HomeKit Bridge's Future, Etc
Sun Mar 31, 2019 6:00 pm
Colorado4Wheeler offline
I'm still around guys! As some of you know I own multiple businesses and when things get busy they get busy! I've been quite buried with work projects and still have plans to give a lot of love to HomeKit Bridge but it's really so stable that there hasn't been a pressing need. As for my other plugins there are always new things I can add (and that is the pitfall of plugin development, if you aren't careful the work never ends. I typically go through spurts where I have down time on my work projects and just get obsessed with massive Indigo plugin updates and hopefully that time will pop up again really soon.
I just wanted to pop in and let you know that I'm alive and well and hopefully updates across the board are coming soon. I've been lucky that HKB has been so stable - so much so that I still do 99.9% of everything in my home automation via Siri on my iOS devices and HomePods. And Indigo has been so stable that I just hardly even have to open it anymore.
While I miss coming here and hanging out on the forums all day I just haven't had spare coding time but I try to answer the Git issues when I can and get on here to answer some questions too :).
Mon Apr 01, 2019 8:00 am
WagnerOne offline
Re: HomeKit Bridge's Future, Etc
Thanks for all your hard work and great plug-ins! :D
Mon Apr 01, 2019 8:44 am
Thanks for the alive "ping" :-), and thanks for all your contributions to the Indigo community!
Sat Apr 27, 2019 8:35 am
Trwesq offline
Just wanted to also express my thanks for HomeKit Bridge. It’s a fantastic plug-in and has greatly enhanced my enjoyment of Indigo.
Tue Jan 21, 2020 2:58 am
Mirko offline
Homekit Bridge Plug-in PROBLEM
HI
Until I upgraded Indigo to 7.4 Homekit worked flawless.
I upgraded a short time ago but recently I saw an endless:
HomeKit Bridge Attempting to start '3 hoog All OFF'
Trigger Homekit 3 hoog ALL OFF RUNNING
HomeKit Bridge Server '3 hoog All OFF' has successfully started, you can use your HomeKit apps or Siri for this accessory
HomeKit Bridge Attempting to start 'Homekit kitchen LED 3'
Trigger Homekit Kitchen LED 3 RUNNING[
repeating again and again after a few seconds.
I disabled the plugin. It would only quit after a force quit from the plugin itself.
I cannot configure the plugin anymore and I cannot add more devices. The wheel keeps turning....
I have Indigo running on a headless MacMini 10.12.6
I downloaded the plugin again, reinstalled it but nothing changed.
o 0
Hue Lights received "VSE HAL HUE Motion sensor TEMPeratuur " sensor update to 16.8 ºC
Z-Wave received "073 - TH boven aanrecht Ultraviolet" sensor update to 0
Hue Lights received "Hue Motion Sensor 1 BADKAMER 2 HOOG BAD TEMPERATUUR" sensor update to 18.9 ºC
Error (client) timeout waiting for plugin response from com.eps.indigoplugin.homekit-bridge for request UiGetValues1
Error (client) timeout waiting for plugin response from com.eps.indigoplugin.homekit-bridge for request CallPluginFunc
Error (client) runDialogForMenuAction() caught exception: NSInvalidArgumentException -- *** -[__NSPlaceholderDictionary initWithObjects:forKeys:count:]: attempt to insert nil object from objects[0]
HomeKit Bridge Server 'Homekit kitchen LED 3' has successfully started, you can use your HomeKit apps or Siri for this accessory
Z-Wave received "089 - Luminance VSE Talud" sensor update to 0 lux
Z-Wave received "037 - Luminance Talud UP" sensor update to 15 lux
HomeKit Bridge Attempting to start '1ste verdieping alle lichten uit'
Trigger Homekit 1ste verdieping alle lichten uit RUNNING
HomeKit Bridge Server '1ste verdieping alle lichten uit' has successfully started, you can use your HomeKit apps or Siri for this accessory
Z-Wave received "074 - Temperature - KUBUS bij raamwerkbank"
Anybody any idea?
Mirko
