7c:17-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'29': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen Recessed 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:22'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:03:21:b0:f5-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'40': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen table 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-10T08:04:18'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:fb:16:f9-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'9DC82D22', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'41': {u'swversion': u'1.46.13_r26312', u'name': u'Kitchen table 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2019-09-10T08:04:12'}, u'productid': u'Philips-LCT016-1-A19ECLv5', u'uniqueid': u'00:17:88:01:03:bc:d5:92-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.6915, 0.3083], [0.17, 0.7], [0.1532, 0.0475]], u'mindimlevel': 1000, u'maxlumen': 800, u'colorgamuttype': u'C'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color lamp', u'state': {u'on': False, u'hue': 7613, u'colormode': u'ct', u'effect': u'none', u'alert': u'select', u'xy': [0.5051, 0.4151], u'reachable': True, u'mode': u'homeautomation', u'bri': 254, u'ct': 454, u'sat': 203}, u'manufacturername': u'Philips', u'swconfigid': u'9DC82D22', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'sultanbulb'}, u'type': u'Extended color light', u'modelid': u'LCT016'}, u'1': {u'swversion': u'5.127.1.26420', u'name': u'Front Room Tiffany', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-18T09:14:26'}, u'uniqueid': u'00:17:88:01:02:30:06:73-0b', u'capabilities': {u'control': {u'mindimlevel': 2000, u'maxlumen': 800}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue white lamp', u'state': {u'on': False, u'reachable': True, u'mode': u'homeautomation', u'bri': 126, u'alert': u'select'}, u'manufacturername': u'Philips', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'omnidirectional', u'archetype': u'classicbulb'}, u'type': u'Dimmable light', u'modelid': u'LWB006'}, u'3': {u'swversion': u'5.127.1.26420', u'name': u'Entertainment Center Right', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-19T09:42:17'}, u'uniqueid': u'00:17:88:01:02:79:f9:fe-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 2000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': True}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'2': {u'swversion': u'5.127.1.26581', u'name': u'Entertainment Center Left', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-13T09:50:01'}, u'uniqueid': u'00:17:88:01:00:f4:35:3f-0b', u'capabilities': {u'control': {u'ct': {u'max': 500, u'min': 153}, u'colorgamut': [[0.675, 0.322], [0.409, 0.518], [0.167, 0.04]], u'mindimlevel': 5000, u'maxlumen': 630, u'colorgamuttype': u'B'}, u'streaming': {u'renderer': True, u'proxy': False}, u'certified': True}, u'productname': u'Hue color downlight', u'state': {u'on': False, u'hue': 38402, u'colormode': u'hs', u'effect': u'none', u'alert': u'select', u'xy': [0.2876, 0.2617], u'reachable': True, u'mode': u'homeautomation', u'bri': 1, u'ct': 153, u'sat': 204}, u'manufacturername': u'Philips', u'config': {u'function': u'mixed', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Extended color light', u'modelid': u'LCT002'}, u'5': {u'swversion': u'1.46.13_r26312', u'name': u'Library 4', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:31:15'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:73:d3:d9-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'4': {u'swversion': u'1.46.13_r26312', u'name': u'Library 2', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:36:35'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:60:d1:ae-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 2, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config': {u'function': u'functional', u'startup': {u'configured': True, u'mode': u'safety'}, u'direction': u'downwards', u'archetype': u'floodbulb'}, u'type': u'Color temperature light', u'modelid': u'LTW011'}, u'7': {u'swversion': u'1.46.13_r26312', u'name': u'Library 1', u'swupdate': {u'state': u'noupdates', u'lastinstall': u'2018-12-08T09:35:52'}, u'productid': u'Philips-LTW011-1-BR30CTv1', u'uniqueid': u'00:17:88:01:02:60:d1:84-0b', u'capabilities': {u'control': {u'mindimlevel': 1000, u'maxlumen': 680, u'ct': {u'max': 454, u'min': 153}}, u'streaming': {u'renderer': False, u'proxy': False}, u'certified': True}, u'productname': u'Hue ambiance downlight', u'state': {u'on': False, u'colormode': u'ct', u'alert': u'select', u'reachable': True, u'mode': u'homeautomation', u'bri': 230, u'ct': 366}, u'manufacturername': u'Philips', u'swconfigid': u'CC6469FE', u'config':
nsheldon
Re: Hue Lights discussion
Post by nsheldon »
Version 1.7.14 Posted
  • Added support for the Hue LED filament ST19 Edison bulb and Hue LED filament G25 globe bulb.
jroach
Post by jroach »
Nathan,
Thanks for the update. I'll download today!
I hope that Indigo provides you a little something for this plug-in...if not, is there a way to donate to the cause?
Best.
nsheldon
Post by nsheldon »
Hi Joe.
The Hue Lights plugin is purely a voluntary project of mine. No one pays me for it, though Jay and Matt do provide some early access to beta Indigo versions for testing the plugin ahead of time.
I appreciate any donation you feel like offering. You can send a donation using the “Show your appreciation” link in the plugin store page for the Hue Lights plugin at http://www.indigodomo.com/pluginstore/21/
jroach
Post by jroach »
done
thanks again
nsheldon
Post by nsheldon »
Thank you!
I’m glad the plugin is useful for you.
PeterGlyn
Post by PeterGlyn »
Hi
Have recently bought a couple of Hue Smart Plug. I am running version 1.7.14
When I select On/OFF device neither of the plugs appear for selection. I have no issues with all the other 50+ lights, sensors etc across my two hue hubs
Is there anything I can try to rectify this?
Cheers
nsheldon
Post by nsheldon »
That's odd. It should show up, unless Philips have different model IDs for different regions (which is quite possible). Unfortunately, they don't list their Smart Plug in the API yet, so support is entirely based on input from Hue Lights plugin users like you.
While there's likely nothing you can do in the plugin to make it work yet, I can add support if you provide Hue Lights plugin debug logs and the names you've given the Smart Plugs in the Hue app. Use the same instructions I gave Joe in my 30 Oct 2019 22:26 post in this thread to get the debug logs (though, that timestamp is probably relative to my local time, -7 hours GMT). Once I have that and the Smart Plug names I can add support (assuming the model ID is the problem).
nsheldon
Post by nsheldon »
Version 1.7.15 Posted
  • Added support for a new Hue Ambiance E26 bulb.
  • Added support for a new Hue LED filament G93 globe bulb.
  • Added support for the UK variant of the Hue Smart Plug.
MarcoGT
Post by MarcoGT »
Are all the IKEA products already working? What about the IKEA Smart Plug?
nsheldon
Post by nsheldon »
Only a few IKEA products are currently recognized by the plugin (the IKEA Smart Plug isn't one of them yet), but support can be added for any IKEA product you pair with the Hue bridge. I just need the debug log output and device names like the previous posts.
nsheldon
Post by nsheldon »
Version 1.7.16 Posted
  • Added support for a new Hue LED spiral filament ST64 bulb.
  • Added support for the on/off OSRAM Smart+ Plug.
  • Fixed plugin log issue that caused plugin log files to grow very large.
  • Fixed the Innr On/Off Plug-in module so it appears in the On/Off Devices. If you already have the module set up with Hue Lights in Indigo, you MUST edit the device in Indigo and redefine it, otherwise it won't work after updating to version 1.7.16.
nsheldon
Post by nsheldon »
Version 1.7.17 Posted
  • Added support for a new Philips A19 dimmable light.
MarcoGT
Post by MarcoGT »
What about IKEA motion sensor? Is it basically the same process or could it be that it is not recognized as motion sensor in Indigo?
nsheldon
Post by nsheldon »
Motion sensors might be more difficult to add support for. In my experience with different motion sensors, each manufacturer and each model usually has some unique feature or unusual behavior that has to be accounted for in the programming. Adding support for lights in the plugin would be relatively simple as long as you can pair them with the Hue bridge, but for sensor type devices such as motion sensors and switches, even if they're paired to the Hue bridge, I'd need to have the hardware in hand so I could test everything before adding support. If you're willing to donate a motion sensor and willing to wait weeks (or possibly even months depending on how busy I am with my day job), I'd be willing to try adding support. Keep in mind, though, if the motion sensor can't be paired to the Hue bridge, I can't add support (I don't have time available to add support for an entirely new communications bridge system).
Locked
Return to “Archives”
