Indigo 7.5 Release Notes
Official announcements on new releases or other important events.
jay (support)
Post by jay (support) »
7.5.0 is now available for download (you must be logged in to your Indigo Account to download). For an overview of the changes in this version, see our blog announcement here.
Note: This release may not be available to all Indigo 7 users, specifically those who have allowed their Up-to-Date Subscription to lapse. The downloads page will show if you are eligible for the latest release or you can also check the licenses page in your Indigo Account or use the Indigo 7(.X)->License Details... menu to see the status of your subscription.
Any maintenance releases of Indigo 7.5 (7.5.1, etc) will be outlined below this post on this forum topic.
A reminder on app and path names: we've made it easier for users to switch back to a previous Indigo version if they like. For this release, we've changed the install path to:
/Library/Application Support/Perceptive Automation/Indigo 7.5/
The installer is smarter than it used to be and now moves control page images over for you (among other improvements). The other change is that the Indigo Mac Client app is now named Indigo 7.5 to identify which client you're trying to launch. If you have problems upgrading from a previous version of Indigo then read through the appropriate upgrade section: New General Features and Fixes
  • Added brand specific actions for Inovelli devices (works with most current Inovelli switches as of December 2020):
    • Set LED Brightness when Off
    • Set LED Brightness when On
    • Set LED Color
    • Set Notification
    • Clear Notification
  • Added brand specific actions for Zooz devices (only the ZEN30 switch has LEDs that can be set as of now):
    • Set Default Brightness
    • Set LED Color
  • Added Match On State to Keypad LED State action which will match any number of devices that support binary (on/off) state to a specified KeypadLinc LED state.
  • Added Event Log window font text size UI to General panel of preference window, and increased default size used.
  • Worked around macOS security bug that prevented Indigo Python scripts (and plugins) that execute AppleScripts from prompting the user for permission.
  • Improved action panel UI to show up to 32 sprinkler zones on Run Schedule action.
  • Fixed text color in send email action panel and Insteon link editing dialog for macOS Dark Mode support.
  • Fixed bug that caused Triggers and Schedules to not be sortable based on the Notes column in the Main Window.
  • Fixed bug that caused RGB values extracted from UI color wells to be inaccurate.
  • Fixed bug that could cause some relay and dimmer devices to not be identified as relay/dimmers on some trigger and action UI panels.
  • Fixed bug in SQL Logger Plugin that caused a log error if a device state value changed to an integer that required more than 32-bits for storage.
New Z-Wave Devices and Fixes
  • Improved performance of Z-Wave communication (over 5x faster in some scenarios).
  • Improved reliability of sending Z-Wave commands in high traffic scenarios.
  • Added support for Aeotec Z-Stick Gen5+ (ZW090) and Z-Stick 7 (ZWA010)
  • Added support for Vision Z-Wave USB Stick (VIS-ZU1401), including working around incompatibility caused by misreported API version.
  • Added preliminary support for Remotec IR Thermostat Bridge (ZXT-600).
  • Added support for new variant of Aeotec Door / Window Sensor 7 (ZWA008).
  • Added support for new variant of Duwi Key Fob (ZME-KFOB2).
  • Added support for new variant of Fibaro Leak Sensor (FGFS101).
  • Added support for new variant of GE Smart Lighting and Appliance Control Receptacle Outlet (14288).
  • Added support for new variant of Horstmann/Secure 1 Channel Boiler Actuator (SSR303).
  • Added support for new variant of Neo CoolCam Multi Sensor (NEOEMS02Z).
  • Added support for Aeotec AërQ Temperature and Humidity Sensor (ZWA009).
  • Added support for Aeotec Door/Window Sensor 7 Pro (ZWA012).
  • Added support for Aeotec Smart Switch 7 (ZWA023).
  • Added support for Aeotec Water Sensor 7 Pro (ZWA019).
  • Added support for Devolo Humidity Sensor (MT02755).
  • Added support for Enerwave Relay Switch (ZWN-RSM1-PLUS).
  • Added support for Eva Logik Smart Plug-in Appliance (ZW36).
  • Added support for Eva Logik Smart Plug-in Appliance (ZW96).
  • Added support for Everspring Floodlight Sensor (EH403).
  • Added support for Fibaro Roller Shutter 3 (FGR223).
  • Added support for Fibaro Smart Module/Switch (FGS214).
  • Added support for Fibaro Double Smart Module/Switch (FGS224).
  • Added support for Fibaro Walli Double Switch (FGWDSEU221).
  • Added support for GE Enbrighten Smart Light Dimmer (46203).
  • Added support for GE Smart Switch (46201).
  • Added support for GE Smart Toggle Switch (46202).
  • Added support for HeatIt Thermostat (TRM2fx).
  • Added support for Honeywell Thermostat (TH6320WF2003).
  • Added support for Honeywell Outdoor Appliance Module (ZW4201).
  • Added support for Honeywell Plug-in Smart Dimmer (39336).
  • Added support for Honeywell Relay Switch (ZW4008).
  • Added support for Inovelli Fan and Light Switch (LZW36-SN).
  • Added support for Inovelli Multi Sensor (LZW60).
  • Added support for Leviton Outlet (ZW15R).
  • Added support for Merten Shutter Module (507801).
  • Added support for Merten Wall Shutter Module (5045).
  • Added support for Monoprice RGBW Dimmer Controller (36511).
  • Added support for Neo Coolcam SOS Key Fob (RC01Z).
  • Added support for Philio Smart Color Button (PSR04).
  • Added support for Qubino Smart Meter Din Rail (ZMNHXD).
  • Added support for Swidget Smart Outlet (R1015S).
  • Added support for Wink Motion Sensor (WNK-MOT1).
  • Added support for Yale Keyless Push Button Deadbolt (YRD110).
  • Added support for Zipato Motion Sensor.
  • Added support for Zooz Double Switch (ZEN30).
  • Added support for Zooz Multi Relay (ZEN16).
  • Added support for Zooz RGBW Dimmer (ZEN31).
  • Fixed support for Philio Double Relay Module (PAN04).
  • Fixed support for Schlage Motion Sensor (RS200HC).
  • Fixed bugs that caused Inovelli Dimmer Switch (LZW31-SN) and Relay Switch (LZW30-SN) ON/OFF device state to incorrectly be set on Up Button, Down Button, and Configuration button presses.
  • Improved re-sync process for modules that have definitions that change the number of devices needed.
SQL Logger Improvements
  • Added support for device level sqlLoggerForceStoreAllStates shared property that can be used to force all states to be written for table updates, overriding the Store only changed states setting on a device level. To use install the Global Property Manager plugin to define a new key (sqlLoggerForceStoreAllStates) setting the value to True.
  • Improved device level shared property sqlLoggerIgnoreStates logic to not create device table at all if value is set to *.
Scripting, Developer and API Changes
  • Plugin API version number has been incremented to v2.4.
  • Plugin API addition: Added plugin.isInstalled() and indigo.server.getPluginList().
  • Plugin API addition: Added optional argument (level) to indigo.server.log() method to specify the python logging level that will determine the Event Log window text color used: logging.INFO (black), logging.WARNING (orange), logging.ERROR (red). The default plugin logger instance will also now map self.logger.warn() to use an orange text color.
    import logging
    indigo.server.log("message here", level=logging.WARNING)
  • Plugin API bug fix: Fixed bug that prevented colorpicker defaultValue attribute from working.
  • Improved handling of plugin device state definitions so that ValueType of float now creates a float/real device state (not integer).
Return to “Announcements”
